Disabling Fire Alarm in Apartment: Safe Methods for Child's Room (Photos Included)
szywester 13011 3
  • Asking whether disconnecting one alarm speaker triggers a fault
    #1 16305743
    szywester
    I have the following problem in the block where I live there are fire alarms installed, i.e. every burning of the cutlet, lighting a cigarette etc. generates a sound signal in the apartment. The signal is very loud for this we have 4 loudspeakers in 5 rooms, recently the alarm at night scared my 2-year-old son to the extent that he does not want to sleep alone in the dim light and for several days he is experiencing that he will turn on again. I want to turn off this system even in my son's room, I don't know much about electronics, that's why I don't know if cutting the cables from the speaker will cause an alarm or signal in the central unit that there is something wrong with the alarm, etc. I attach photos of the alarm after removing the housing, maybe someone will tell you what to unscrew, so as not to have any trouble.
    Regards.
  • #2 16305839
    Adam-T
    Help: 834
    Rate: 1096
    Disconnect one cable from the speaker and it will be off your head.
  • #3 16305978
    szywester
    I would have to rip it off because it is soldered.
  • #4 16306100
    Gregovic
    Help: 11
    Rate: 21
    weaker speaker, or replacement with a "rooster" warning light, or better yet put an 8ohm 15W resistor instead of this speaker :)
