Buying a BMW x3 - diesel or gasoline?
maxpac4321 43566 13
Which engine is the best choice for a BMW X3, diesel or gasoline, and what are their typical advantages and faults?
For most buyers in this thread, the best compromise is the 3.0d; it is described as robust and pleasant to drive, while the cheaper 2.0d is acceptable but needs careful attention to the timing on N47 cars and to the intake flaps and injection system on older M47 cars [#15412613][#15414029][#15414745] The 3.5d is basically a twin-turbo 3.0d, but its maintenance costs are higher [#15412613] On petrol engines, older naturally aspirated units like the M54 are considered OK, though they can consume more oil; newer petrol engines have more power but also more complexity and potentially more problems [#15412613] When buying, check the service history first, especially xDrive, the transmission, the condition of the injectors, and whether the car smokes under hard acceleration [#15414029][#15414745][#15413919] The 2.0d 150 hp is seen as the minimum, but several posters recommend moving up to the 3.0d if the budget allows [#15414745][#15433619]
  • #1 15412419
    maxpac4321
    Rate: 16
    Hello sincerely I am planning to buy a BMW x3 I do not know with which engine, someone is perhaps a diesel and gasoline user please give me an opinion on the advantages and disadvantages and faults.
  • #2 15412613
    Kune
    Help: 23
    Rate: 212
    Well I guess it also depends on the budget. 2.0d costs much less than 3.5d, maintenance also different and combustion.
    My opinion is that the optimal for this car is 3.0d. Risks, as in any new diesel injectors (6x), dual mass/automatic, turbo, egr etc. In general, the engine itself is very robust.
    2.0d, it now depends which one? I have an e60 lci N47 (177 horses) and overall super engine, low fuel consumption, runs well, ZERO problems - the only important thing is to take care of the timing, or replace it - BMW has a service campaign and if it covers your car, they will replace it for free if necessary.
    3.5d is actually 3.0 on biturbo. In truth, a powerful engine, it drives well, but maintenance costs go up.
    Penzines that are without water features (i.e., for example, M54) are ok, except for increased appetite for oil, but this can be removed at relatively low cost, and 230 horses already go somehow. Newer engines have more power, but also, unfortunately, are much more complicated (valvetronic, direct injection) so they can cause a bit more problems.
    What budget are you talking about? Because X3 can be bought for 25 and for 70, depending on the vintage and engine.
    In general, BMW is not a cheap car to maintain, as you move from Astra or Golf you may be a little surprised. The question of aesthetics is an individual matter, for me it's an ugly car, just like the X1. How about the Outlander II? It's in truth a nice car.
  • #3 15412816
    maxpac4321
    Rate: 16
    OK up to the amount of 35 thousand.
  • #4 15413313
    DJ ANNUS
    Help: 108
    Rate: 354
    Are you sure you want an x3?
    You know it's not a cheap car to repair, do you have someone you know who has it g........ ?
    :O -3-3
  • #5 15413726
    Kune
    Help: 23
    Rate: 212
    DJ ANNUS wrote:
    Are you sure you want an x3? You know it's not a cheap car to repair, do you have someone you know who has it g........ ?
    :O -3-3
  • #6 15413891
    DJ ANNUS
    Help: 108
    Rate: 354
    Kune wrote:
    I'm curious, because supposedly everyone, everything knows, and I suspect they never had
    And from there , even if you gave it to me for free I would not take it.
    X3--even funny spelling, I have been repairing since 2006 as a guy from the area bought it for himself.
    Now various heads buy it for themselves because they are cheap , xenons, transmission, melted pistons from broken injectors, drivetrain, accident repairs it all makes the grade.
    I myself would choose something from hunday or toyota or volvo.
    And if you already want a bmw then se 5 fund.
  • #7 15413895
    maxpac4321
    Rate: 16
    I don't have anyone with a car like this.but in my right mind would I want a bmw as if mine couldn't afford the repairs ☺ thanks for the hint I'll go ha days to take a look x3 ☺
  • #8 15413919
    DJ ANNUS
    Help: 108
    Rate: 354
    It's ok , just before you buy it drive it decently , drive it into the meadow see if the drive doesn't jerk , see if the kesnons light up the same , see if the air conditioning works , see if it leaves a trail of smoke behind when accelerating hard.
  • #9 15414029
    Kune
    Help: 23
    Rate: 212
    DJ ANNUS wrote:
    X3--even funny to write, I have been repairing since 2006 as a guy from the area bought it for himself.
    I understand, but all these things you mention apply to almost every car available on the market, which is why I ask about the typical weaknesses of this model because:
    - different filaments is probably a small problem
    - automatic transmission, unfortunately has the fact that at a certain mileage (usually more than 200kkm) requires revision and more or less repair
    - worn injectors is also not the fault of the car
    - accident repairs are a matter of care in making this repair, it is not a problem of the model, but of the copy.
    So back to the topic, because probably from 80% of cars will have this motor:
    - with N47 (2.0d) pay attention to whether the timing was replaced, if not then check whether the car is subject to service action
    - M47 (2.0d) is an older engine, known from E46 - 150 horses. You can find a lot of information on the internet, the problem is definitely the flaps in the intake manifold and the delicate injection system.
    Unfortunately, I don't have much time now to look at specific copies. What engines do you have to choose from? What are you considering?
    Of course, check the condition of the drives, and the engine when buying, due to the rather high mileage. Look for a car with a good service history, even at the expense of mileage. Body repairs are nothing to worry about, unless it was something more serious or it is done carelessly.
  • #10 15414104
    maxpac4321
    Rate: 16
    I don't know yet what engine I will look at,I am staying in Germany so here I will look.I will write I will go for a drive to see,but some bigger rather engine will be.
  • #11 15414745
    kakibara
    Help: 202
    Rate: 1284
    x3 2.0d 150 km is the minimum, preferably 3.0 d, 3.0 pb, 4.4 pb on pb will be expensive but nice may be with the sequence,
    you must definitely check the service xdrive
    the manifolds crack,
    the manifold flaps like to fall into the middle,
    in diesel around 170 - 200 thousand km may appear the first signs of dual mass,
    suspension very durable on the originals.
    up top a colleague suggests something from the far east - he may be right that cheaper, and probably inside more space - x3 is strikte 4-seater on the road, but if one drives a premium class, it will be hard to switch to, for example . kia or hund.
    automatic is GM as I am not mistaken.
  • #12 15424329
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    Kune wrote:
    :O -3-3
  • #13 15424643
    andrzej20001
    Help: 1578
    Rate: 6669
    ML already better.
  • #14 15433619
    maxpac4321
    Rate: 16
    I was looking at x3 2.0 diesel car OK but too weak And it was damaged.Overall Very nice to drive I am looking for 3.0.
The discussion revolves around the decision to purchase a BMW X3, focusing on the choice between diesel and gasoline engines. Key points include the cost differences between engine options, with the 2.0d being more affordable than the 3.0d, which is considered optimal for performance. Users highlight the importance of maintenance, particularly for diesel engines, which may face issues such as injector problems, dual mass flywheel wear, and turbocharger reliability. The 2.0d engine is noted for its low fuel consumption and reliability, provided the timing chain is properly maintained. Concerns about repair costs and the overall reliability of the X3 are raised, with some users suggesting alternatives like Hyundai, Toyota, or Volvo for better value. The necessity of thorough pre-purchase inspections is emphasized, particularly for common issues like manifold cracks and suspension durability.
