[Solved] The car does not start, the lights flash after removing the key, Stilo 1.8
babazakolkiem 9768 7
  • #1 17266091
    babazakolkiem
    Hello to all forum members, I'm new here, but previously I used this site a lot in various fields. Always useful tips.
    Currently, I have a fairly big problem - maybe some of you have encountered it: well, after repairing the car (a plate was welded to grab the engine's paw from the gearbox side), I left the mechanic as usual, drove to work, then fired again and went to the store . Unfortunately, the car did not start from the shop parking lot. After turning the key in the ignition switch, the lights turned on properly, but the starter did not work, even a characteristic knock was not heard. On the other hand, after withdrawing the key, and even after removing it from the ignition, the lights flashed like crazy, the hands were vibrating. I tapped lightly on the steering wheel - it stopped. I checked the clamps on the battery - they were tightly screwed on by a mechanic, although he said that the employee "probably" did not disconnect the battery. I tried to start the car again, but the same thing. I took the clamp off, waited 10 minutes, fastened it and nothing helped. Then a tapping on the steering wheel did not help, just removing the clamp so that the board would not flash. Is this a short circuit?
    adamski123
    Help: 46
    Rate: 250
    Hello, many things could have been damaged during welding, from the ECU, BODY and the burned out wiring harness, at the beginning, check the weight on the engine and the rest. I personally weld about 10 cars a day and I have never had such a case because I put on a protection on the battery, or I unfasten the clamp.
  • #3 17266113
    babazakolkiem
    Thank you, I'll check it out (i.e. my husband will check it) and let you know. greetings
    Added after 58 [minutes]:
    what I have not written yet, and what is very important, that the message "check vehicle protection system" is displayed and the padlock is on.
  • #4 17266301
    adamski123
    Help: 46
    Rate: 250
    Hello, see on the second key what is the reaction
  • #5 17266303
    babazakolkiem
    unfortunately I only have one :(
    adamski123
    Help: 46
    Rate: 250
    Hello, and the key has not fallen without a diagnosis, it will be difficult to tow the car to the mechanic
  • #7 17266982
    babazakolkiem
    Whew ... done !!! :) . It's a broken engine ground wire. Due to the fact that the bolt of the third leg of the engine mount broke, it rocked the engine and had to break the ground wire. My dear, big and wise husband made a temporary mass from the bedside lamp cable and so we started the car. This is also how we reached the channel, where he found that the ground wire was only tucked into the T-shirt. He attached it on the washers, because we didn't have a ferrule (this clamp with an eyelet) and it works.
    Adamski123 - good lead with a lack of mass - applause and thanks :) . Best Regards
  • #8 17266989
    babazakolkiem
    Broken engine ground wire. It was not visible directly because it was in a T-shirt next to the block. The meter showed no weight.
The discussion revolves around a Fiat Stilo 1.8 that failed to start after a repair involving welding. The owner reported that the ignition lights activated, but the starter did not engage, and unusual flashing occurred after removing the key. Responses suggested checking the engine ground wire, which was identified as the issue. A broken ground wire due to engine movement was confirmed, and a temporary fix was made using a bedside lamp cable. The problem was resolved by properly securing the ground connection.
