Parallel connection of motor and lighting to NICE TT1N possible?
Tomasz Filipiak 2784 2
  • Using relays to isolate lighting from TT1N motor outputs
    #1 15672453
    Tomasz Filipiak
    I would like to connect to the Nice TT1N control unit a tubular motor for the roller shutters and in parallel the lighting in the garage, i.e. upward output for the internal light and downward output for the external light.
    Purpose
    When I give the signal upwards, I want the door to open and the light inside the garage to come on, and when I give the signal downwards, the door to close and the outside light to come on, so that I don't have to walk home in the dark.
    I would like to add that the control unit, after every up or down signal, puts voltage on these outputs for approx. 3 minutes and switches them off by itself
    Of course, this connection has already been made and the result is that the motor capacitor has died after several openings and closings.
    The question is, if I connect the lighting via a relay, i.e. I connect the relays upwards and downwards in parallel under the control unit, does this prevent damage to the capacitor?
  • #2 15672483
    piotrek22101
    Help: 695
    Rate: 1421
    Certainly yes, the module will only give a signal. The entire load will go through the relays. Supply power to the relays from the 230v input.
  • #3 15673041
    Tomasz Filipiak
    And that's what I was thinking. Thanks for the reply, if anyone has any other suggestions, they are welcome
    I will probably tinker tomorrow. I'll let you know what the result is.
