Fiat Stilo 2003: Triangle Control exclamation mark (BRKE.LAMP FAIL) & Engine Fault Light Issues
K19oChA94S 18183 5
  • #1 16347416
    K19oChA94S
    Rate: 20
    Hello, I have a Fiat Stilo with 2003 1.6 16V and the eternal problem of this car is that the triangle control with the exclamation mark (BRKE.LAMP FAIL) is constantly disappearing once every 20 times and the second control is (engine fault). shines from 3.4 days and will disappear for a month and then again the same. I read on the net that it is a bane Stilo but maybe someone has a solution to this annoying problem. I would like that all the lights work.
  • #2 16347454
    spinacz
    Help: 1205
    Rate: 2655
    Yes, go to the garage to do the diagnostics and fix it.
  • #3 16347479
    andrzej20001
    Help: 1578
    Rate: 6675
    Make bypass the mass of the rear lamps and check the error diagnostics at the workshop.
  • #4 16347541
    K19oChA94S
    Rate: 20
    Can something brighter with a bypass? This check I checked with my buddy is a catalyst error ....
