Experiencing No Visuals but Sound on Philips 32PFL3008H/12 TV - Possible Causes?
alsek 52968 8
  • #1 15556720
    alsek
    Rate: 33
    Hello, today the TV just turned off while watching the news. The image disappeared and the sound remained. And so it is until now - the sound continues, the image is gone. I tried to disconnect, connect, I changed decoders and nothing of it. What could be causing this crash? The TV is a Philips 32PFL3008H / 12 and is no longer under warranty.
    Marian B
    Help: 392
    Rate: 1161
    The backlight of the screen does not work. There can be many reasons, eg one of the transformers in the inverter, electrolytic capacitors, damaged fluorescent lamp, short circuit / damaged semiconductor, bad soldering, especially of heating elements, the ends of transistors / diodes can be desoldered, etc. Nobody will give a ready solution.
  • #3 15556784
    Freddy
    Help: 1394
    Rate: 2821
    If you press the "menu" key, you can see something?
  • #4 15556822
    alsek
    Rate: 33
    Nothing is displayed after pressing the menu key. But after some time in a row with the "power" button, you can see slightly skipping dark gray rectangles when you turn on the TV for about 2 seconds.
    NIXIE_123
    Help: 288
    Rate: 610
    In a dark room, turn on the TV and light the screen with a flashlight. Do you see any picture?
  • #6 15557904
    alsek
    Rate: 33
    Poor, but you can see. What does it mean?
    miecho18
    IT specialist
    Help: 3087
    Rate: 2778
    This means that there is no matrix illumination. You have to give the TV to the site.
  • #8 15557943
    alsek
    Rate: 33
    What will be the approximate cost of the repair?
  • #9 15557948
    miecho18
    IT specialist
    Help: 3087
    Rate: 2778
    Without taking measurements, it is impossible to determine.
The Philips 32PFL3008H/12 TV is experiencing a failure where sound continues but visuals are absent. Possible causes include malfunctioning backlight components such as transformers, capacitors, or damaged fluorescent lamps. Users suggested checking for any display by pressing the "menu" key or illuminating the screen with a flashlight, which revealed faint images, indicating a lack of matrix illumination. Repair is recommended, but costs cannot be estimated without further diagnostics.
