MacBook Pro 1226: Analyzing MagSafe Adapter's Red, Pale Green & Orange Blinking LED
tomasz249 7884 12
What component failure could cause a MacBook Pro MagSafe adapter LED to flash red/orange and the laptop not to power on?
The thread does not identify one exact failed part; the most likely conclusion is that the SMC is not detecting the MagSafe power supply, so the fault is probably in the logic-board power/power-detection circuit rather than the adapter itself [#16422748][#16411402] The LED behavior was interpreted as green = charged, flashing orange = charging, and red as abnormal, but that pattern alone does not pinpoint a single component [#16411306] The adapter was also reported to work with another laptop, which makes the charger less likely to be the problem [#16420994] Suggested next steps were to try another power supply and the SMC reset procedure, but if there is still no reaction the repair is at service/board-diagnosis level [#16413444][#16411402] One detailed reply recommended checking for 3.3 V at the power button, then measuring the 19 V input and rails around TPS51120, ISL6257, LT3470, the KBC H8S/2116, and possibly the NV chip [#16432213]
  • #1 16411259
    tomasz249
    Help: 10
    Rate: 68
    A friend has a laptop, a MacBook Pro 1226, the condition before checking was unknown. The MagSafe power adapter flashes red when connected, sometimes this LED in the plug had a pale green glow and over time it began to flash orange more and more. On this basis, can you determine what may be damaged in the laptop?
    [movie: 9e2d66f470] https://filmy.elektroda.pl/89_1492121551.mp4 [/ movie: 9e2d66f470]
  • #2 16411306
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    Green LED = charged battery
    Flashing orange = charging
    Red = does not bode well (is it really red?).
  • #3 16411322
    tomasz249
    Help: 10
    Rate: 68
    Red, maybe orange. Battery removed so it's not charging
  • #4 16411402
    lisek
    Service technician RTV
    Help: 6356
    Rate: 6887
    Reset the SMC (System Management Controller) Link
    Look at Link
    It will not help, you must think about the service
  • #5 16412200
    tomasz249
    Help: 10
    Rate: 68
    I will not do the reset because it does not even turn on. And the way with holding the power button 5s I tried.
    It is an old laptop, so it will not pay off for a service, if you could only say a few options what is damaged, I could try to do something.
  • #6 16412390
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    tomasz249 wrote:
    if there were only a few options that could be said what is broken, I could try to do something.
    Give the plate number, write what equipment you have.
    Additionally, describe your experience in diagnosing MB in 5 words.
  • #7 16413444
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Have you checked on a different power supply?
    Check the behavior when turning on without SMC - disconnect magsafe, press and hold power, connect magsafe, release power, press power like when turning on normally.
  • Power supply ruled out; LED changes with board connections
    #8 16420994
    tomasz249
    Help: 10
    Rate: 68
    I'm not a specem, equipment typical of a hobbyist electronics.
    The power supply is not the fault because another laptop worked on it.
    Board marking written on the laminate: 820-2101-a
    Marking on the sticker (stuck on the DVI socket): MB7010B13182
    PS. after connecting magsafe to the power board itself (left), the magsafe diode glows pale green and when I connect the matrix backlight in turn, the motherboard is still like that. And when everything is connected and magsafe is connected, it flashes orange.
  • #9 16422748
    Reset_Uk
    Level 19  
    Help: 30
    Rate: 22
    The SMC does not detect the power supply. That is why it is so. If you are not an Apple repair specialist, you will not be able to do it.
  • #10 16422758
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    You checked:
  • #11 16423219
    tomasz249
    Help: 10
    Rate: 68
    Yes, no reaction.
    EDIT
    So I understand there is no simple answer to the question "what could have gone".
    I merged. RADU23
  • #12 16431976
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    No.
  • Suggested power-rail checks for A1226 charging failure
    #13 16432213
    lisek
    Help: 6356
    Rate: 6887
    Charging> lights up orange, .. without Aku, lights up green
    You have 3.3V on the button,> after pressing it goes to 0V?
    Nap. do you have duty on your chokes? (TPS51120> see datasheet)
    * pin.9 / pin.10 >> 3.3V and 5V.
    - see sign.EN1 / En2
    - measure ISL6257
    If you don't, start with
    - 19V checks on LIO 820-2102.
    - then on IC LT3470> pin 5> choke ... power supply KBC H8S / 2116 BGA
    ps
    Can be prophylactically "blowing" on the NV chip (G84-603-A2)
    No org SM.
    It is available on the web (significant differences, and not everything) for the 051-7225 model
    Apple MacBook Pro A1226 MLB, MBP15 820-2101
    The album in PL service from 180-day. warranty (installation in the service) is about PLN 900
    Usage from the USA (with included shipping) is around $ 180-200
The discussion revolves around a MacBook Pro 1226 experiencing issues with its MagSafe power adapter, indicated by a flashing red LED, occasional pale green glow, and increasing orange flashing. Users suggest that a red LED typically indicates a problem, while a green LED signifies a charged battery. The author mentions that the battery has been removed, leading to the conclusion that the laptop is not charging. Suggestions include resetting the System Management Controller (SMC) and checking the power supply with another device. However, the author is reluctant to pursue service options due to the laptop's age and seeks potential damage diagnoses. Further technical insights point to possible issues with the SMC not detecting the power supply, and various voltage checks on components like the TPS51120 and LT3470 are recommended for troubleshooting.
