Hotpoint Ariston KIX 644 BEIT induction plate - displays error F5.
mos5 16875 5
  • #1 15820792
    mos5
    Help: 12
    Rate: 148
    Please give me a hint as to what is the F5 error , I would appreciate the entire list of Ariston cooker errors.
  • #2 15820858
    psine.pl
    RTV equipment specialist
    Help: 133
    Rate: 328
    As it is a program similar to Amica, you can check the same damage :D
    That is interrupting the connection between the tiles. So in a nutshell.
    So slides, connectors, connecting cables. Any patina or interrupting cable (or connector) can cause this.
    But there is also a good chance that the driver is damaged. :-(
    in amice it means exactly that:
    Anomalies in the connections between the panel
    touch and electrical splitter
    – all cooking zones are inactive,
    all displays are shown
    error
    and that the rest of the service is very similar, I think it is possible to follow this trail further. :D
    brands
    PSINE.PL
    ul.Karczówkowska 8A, KIELCE, 25-019 | Company Website: https://www.psine.pl
  • Suspected unstable FSL136HR inverter causing F5 error
    #3 15836309
    mos5
    Help: 12
    Rate: 148
    inventco.eu thank you for your help, unfortunately The quality and reliability of the connections I've checked is very good. I have already repaired a dozen induction hobs and almost always the problem consisted of lack of contact, cold February, burned out elements and the most frequently flooded parts of the control board. Here the plate is perfect without any visible signs of malfunction. Power transistors and large capacity capacitors. I am concerned about the unstable operation of the FSL136HR based inverter. There are large pulsations on the oscilloscope, possibly due to some greater load, unfortunately unsteady. Electrolytic capacitors checked (even replaced). Maybe some suggestions from dear colleagues.
  • #4 15891081
    adamekp
    Help: 19
    Rate: 55
    NTC thermistor on a large inductor for checking / replacing.
  • #5 15893891
    mos5
    Help: 12
    Rate: 148
    adamekp thank you for your help unfortunately today I checked the mentioned thermistors. They all have the same resistance of 88kΩ. Connectors from thermistors and wires in perfect condition. Maybe some other suggestion.
  • #6 15898318
    adamekp
    Help: 19
    Rate: 55
    Generally, F5 is a communication error and, as he wrote, inventco.eu you have to check everything for connections / cold solder. Personally, I had a case of a released DTT with the same mistake that's why I wrote to check it out. Maybe, however, cold February / joints? Did you "snag" cable harnesses?
