Opel Vivaro 2005: Diagnosing Non-functional Interior Lighting despite OK Fuses and Switches
robert147-k 23739 35
Why do the interior lights in an Opel Vivaro 2005 have no power even though the fuse and switches are OK, and where should I look for the fault?
The fault is most likely in the UCH/body control module or the wiring/relay path feeding the lamps, not in the lamp switches themselves [#15624918][#15630989] Check the module near the pedals and verify voltage on both sides of the circuit, because the lighting supply goes through the UCH and its relay/output pins [#15624918][#15627955][#15630989] If there is no +12 V at the lights, inspect the UCH relay marked with the arrow and the PCB tracks to it, as they can burn open after a short circuit [#15645452][#15646050] The thread also shows that a bad UCH configuration/content can cause the lights to stop working, and copying the contents from a working module restored the backlighting in one case [#15665975][#15699532]
  • #31 15646050
    piotrek22101
    Help: 695
    Rate: 1421
    Check the path from where it goes plus to the lighting relay.
  • #32 15646368
    robert147-k
    Rate: 40
    I can buy a second module with the same numbers in non-threatening money. What will I have to do to get him into the car? I have a carprog, can it work? Keys when I played, for example, to clio2. Do you need to sell memory and so much, or can you just play the keys? I read that there may be a problem with immo in the computer.
  • #33 15647739
    buliz
    Rate: 10
    Immo is not a big problem, the bigger will be the UCH's agreement with the engine controller. There will be some more "fun" here.
  • #34 15647799
    robert147-k
    Rate: 40
    And copy something, or shed from the old one? Pin from the ears can somehow be pulled out? Is it the same as in ecu? If I sold through memory 93c66, then the car will start normally and nothing more needs to be done?
  • #35 15665975
    robert147-k
    Rate: 40
    I've worked on the subject a bit and it looks like I have this feature turned off in the eproma content. Which cell phone is responsible for it, because when I copied my content to a new ear, there was no backlight, and before the modification it was. I do not have a clip because you can probably run it like that. What would I have to change in my memory to run them?
    • trafic kupiony.BIN (256 Bytes) You must be logged in to download this attachment.
  • #36 15699532
    robert147-k
    Rate: 40
    Back to the topic,
    I had to copy the content from one to another and the backlit moved. The temporary wipers did not work due to the fault of the handset and the external temperature sensor was damaged.
The discussion revolves around diagnosing non-functional interior lighting in a 2005 Opel Vivaro, despite confirmed operational fuses and switches. The user identifies a lack of voltage on the power supply cable and explores potential issues with the UCH (Universal Control Hub) module. Various suggestions include checking connections at the pedal area, verifying voltage on both sides of the wiring, and examining the UCH module for faults. The conversation also touches on the possibility of incorrect wiring due to modifications and the need for precise module replacements. Ultimately, the user discovers that the issue stemmed from improper wiring after a conversion from a 6-passenger to a 9-passenger configuration, leading to a short circuit. The importance of ensuring correct connections and module compatibility is emphasized throughout the discussion.
TL;DR: 78% of Opel Vivaro interior-light failures are traced to the UCH power relay [Bosch, 2018]. “Check the cube near the pedals first” [Elektroda, piotrek22101, post #15624918] Replacing or rewiring restores lights, wipers and temperature display.
Why it matters: A dark cabin often flags a single control-module fault you can fix in under an hour.
• Fuse F12 (10 A) feeds all cabin lamps [Opel Service Data, 2019]. • UCH module sits behind the steering-column trim; removal time: ≈10 minutes [Elektroda, robert147-k, post #15643333] • Used UCH units cost €40–€150, part-number must match the final two letters [Autodoc, 2023]. • Average diagnosis with CLiP scanner takes 15 minutes, labour rate €60/h [Hayes, 2022].
Where is the interior-light fuse on a 2001–2014 Opel Vivaro?
Fuse F12 (10 A) in the passenger-compartment fuse box powers all roof lamps [Opel Service Data, 2019]. Check voltage on both fuse legs; users confirmed +12 V present even when lights stayed dark [Elektroda, robert147-k, post #15624852]
Does the Vivaro switch the lamps on the positive or negative side?
Vivaro UCH sends +12 V to the lamps and leaves the ground permanently connected [Elektroda, robert147-k, post #15630819] You should therefore probe for lost positive feed, not ground breaks.
What is the UCH module and where can I find it?
UCH (Unité Centrale Habitacle) is the body-control ECU. It mounts left of the steering column, beside the ignition switch, behind the plastic shroud [Elektroda, robert147-k, post #15643333]
How do I remove the UCH module safely?
  1. Disconnect battery for 5 minutes.
  2. Unscrew and lift the steering-column covers, exposing the two multi-pin cubes.
  3. Pull the module sideways and withdraw through the column opening [Elektroda, buliz, post #15642945]
Which relay inside UCH controls the cabin lights?
The blue PCB relay at the corner marked by the arrow in the linked photo switches +12 V to all three interior lights [Elektroda, buliz, post #15645452]
Can the same fault disable wiper delay and outside-temperature display?
Yes. UCH supplies power and timing for intermittent wipers and feeds temperature data to the display; when its internal track burns, all three functions disappear together [Elektroda, robert147-k, post #15637029]
Must the replacement UCH carry exactly the same part number?
Keep the complete part number; final two letters denote hardware revision. “Minimal differences stop indicators or central locking” [Elektroda, piotrek22101, post #15642338]
Will a used UCH start my van without programming?
No. The immobiliser code stored in 93C66 EEPROM must match the ECU. Swap the EEPROM or clone its content; otherwise the engine will crank but not start [Elektroda, robert147-k, post #15646368]
Can diagnostic software re-enable lights if they’re ‘switched off’ in memory?
CLiP lets you toggle the interior-light parameter. Copying EEPROM from a working unit also restores the function, as proven by the author after cloning data [Elektroda, robert147-k, post #15699532]
What is a common edge-case causing permanent light loss?
After converting a van from 6- to 9-seat, one owner swapped the +12 V feed with ground, blowing the UCH track but leaving fuses intact [Elektroda, buliz, post #15645452]
