[Solved] Philips 3208H/12 TV No Picture & Sound, Responds to Remote, Connects to Internet - Matrix Fail?
LukayLukay 13929 16
Why does my Philips 3208H/12 TV turn on its LED, respond to the remote, and connect to the internet, but show no picture or sound?
It was likely not the matrix; the thread points first to the power supply/backlight and its electrolytic capacitors instead [#17094077] A bulged, slightly leaking capacitor was found, and the advised replacement was a 470uF/16V part [#17096154] [#17096230] Replacing that capacitor alone did not fix the TV, so there was another fault as well [#17105355] The TV was later repaired in service: another damaged capacitor was found only after measurements, and the software also had to be reinstalled [#17224673] [#17224674]
  • #1 17093824
    LukayLukay
    Rate: 11
    Philips 3208h / 12 TV.
    In the evening it worked, in the morning the screen did not turn on, there is no sound. The TV responds to the remote control, the LED is on, looking at the router, the TV also connects to the internet. Did the matrix fall?
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. Did a colleague make some measurements of the power supply voltage and on the backlight of this Philips 40PFL3208H / 12 SMART?
  • #3 17094094
    LukayLukay
    Rate: 11
    No, I have to borrow the meter, but I have the opportunity tomorrow.
  • #5 17096154
    LukayLukay
    Rate: 11
    I opened it now and it seems to me that one capacitor shown in the picture is bulged at the top, plus it has a slight leakage.
    Philips 3208H/12 TV No Picture & Sound, Responds to Remote, Connects to Internet - Matrix Fail? Philips 3208H/12 TV No Picture & Sound, Responds to Remote, Connects to Internet - Matrix Fail? Philips 3208H/12 TV No Picture & Sound, Responds to Remote, Connects to Internet - Matrix Fail?
    Krzysztof Druś
    Help: 35
    Rate: 85
    Exchange 470uF / 16v.
  • #7 17097142
  • #8 17104306
    LukayLukay
    Rate: 11
    He didn't have an identical guy in the store and gave me 470uF / 50v saying he would be ok. It's a bit bigger, but will fit under the casing. Today I will solder.
    Krzysztof Druś
    Help: 35
    Rate: 85
    It is good that the dimensions are not too high voltage does not bother. It should preferably be at 105 ° C.
    Freddy
    Help: 1394
    Rate: 2821
    LukayLukay wrote:
    it is bulged on top, plus it has a slight leakage.
    Do not forget to wash the tile from what has spilled.
  • #11 17105355
    LukayLukay
    Rate: 11
    Unfortunately, the replacement of the capacitor did not give anything, there had to be something else wrong, all the others look ok. So much when it comes to my repair options, also thank you for helping everyone.
  • #12 17105366
    Krzysztof Druś
    Help: 35
    Rate: 85
    Plus with minus you did not mistake because the capacitor will fire?
    Well, now the voltage to measure in the first photo you have a socket under it the voltage that should be on it.
    Something doesn't suit me, the socket has a 13 pin and the description has a 12 pin?
  • #13 17105378
    Pedros050
    Help: 2471
    Rate: 3926
    Even voltage measurements were not done. Refer RTV repair point and locate fault and power supply will be repaired.
  • #14 17105415
    LukayLukay
    Rate: 11
    I soldered correctly I am sure. Okay, I'll take it to the radio and TV point where I bought the capacitor because they fix the equipment there, maybe they can do something.
  • #15 17105422
    Krzysztof Druś
    Help: 35
    Rate: 85
    As they say, a good choice with this site.
  • #16 17224673
    LukayLukay
    Rate: 11
    I write back a little bit because I forgot about the topic. The TV was successfully repaired, except for one capacitor, another one was damaged, which I could not find without taking measurements. In addition, the television has been unloaded and you had to install the soft again. The cost of the repair was PLN 140. Thanks to everyone for help :)
  • #17 17224674
    LukayLukay
    Rate: 11
    repair on the tv site
The Philips 3208H/12 TV experienced a failure where the screen and sound did not activate, despite responding to the remote and connecting to the internet. Initial troubleshooting suggested checking the power supply voltage and inspecting capacitors for bulging or leakage. A bulged capacitor was identified and replaced with a higher voltage component (470uF/50v). However, the issue persisted, leading to further investigation. Ultimately, it was discovered that another damaged capacitor was the root cause, which was identified through measurements. The TV was successfully repaired, and the total repair cost was PLN 140.
TL;DR: For a Philips 40PFL3208H/12 with no picture/sound, start with power/cap checks; "It should preferably be at 105 °C." Use 105°C-rated capacitors and higher-voltage replacements when needed. [Elektroda, Krzysztof Druś, post #17104359] Why it matters: This helps DIYers quickly decide if a simple capacitor swap and basic measurements can revive the set or if service is smarter.
Did the matrix/panel fail if there’s no picture and no sound, but the TV responds to the remote?
Unlikely in this case. The final fix found another bad capacitor and required a software reinstall. The panel was not replaced. If the matrix failed, sound usually remains. Here, two capacitors were bad and firmware was reloaded, restoring function for PLN 140. [Elektroda, LukayLukay, post #17224673]
What’s the first diagnostic step on a Philips 40PFL3208H/12 with these symptoms?
Measure the power supply and backlight voltages with a multimeter before replacing parts. Confirm standby and main rails at the PSU connector. This quickly separates a PSU/backlight issue from mainboard or software causes. Keep notes of each rail versus its label. "Measure power supply voltage and on the backlight" was the first ask in the thread. [Elektroda, Pedros050, post #17094077]
Which capacitor should I replace first?
Start with the visibly failed one, then the commonly flagged part: 470uF/16V on the PSU. Check for bulging tops or leakage. Replace like-for-like capacitance and equal or higher voltage. Use a quality low-ESR, 105°C part. As one expert said, "Exchange 470uF / 16v." Verify polarity before soldering. [Elektroda, Krzysztof Druś, post #17096230]
Is a 470uF/50V capacitor safe to use instead of 16V?
Yes, a higher voltage rating is acceptable if physical size fits and ESR is suitable. Prioritize a 105°C temperature rating for reliability. The advisor clarified that extra voltage headroom does not harm operation. Quote: "It should preferably be at 105 °C." Ensure correct polarity and secure soldering. [Elektroda, Krzysztof Druś, post #17104359]
How do I identify bad capacitors on the PSU board?
Look for domed tops, split vents, or brown residue from electrolyte. Any leakage or swelling means replacement. These failures are common in monitor and TV power sections. Replace suspect parts as a set if several show age. Confirm polarity marks before removal. "They are recognized ... by a bulge on top and electrolyte blots." [Elektroda, Anonymous, post #17095902]
I replaced the bulged cap and nothing changed—what next?
Measure all PSU and backlight rails. A second capacitor may be faulty even if it looks fine. In this case, two capacitors were bad and firmware had to be reinstalled to recover. Record voltages versus the connector label. If rails are unstable, recap the affected section. [Elektroda, LukayLukay, post #17224673]
What did the successful repair involve and how much did it cost?
Service found another failed capacitor and reinstalled the TV software. The total reported cost was PLN 140. The set returned to normal operation. This path avoids unnecessary panel replacement. Keep this cost as a benchmark for similar faults. [Elektroda, LukayLukay, post #17224673]
Why does capacitor polarity matter so much when soldering?
Electrolytics are polarized. Reverse installation can destroy the capacitor and risk board damage. One expert cautioned that mixing plus and minus means "the capacitor will fire?" Always match the board’s plus/minus markings and the capacitor stripe. Double-check before powering up. [Elektroda, Krzysztof Druś, post #17105366]
When should I hand it to a repair shop?
If you lack a meter, skills, or see confusing readings, stop and refer it to an RTV repair point. As advised: "Refer RTV repair point and locate fault and power supply will be repaired." This avoids further damage and speeds diagnosis. [Elektroda, Pedros050, post #17105378]
Is a connector label mismatch (12 vs 13 pins) a problem?
It can indicate a revision or silkscreen mismatch. Verify the actual pin count and the voltage legend before probing. An expert noted a 13-pin socket with a 12-pin description. Trust the board’s measured pins and markings near your connector. Confirm ground reference before measuring. [Elektroda, Krzysztof Druś, post #17105366]
Can software cause these symptoms on this Philips model?
Yes. In the documented case, the TV had to be "unloaded" and the software installed again after hardware repair. Firmware issues can present as no audio/video while the set still responds to the remote and network. Reflashing restored normal behavior here. [Elektroda, LukayLukay, post #17224673]
How do I measure the backlight and PSU rails safely?
Three-step check:
  1. Set DMM to DC volts and reference chassis ground.
  2. Measure standby and main rails at the PSU connector against its label.
  3. Measure the backlight supply when powering on. This targets the failure zone before swapping parts. Document readings. [Elektroda, Pedros050, post #17094077]
What should I do after a capacitor leaked onto the board?
Clean the affected area thoroughly and let it dry before power-up. Residue can conduct or corrode traces. As one member reminded, "Do not forget to wash the tile." Use appropriate electronics-safe cleaning methods and inspect pads before reinstalling parts. [Elektroda, Freddy, post #17104531]
