It is not possible to change the resolution in CS: GO.
Baleronek 34182 3
  • #1 15612375
    Baleronek
    Hello, I have a resolution problem
    in the menu in the game I only have a resolution of 1600x900
    how could i change to 1280x720
    1 month ago I was able to change that
    Thanks in advance
  • #2 15612379
    kuba0742
    Hello, let's start with what operating system do you have?
  • #3 15612774
    Baleronek
    Win 7
  • #4 15616303
    kuba0742
    Ok now I will give you a short tutorial on how to enter certain commands into the startup settings:
    1. Go to your Steam game library and find Counter-Strike: Global Offenisve there
    2. Right-click on CS: GO and then go to properties - you will find them at the bottom.
    3. Go to the General tab and then click on SET STARTUP OPTIONS. You will see a field where you can enter your startup parameters.
    4. Type -in 1280 -h 720 there and try running Cs: Go
