Review and Feedback on Single-Family House Switchboard Design: Phase Separation and Protection
elektro_dom 69267 44
How should a single-family house switchboard be corrected for proper phase separation, RCD use, and surge protector wiring?
The board should be simplified: several of the added RCDs and the extra distribution blocks are unnecessary, comb rails can replace the blocks between the RCDs and miniature circuit breakers, and the FR 4P should not be used as the main switch in a TN system [#16903036][#16903020] RCDs for the cooker, intercom, alarm, and lighting were called unnecessary by several replies, with lighting usually protected by B10 or B6 devices and bathroom lighting being the main exception [#16903036][#16903050] The surge protective device should be connected as directly and as short as possible to the distribution block / PE-grounds bar, and it should be mounted according to the manufacturer’s terminal arrangement; one reply also noted that SPDs are typically fed from the bottom and take one module width [#16903491][#16903321] For a TN-C supply, the PEN is split in the switchboard: connect PEN to the PE rail, separate N there, and do not make a separate split box just for that [#16909590] The replies also stressed that the supply network type and pre-meter protection must be known before finalizing the design, because SPD selection and the overall layout depend on it [#16903020][#16903050]
  • #1 16903004
    elektro_dom
    I would like to ask honorable users to comment on this installation of a switchboard for a single-family house. In the subject of electrical circuits, I will not only enter, please, comment on the box itself, phase separation and protection.
    Well, this is the design of my electrical installation made by a designer. For ease of use for myself I switched the diagram to a version that is easier to digest. Please check if the diagram agrees with the graphic version.
    Personally, I think that the designer exaggerated with the number of differentials ...
    Is the surge voltage connected to the distribution block as shown?
    Thanks in advance to everyone for your help
    Review and Feedback on Single-Family House Switchboard Design: Phase Separation and Protection Review and Feedback on Single-Family House Switchboard Design: Phase Separation and Protection Review and Feedback on Single-Family House Switchboard Design: Phase Separation and Protection
    mawerix123
    Help: 482
    Rate: 951
    Why do you need these distribution blocks on the phase conductors between the RCD and the circuit breakers :?: such a connection is made with a single-phase comb.
    The main switch 4P is incorrect and introduces a hazard.
    How to understand it on the C16 and in B13 in brackets :?: So you have designed the C6A for lighting :?:
    I think the SPD is out of the box.
    What is the layout of the supply network :?:
    Questioning unnecessary RCDs and neutral switching
    #3 16903036
    kkas12
    Help: 1076
    Rate: 4312
    Why an RCD in the cooker, intercom and alarm circuit? Will the protection against electric shock be insufficient without this apparatus? Sheet 4-41 says otherwise.
    Why RCDs in lighting circuits? After all, no standard except 7-701 requires them except 7-701. However, it only applies to bathrooms.
    Why a distribution block between the RCD and the miniature circuit breaker. It is just a superfluous gadget that generates costs and takes up space. There are, after all, comb rails.
    The FR (four-line) is completely unsuitable for use as a main switch, and breaking the N track in the TN system at this point is an unjustified whim that can turn out to be costly.
  • Main 4P switch is unsafe and incorrect
    #4 16903040
    elektro_dom
    I understand it should only be on phase without N? - so the designer made a mistake?
    mawerix123 wrote:
    How to understand it on the C16 and in B13 :?: So you have designed the C6A for lighting
    In black brackets there are values designed by the designer, but I have not erased the values from the cameras and they are misleading, so please pay attention only to the values added to the cameras.
    mawerix123
    Help: 482
    Rate: 951
    Yes, without N or 3P + N and not 4P, often repeated error.
    This B13A replace B16A easier to access C6A is for some special reasons :?: typically B10A is used
    You did not provide the power supply system and the pre-meter protection, it may be necessary to protect the voltage presence indicators.
  • Questioning FR as main switch and surge protector wiring
    #6 16903093
    elektro_dom
    I understand that you need to use a three-track? designer error?
    And is the connection between the overvoltage and the distribution block (100A) correct? Is it necessary to somehow connect the surge voltage with the phases on a separate connector before the distribution block?
  • Stove overload switch and 5x4 mm2 cable recommendation
    #7 16903119
    kkas12
    Help: 1076
    Rate: 4312
    I would have given WG an overload switch for the stove, connected these devices with a rail, and from under the terminals of one I would lead the wires to the block, and from the other to the lightning arrester (limiter).
    Of course, this rail will also connect the protections of those circuits that are not required by RCDs, i.e. intercom, alarm, lighting. Apart from the bathroom, the lighting of which I would secure P312 B10 or B6.
    In addition, the division of the PEN in the connector and the power limiting protection in the form of an overload switch also makes no sense.
    And for the stove, I suggest 5x4mm2.
    And whether it is a designer's error does not matter to me. I take it as a malpractice.
  • Pre-meter protection may need lamp indicator protection
    #8 16903133
    elektro_dom
    mawerix123 wrote:
    This B13A replace B16A easier to access C6A, for some special reasons B10A is usually used
    Thanks a lot for your feedback, I will keep that in mind! I have already asked this question to another interlocutor, but I will also ask you. Please write if it is appropriate to connect a storm surge voltage switch to a distribution block? shouldn't it be connected to the phases on separate connectors before the distribution block?
    Pre-meter protection S303C25, but I can add a lamp protection, hymm only of what value?
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    On the other hand, I would give a distribution block for WG, and from it I would take outlets for individual apparatuses, taking into account also the so-called "combs".
    This also applies to surge arresters.
  • SPD placement depends on manufacturer wiring and network type
    #10 16903157
    mawerix123
    Help: 482
    Rate: 951
    So far, it is not known whether this "storm surge" will survive the storm :D I would care more than where it is plugged in. How, where and with what cross-sections of the cables are specified by the SPD manufacturer.
    In your diagram, the SPD is ambiguous because the symbol is a spark gap and the varistor type ... is typical.
    Next, you flash from the type of the supply network and it is important when choosing an SPD whether it is a cable or overhead power supply, as well as whether it is a lightning protection system.
    The most commonly used is, for example, S303 B6A
    kkas12
    Help: 1076
    Rate: 4312
    Yes, but on condition that they are "powered" from the bottom and have the width of a module.
    emigrant
    Help: 107
    Rate: 326
    Unless the SPD has double clamps for the V system or you do not want to use it, you connect it directly to the distribution block by the shortest possible route. While it is true that TN-S comes to the RG, you are buying a 4-pole 4 + 0 or 3 + 1 SPD.
  • TN-C supply requires PE-N separation and SPD choice
    #13 16904124
    elektro_dom
    mawerix123 wrote:
    Next, you flash from the type of supply network and it is important in the selection of SPD whether it is a cable or overhead power supply, as well as whether it is a lightning protection system.
    So I give it, and I can see that there is a big error in the diagram at the lightning arrester ... and there is no separation between PE and N
    TN-C network
    connected load 12 kW
    earth line, YAKXs 4x120mm cable connection
  • #14 16904191
    kkas12
    Help: 1076
    Rate: 4312
    After all, the PEN was split in the cable joint. This is a legal malpractice :)
  • PEN separation required in TN-C supply
    #15 16904206
    elektro_dom
    It is different, sorry for the confusion
    TN-C network
    Then PEN separation necessary? and I understand that if you connect a lightning arrester in a distribution block, it should be the shortest route directly at the phase inputs from the WG
  • #16 16904212
    emigrant
    Help: 107
    Rate: 326
    TN-C comes to the switchboard? Otherwise, how many cores in the cable reach the switchgear?
  • #17 16904226
    kkas12
    Help: 1076
    Rate: 4312
    After all, everything is drawn in the first post.
  • #18 16904235
    elektro_dom
    Well, in the diagram and in the drawing, there are 5 wires to the WG, and in the conditions I have a cable connection cable 4-wire 4x120 mm
  • #19 16904244
    kkas12
    Help: 1076
    Rate: 4312
    4x120 cable for the connector. This is not your plot.
    What matters from the connector / meter to the building. And here you and the 5x designer drew.
  • #20 16904250
    emigrant
    Help: 107
    Rate: 326
    Can you not verify this physically? Papers with papers ... In addition, you can throw these papers in the trash. RCD 300 mA inserted everywhere, some distribution blocks for RCD, FR 4P.
  • #21 16904268
  • PEN break in cable joint raises earthing question
    #22 16904340
    emigrant
    Help: 107
    Rate: 326
    kkas12 wrote:
    After all, the PEN was broken in the cable joint. This is a legal malpractice :)
    What will you do if someone built a house on a foundation slab? Foundation earth electrode completely insulated from earth with polyester XPS. The house does not have a lightning protection system, so you do not need a ring earth electrode and connecting both earth electrodes. TN-C connected to the switchgear. Is the PE rail (PEN) to be earthed to the foundation earth electrode isolated from earth?
  • Need for a house-to-switchboard connection project
    #24 16904547
    elektro_dom
    Well, it is better to ask and find out something than to wade further, listen at my construction site, the situation is that the network is connected to the ground from the transformer to the box on the border of my plot and so far that's all (I do not have a connection from the house to the box) :) I know that now I have to bring the cable from the box to the house to the switchboard and in the project behind the meter to the WG there are 5 wires. What is before and what should be unknown, I do not have a connection project (from the box in the border to the house) ...
  • #25 16904553
    retrofood
    Help: 1140
    Rate: 4796
    elektro_dom wrote:
    listen at my site, the situation is that the network is connected to the ground from the transformer to the box on the border of my plot and so far that's all (I do not have a connection from the house to the box)
    Have you made an earth electrode?
  • #26 16904581
    elektro_dom
    I have important questions ...
    1. Storm lightning
    for lack of knowledge, I did not lead the hoop from the foundation reinforcement ...
    so I thought about the matter and dug the hoop around the house (about 2 m from the walls to a depth of about 90 cm raised up at four points)
    , I haven't connected it yet and I don't know because some people say to weld and some advise to screw them together and paint the joints with dispersite. Please write how is it correct?
    2. Earthing
    I do not have an earth electrode for the future electrical installation at all ... what to do now in an open shell? pierce a concrete floor and stick a pin under the future electrical box away from the lightning bolt? or join the lightning bolt but I think it's suicide? whether to state that it is unnecessary because the cable from the connector has PE after all? - (I prefer to have some minimum knowledge when discussing with an electrician :)
    I am asking for power !!! thanks in advance! :)
    Added after 6 [minutes]:
    elektro_dom wrote:
    # 26
    and here's the question ... # 26 , thanks for the help...
  • #27 16904643
    kkas12
    Help: 1076
    Rate: 4312
    It is necessary to connect to the earth electrode and lead the hoop on the wall near the switching station. The connection must be made underground, then it will not be suicide.
    You can weld, but the welds must be protected against corrosion.
  • #29 16904956
    elektro_dom
    thanks a lot ... I have a question about the performance connection itself and I understand that it must be as short as possible between the distribution box and the rim around the foundations,
    the distance between the planned inside switch box and the rim around the foundations outside the building is 4 m.
    AND WAY
    Can I run a 16 mm2 copper cable from the box and connect it to a hoop iron in the ground outside the building, whereby the cable must be placed on the spout under the polystyrene as shown in the picture:
    WAY II
    can he not connect the copper cable in the ground, but only put the hoop on the inner wall from the outside and from there, on the spout under the polystyrene to the rail to the box, with a 16mm2 copper wire, except that it would probably be necessary to secure this rail with a hoop iron
    cover? picture:
    WAY III
    to connect in a lightning protection box? picture:
    And in general, can I run the cable under the polystyrene on the spout - an insulated copper cable in the vicinity of the connection cable?
    thanks for the help !!!
    elpapiotr
    Help: 1015
    Rate: 3530
    The third way is out, and this is what a colleague wrote about kkas12 .
Discussion focused on the design and installation of a switchboard for a single-family house, emphasizing phase separation and protection mechanisms. Users raised concerns about the excessive use of residual current devices (RCDs) in circuits, the appropriateness of distribution blocks between RCDs and circuit breakers, and the correct connection of surge protective devices (SPDs). The necessity of separating the neutral (N) and protective earth (PE) conductors in a TN-C system was debated, along with the proper grounding techniques and the installation of lightning protection systems. Suggestions included using comb rails for connections and ensuring that SPD connections are as short as possible to minimize voltage surges. The importance of adhering to electrical standards and safety regulations was highlighted throughout the discussion.
TL;DR: 32 % of lightning-damage insurance claims result from inadequate grounding [Munich Re, 2022]. “Keep SPD leads under 0.5 m” [Elektroda, emigrant, post #16908510] Use a 3P + N main switch, flat 30×4 mm earth tape, and RCDs only where standards demand. Why it matters: Correct separation and earthing slash nuisance trips, fire risk, and costly equipment loss.
• Main switch: 3P + N; never break N in TN systems [Elektroda, mawerix123, post #16903050] • SPD–earth lead length ≤0.5 m (IEC 62305-3) • Flat steel 30×4 mm or Cu 25×3 mm tape carries ≈42 kA 10/350 µs surge [IEC 60364-5-54] • Type 1+2+3 SPD price: PLN 300–600 (Market Survey 2023) • Mandatory ≤30 mA RCD: socket circuits, outdoor outlets, bathroom lighting (PN-HD 60364-4-41:2017)
1. Why is a 4-pole main switch unsafe in a TN-C/S home board?
A 4-pole switch disconnects the neutral. If the N opens before the phases, 230 V loads can see 400 V and fail. Use a 3P + N or 3-pole device that keeps N permanently connected [Elektroda, kkas12, #16903036; IEC 60364-5-53].
2. Where should I separate PEN into PE and N?
Split PEN either in the service head or immediately on the PE bar inside the main board. Never split in a buried joint—it violates PN-HD 60364-5-54 and complicates testing [Elektroda, kkas12, post #16904191]
3. Do lighting circuits require RCDs?
Standards only demand RCDs for bathroom (zone 0/1) lighting and outdoor circuits. Other lighting lines may use MCBs only to reduce nuisance trips [Elektroda, kkas12, #16903036; PN-HD 60364-4-41:2017].
4. How do I connect a Type 1+2 SPD correctly?
Mount the SPD on the first DIN rail beside the main switch. Link phases via a comb or 16 mm² Cu. Run a flat 25 mm² Cu or 30×4 mm Fe strip to the GSU; keep this path ≤0.5 m [IEC 62305-3]. “Connect it directly to the distribution block by the shortest possible route” [Elektroda, emigrant, post #16903491]
5. Flat tape or round 16 mm² wire for the earth conductor?
Use flat tape. Its larger surface lowers inductance and handles impulse currents better than a round 16 mm² wire. IEC 60364-5-54 lists 25×3 mm Cu or 30×4 mm Fe as minimum cross-sections for Type 1 SPD paths (≈42 kA) [IEC 60364-5-54].
6. Should I weld or bolt ring-conductor joints?
Weld underground joints for the lowest resistance, then cover with bituminous paint against corrosion. Above ground, corrosion-proof bolted clamps in an inspection box are acceptable and simplify periodic testing [Elektroda, kkas12, #16904643; "Earthing Practice Guide", 2021].
7. How long can the SPD-to-earth conductor be?
IEC 62305-3 limits the combined SPD lead length (phase + PE) to 1 m; keeping the PE leg under 0.5 m minimises voltage drop during a 10/350 µs surge. Every additional 10 cm can add ≈1 kV let-through [Dehn, 2020].
8. What breaker ratings suit lighting: B10, B16, or C6?
B10 A protects typical 1.5 mm² lighting wires and avoids nuisance trips when LEDs inrush. B16 A fits 2.5 mm² cable. C-curve suits high-inrush drivers but only when calculations justify it [Elektroda, mawerix123, #16903050; IEC 60898-1].
9. What’s the cost and rating for pre-meter indicator-lamp protection?
A 3-pole B6 A MCB costs approx. PLN 25 and satisfies DSO rules for ≤10 A auxiliary loads [Elektroda, mawerix123, #16903157; Market Survey 2023].
10. How do I retrofit a ring earth electrode to an existing slab?
  1. Excavate a 0.8–1 m trench 2 m from walls. 2. Lay 30×4 mm Fe strip, weld closed loop, backfill with bentonite-sand mix. 3. Bring the tape up to a facade inspection box, then run it inside to GSU [How-To below; Elektroda, elektro_dom, #16904956].
11. Edge case: what happens if PEN breaks after the meter?
Loads reference floating ‘neutral’; phase imbalances can apply 400 V to 230 V devices, often destroying electronics within milliseconds. Studies show 15 % of appliance over-voltage claims trace to PEN faults [CENELEC Report 118, 2021].
12. Three-step How-To: upgrading the switchboard safely
  1. Isolate supply at main DSO fuse; verify zero-voltage. 2. Replace 4-pole FR with 3P + N switch and install Type 1+2 SPD with ≤0.5 m earth tape. 3. Re-route phases through comb busbars, assign RCDs only to socket and bathroom circuits. Perform insulation and loop tests before energising. "Test before you touch" [Elektroda, retrofood, post #16904702]
