Intel i5 4690k MSI Z97 G43 Board: Correct Torque for Corsair Hydro Series H75 CPU Cooler
natsu12 16692 15
Can overtightening a Corsair Hydro Series H75 cooler damage an Intel i5-4690K or MSI Z97 motherboard, and how tight should the cooler be screwed down?
If the PC is stable and the temperatures are now normal, you probably did not damage the CPU; with a backplate/spacers, the motherboard would likely be the first thing to suffer, and the CPU/IHS is hard to crush unless the pressure is badly uneven [#15615671][#15621000] The nut popping out sounds more like the screw/nut was started crooked or the thread was crossed than like CPU damage [#15615841] The cooler should be tightened firmly enough to make solid contact so it cannot move, with only a thin layer of paste, but there is no exact torque value for this type of mount [#15615740] A practical way to judge it is to tighten the screws evenly, counting turns or feeling for similar resistance on each side, so the backplate stays straight and the pressure is distributed evenly [#15622796] If the system continues to run normally and the load temperatures are much better than before, that is a good sign that the mount is acceptable [#15623714]
  • #1 15615641
    natsu12
    I have a small question and problem at the same time. I bought new equipment based on the Intel i5 4690k platform and the MSI Z97 G43 board. I bought water cooling from Corsair Hydro Series H75, the first time I tightened the pump too weak, and the temperatures in IDLE reached 40C and under stress even 89C, so I decided to tighten the cooling. However, I miscalculated the strength and suddenly I heard a crack, one of the nuts popped out. After this incident, I checked the CPU and motherboard for damage. However, I did not notice anything, but on the core of the pump you can see a scratch from the corner of the IHS, but nothing can be seen on the CPU. After replacing the paste and screwing it again, the temperatures dropped to 48C under stress. I have a question, did I damage something that I don't know about? The processor and the motherboard are stable. Can such a strong tightening can damage the CPU if there are spacers anyway?? Please reply. Regards.
  • #2 15615671
    310artur
    Help: 980
    Rate: 670
    If it works, you haven't damaged it. You could damage the motherboard, the processor would be difficult to damage - possibly you could crush the IHS, but since the temperatures are good, you probably didn't bend it.
  • #3 15615686
    natsu12
    And how crushed IHS is with the thread guarantee?? :P Luckily nothing happened.
  • #4 15615703
    310artur
    Help: 980
    Rate: 670
    Well, it looks like it's mechanically damaged. On the other hand, the CPU needs to be broken (improper OC or healthy overheating) or be unlucky for it to fail.
  • #5 15615713
    natsu12
    And as for the pressure of the cooler, it must be screwed tight??
    310artur
    Help: 980
    Rate: 670
    Well, it must. The minimum necessary amount of paste and solid pressure. It's not allowed to move. Only you see, there are no numbers here, no torque wrenches, so with this force it's a moot point. Two people will tighten it tightly - one will fly, the other will break everything. So firmly but with feeling...
  • #7 15615766
    natsu12
    When I tightened the pump, I still had some slack, but suddenly trachhhhh and the nut jumped out of the thread.
    310artur
    Help: 980
    Rate: 670
    Maybe something was set crookedly. Because I understand you have the backplate on.
  • #9 15615821
    natsu12
    Of course it's founded. I don't know what to think about it.
  • #10 15615841
    310artur
    Help: 980
    Rate: 670
    Since it was dead and it was possible to put it back together again, I bet that you screwed the nut crookedly and it fell off the thread. Lucky you didn't ruin the thread :P
  • #11 15615853
    natsu12
    Luckily I had to buy a new mount.
  • #12 15620657
    natsu12
    And tightening the screws too much can crush the cpu, since there are spacers, I'm tired of this matter, and the computer works stably.
  • #13 15621000
    310artur
    Help: 980
    Rate: 670
    I think the motherboard will fail first. But if you have a backplate, nothing can happen. The processor is a piece of nickel profiled (probably embossed) sheet (IHS) placed on the PCB. A fairly evenly distributed pressure will take a lot of pressure.
  • #14 15621580
    natsu12
    And how do I know that the pressure is even?
  • #15 15622796
    310artur
    Help: 980
    Rate: 670
    The rotation of the screws is usually counted. Possibly, after all, you feel the resistance of the screw under the screwdriver or whatever you twist it. If the backplate lies straight, all the distances are whole, then with the same number of turns of the screws or the same resistance of the screw, the pressure is equal.
    Stop panicking now. You bought yourself a good computer - now you know why it's better to have an antique for the first steps in assembling, modding and assembling a PC. Then you learn from your mistakes at little cost.
  • #16 15623714
    natsu12
    Well nothing is happening yet, so maybe nothing will happen;D I think if the pressure was bad then the temperatures would be worse.
The discussion revolves around the installation of a Corsair Hydro Series H75 CPU cooler on an Intel i5 4690k processor with an MSI Z97 G43 motherboard. The user initially experienced high temperatures due to insufficient tightening of the cooler, leading to a subsequent attempt to tighten it more securely, which resulted in a nut popping out. Concerns were raised about potential damage to the CPU or motherboard, particularly regarding the integrity of the IHS (Integrated Heat Spreader). Responses indicated that while excessive tightening could theoretically damage the CPU, the presence of spacers and the current stable operation of the system suggest no significant harm was done. Proper torque specifications were discussed, emphasizing the need for even pressure during installation to avoid mechanical damage. The consensus is that as long as the system remains stable and temperatures are manageable, the user likely did not cause lasting damage.
