Fiat Stilo 2002: Non-Functioning Visteon CD, No Can Network Display, Possible Solutions
paul66 9852 4
  • #1 15475484
    paul66
    Hello, I bought a Fiat Stilo with a non-functioning CD Visteon. This is manifested by the message on the NO CAN NETWORK display, counts from 5 to 0 and the end. I've read on various forums about it, but nothing helps.
    I did:
    - ISO CAN A and CAN B bars are in place, pins 1 and 3,
    - I connected the battery to reset the computer,
    - I checked all fuses,
    -when holding buttons 1 and 6 plays a radio and shows the firmware numbers, etc., then shows NO CAN NETWORK,
    The previous owner claims that he just stopped playing one day. What could be wrong? Is it possible to work around CAN NETWORK? Please help.
    LWD11
    Help: 223
    Rate: 486
    Hello, assuming that everything is in place in the car, there is a tja1054 on the radio responsible for CAN communication, a high probability that it has been damaged.
  • #3 15475842
    paul66
    It pays to repair it? Who could do this to me?
  • #4 15479342
    adams
    Help: 44
    Rate: 99
    First, it would be good to check what the problem, radio or auto. Connect your radio in another car or other radio with you.
  • #5 15517579
    paul66
    Problem solved :) LWD11 colleague suggested that I fix radyjko, I sent a packet of radio, it turned out that correctly diagnosed damage TJA1054, repaired and today radyjko to me returned :D Everything works as it should, I also recommend a friend for the future :)
