Time relay with cyclic mode of operation: T1-20 min, T2-1 min - model wanted
hexor331 3894 8
  • #1 15719937
    hexor331
    Hello!
    I need help in finding a suitable relay/timer switch.
    I mean one in which two times can be set (ON time T1- 20 min and OFF time T2-1min). The problem in finding one is that in most cases it is only possible to start a new cycle after disconnecting and re-connecting the supply voltage. I, on the other hand, need continuous cyclic operation. I look forward to your suggestions. Regards :)
  • #2 15719971
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    I don't really know what you mean.
    Or do you fancy one of these time switches:
    • Tygodniowy włącznik Boilera Agnieszki.pdf (631.98 KB) You must be logged in to download this attachment.
    • DT03 TFE2 Cyfrowy programator czasowy - PL - Instrukcja.pdf (933.83 KB) You must be logged in to download this attachment.
    • Instrukcja obsługi cyfrowego tygodniowego wyłącznika czasowego.pdf (314.57 KB) You must be logged in to download this attachment.
  • #4 15720350
    kosmos99
    Help: 338
    Rate: 820
    Cheaper is unlikely to do it, as two regular timepieces are unlikely to be cheaper.
  • #5 15723088
  • #6 15725321
    texma
    Rate: 26
    Take a look at the AVT1820. On and off times can be set separately. It runs in circles.
    Be warned - the resistors in front of the display are to be replaced. Someone forgot about the load capacity of the whole CPU and at maximum consumption (e.g. 88) the pins can pop. If you want to build in then don't take an assembled one. The same someone did not make an effort....
    greetings. Czarek
  • #7 15731426
    dzolo35
    Help: 56
    Rate: 120
    You make a bistable circuit on the immortal NE 555.
    or
    You buy for example an ARDUINO NANO, a 5v power supply and a relay for avr circuits with opto isolation. In the arduino you program whatever times you want (for your need, you only need to modify a little bit the times in the blink program). Type in You Tube : ARDUINO blink. Instead of the diode from the examples , you connect a relay .
  • #8 15828314
    Zbigniew 400
    Help: 283
    Rate: 794
    555 takes care of the subject
  • Clarifying timer requirements and installation constraints
    #9 15828382
    jega
    Help: 67
    Rate: 108
    You have not provided the relevant information:
    1) is timing adjustment needed?
    2) what accuracy and stability is expected/necessary?
    3) is price the criterion and if so how do you value your time?
    4) do you allow for a software solution?
    5) do you want to install this in a switchboard on a rail or build it into some kind of device?
    the result - a range of solutions from grass to grass, each with advantages and disadvantages, and there may be no optimum solution.
