Computer Case LED Switches from Blue to Blinking Red with Damaged USB Ports
vister12 23385 11
Why did the front-panel power button LED change from steady blue to blinking red, and why does it sometimes not light up at all?
The blinking red LED is most likely the hard drive activity light, so it blinks when the disk is being read or written, not because of the USB ports or the case LED itself [#15480977][#15540162] A steady blue light when the computer sleeps does not contradict that, because the power button and disk activity indicators can behave differently [#15480977] If the disk really has 3/4 bad sectors, the drive is failing and there is no point in continuing to use it [#15540162]
  • #1 15479122
    vister12
    Rate: 21
    I have a problem with my computer because the LED in the computer case is blinking red. Sometimes it doesn`t light up at all. It used to glow blue all the time. I will mention that the case has two USB ports on the front that are damaged and the power supply cable was once broken
  • #2 15479140
    kokapetyl
    Help: 1787
    Rate: 2105
    Not with a computer, but with a diode. :D
    Describe the actual problem and provide the full hardware configuration.
  • #3 15479331
    vister12
    Rate: 21
    Is this about what I provided in the attachment? And there is no problem with the computer related to this diode, I`m just surprised that it was blue all the time before.
    • DxDiag.txt (31.33 KB) You must be logged in to download this attachment.
  • #4 15479540
    R1hab
    Help: 22
    Rate: 94
    Are you talking about these diodes on the front of the panel?
    One from the disk, the other from the power supply... you probably changed the cables...
    Take a photo of these "diodes"
  • #5 15480000
    vister12
    Rate: 21
    This is about the diodes on the front of the panel. The cables are connected according to the motherboard instructions. Computer Case LED Switches from Blue to Blinking Red with Damaged USB Ports1456686098...835375.jpg (3.49 MB)You must be logged in to download this attachment.
    And this LED is blinking all the time, only when I do something more demanding with it, it only lights up
    • Computer Case LED Switches from Blue to Blinking Red with Damaged USB Ports 14566861287901634356473.jpg (4.74 MB) You must be logged in to download this attachment.
  • #6 15480851
    R1hab
    Help: 22
    Rate: 94
    Is the LED on the POWER button blinking?
    You have the wrong cables and that`s it.
    Did you or someone else mess with your computer or did it just happen?
  • #7 15480976
    vister12
    Rate: 21
    Yes, this is the diode from the power button. It just happened
  • #8 15480977
    Serwis_Eldamar
    Help: 15
    Rate: 21
    Maybe the blue diode or its power supply is damaged.
    The red diode most often signals the operation of the hard drive, which is why it blinks - and perhaps it simply lights up on the power button?
    Either way, you won`t be able to do anything without stripping.
    Eldamar Serwis
    Pocztowa 11b, Dziadkowice, 58-200 | Company Website: www.eldamar.com.pl
  • #9 15480981
    vister12
    Rate: 21
    But when the computer goes to sleep and then I use it again, the LED is blue. I have a question: could it have something to do with the power supply?
  • #10 15486920
    vister12
    Rate: 21
    Is it possible that the diode is blinking because of the disk? Because the red diode is supposed to be from the disk. I checked the disk with HD Tune and it showed that 3/4 were bad sectors
  • #11 15540162
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    The LED shows disk activity. So most often it blinks (or lights up) if the disk is being read/written. If the disk has 3/4 of its surface damaged, there is no point in continuing to use it.
  • #12 15540316
    vister12
    Rate: 21
    Ok, thanks for your help
The discussion revolves around a computer case LED that has changed from a constant blue glow to a blinking red light, with intermittent failures to light up. The user notes that the case has damaged USB ports and a previously broken power supply cable. Responses suggest that the blinking red LED may indicate hard drive activity, especially since the user reported bad sectors on the disk. It is also mentioned that the LED behavior could be linked to the power supply or incorrect cable connections. The user confirms that the LED returns to blue when the computer wakes from sleep, indicating potential issues with the power supply or the hard drive itself.
