  • #1 15579120
    tough
    Hi, I am in the process of designing a KNX installation in a flat with a 400V induction hob. In the flat, there is to be a push button at the entrance to cut off the power to all consumers (except the fridge) including the induction hob when leaving the house. And here is the question: have you come across a 400V/20A switch actuator?
  • #2 15579387
    janeczekkk
    Help: 44
    Rate: 76
    You can use the output of the actuator to drive the coil of a contactor, and you can find one with the necessary parameters.
