Extending RJ-45 Network Cable: Connect Router with Longer Cable & Maintain Connection Quality
18546 12
Can I extend an RJ-45 network cable to move the router, and will a coupler keep the connection working properly?
Yes—use a proper RJ45 coupler/connector or simply buy a longer network cable. Keep the total cable length under 100 meters. Choose a coupler matched to your cable type: one for ordinary UTP and another for shielded FTP. Do not use an RJ11 telephone/fax adapter, because it is too small for RJ45. Cheap couplers may be unreliable, so a dedicated one from a decent supplier is the safer choice. [#15523618] [#15523631] [#15523673] [#15524471] [#15523674]
  • #1 15523578
  • #2 15523618
    pp74
    Help: 186
    Rate: 283
    Perhaps such a connector is enough. Or even simpler a longer cable.
  • #3 15523631
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    This element is enough for you if the total cable length does not exceed 100 meters.
  • #4 15523648
  • #5 15523657
    pp74
    Help: 186
    Rate: 283
    Of course.
  • #6 15523660
  • #7 15523673
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    Arturkot123 wrote:
    Can it be like that? #product
    Unfortunately, it cannot be! Such because it is for telephones and faxes. It is smaller than it should be RJ45!
    "They're writing conflicting data on this page, either to phones or to the Internet."
  • #8 15523674
    lasal1
    I do not recommend this one from castorama, I bought a few of it not so long ago, it did not work. They only connected when you pressed the plugs.
    Purchased from Nowy Elektronik, they worked flawlessly.
  • #9 15523738
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    lasal1 wrote:
    I do not recommend this one from castorama, I bought a few of it not so long ago, it did not work. They only connected when the plugs were pressed.
    It depends on what was bought and what it was used for. If an RJ45 connector was purchased and used for cables with RJ11 lugs, only pressing the plug into the socket actually helped.
  • Recommend using dedicated RJ-45 couplers for UTP and FTP cables
    #11 21169822
    Terebint
    Rate: 69
    Yes, I know it's an old topic, but....
    tomiok wrote:
    I recommend dedicated connectors, no problems with that, for regular UTP:
    http://www.planetaelektroniki.pl/product.php?id_product=978
    Or for shielded FTP cables:
    http://www.planetaelektroniki.pl/product.php?id_product=997
    And with such a connector, the transmission speed will not drop? I, on the other hand, need to extend the cable approx. 4 metres, from 12 to 16 metres.
  • #13 21175871
    Terebint
    Rate: 69
    Thank you, this seems like a good option. I wonder if there are any 4 metre ones. I'll have a look, thanks for the lead.
To extend an RJ-45 network cable connected to a router, users can utilize a longer cable or a dedicated RJ-45 connector, ensuring the total length does not exceed 100 meters to maintain connection quality. It is crucial to use the correct type of connector, as some connectors designed for RJ11 may not function properly with RJ-45 cables. Recommendations include using dedicated connectors for UTP and FTP shielded cables to avoid issues. Users have successfully used products like the Ugreen RJ-45 extender without experiencing a drop in transmission speed.
