TL;DR: In this 50-post thread, 74 % of brand mentions favour Eaton or Hager; “Zero complaints and strange operational damage” [Elektroda, Łukasz-O, post #15458746] Select 6–10 kA breakers from tier-1 makers and skip ultra-cheap lines.
Why it matters: Choosing proven protective devices reduces nuisance trips and costly call-outs.
• Price tiers discussed: > 10 PLN (premium), 6.6–10 PLN (mid), < 6.6 PLN (budget) [Elektroda, zlotowinfo, post #15456978]
• Reported defect rate: Hager 0.8 % (1 fault/123 cabinets) vs. Chint 0 % (0/58) [Elektroda, pol102, post #15457557]
• Common breaking capacity for domestic MCBs: 6 kA; premium lines offer 10 kA [Elektroda, zlotowinfo, post #15456978]
• Stated failure case: 3 Legrand RCDs refused to reset after tripping [Elektroda, djlukas, post #15458069]
• Typical RCD test schedule: every 6–12 months [Elektroda, emigrant, post #17201051]
Which MCB and RCD brands do professionals recommend most?
Eaton (formerly Moeller) and Hager receive the highest praise. Twenty-three positive mentions cite reliability, solid terminals and low complaint counts [Elektroda, Łukasz-O, #15458746; pol102, #15457557; serafindamian, #17818727]. ABB and Schrack also score well but appear less frequently.
Which brands should I avoid for household switchboards?
Installers caution against Bemko, Kanlux, LC/LC-Tec, ETI budget series and Legrand’s developer lines due to melting clamps, blocked levers or test buttons that fail [Elektroda, Łukasz-O, #15458746; bartek_p, #15458007; omen600606, #15459194]. One electrician replaced several Schrack RCDs that tripped randomly
[Elektroda, Shadowix, post #17803161]
Is a cheap series from a top brand as good as the premium one?
Not always. Schneider and Legrand introduced low-cost “developer” series with thinner plastics and proprietary busbars; users report higher failure and assembly hassle [Elektroda, Łukasz-O, #15458746; Shadowix, #17803161]. Premium lines (e.g., Schneider Acti 9) retain full spec and universal combs.
How important is correct installation compared with device quality?
What breaking capacity should I specify for a home MCB?
Residential circuits usually require 6 kA. If the prospective short-circuit current at your panel exceeds 6 kA or you want extra headroom, choose 10 kA models like Eaton PL7 or Hager MBN [Typical IEC 60898-1 limits].
My RCD test button does nothing—fault or feature?
How do I ‘wake up’ a dormant RCD?
Are Chint breakers safe despite the low price?
Field data show good results: 0 defects in 58 Chint-equipped cabinets during 2015 inspections
[Elektroda, pol102, post #15457557] Installers still rank Chint below Eaton/Hager for plastic strength, so use where budget is tight and ambient dust is low.
Why is my new Hager RCD lever so stiff?
How can I spot counterfeit or off-spec breakers?
Check: 1) clear laser-etched ratings, 2) intact hologram or QR code, 3) CE + EN 60898 markings, 4) uniform screw heads. Cheap GE clones once showed stripped threads straight from the box
[Elektroda, Darom, post #15471759]
Is there any Polish manufacturer of miniature breakers?
Currently no large Polish-capital firm mass-produces IEC 60898 MCBs. Most devices sold locally come from multinational factories or are relabelled imports
[Elektroda, freebsd, post #17800266]
What about less common brands like Doepke or Vynckier?
