[Solved] Huawei E5186S-22A Router Login Password Issues: Reset, Default & T-Mobile Network Info
furtek 22374 9
How can I log in to a Huawei E5186s-22A router after resetting it when the default passwords do not work?
After a reset, try logging in with username `user` or `Enduser` and enter only the password; on some T-Mobile units the web login uses a 6- or 8-digit PIN from the sticker instead of the Wi‑Fi key [#17621266] [#17621278] [#17700981] If that still fails, the admin password is stored in NVRAM rather than on the label, and one user confirmed it was on the `hw_webui_userpwd` line, not `http_passwd` [#17701449] [#17701489] [#17709053] Changing or downgrading firmware does not change this login data [#17701891]
  • #1 17620970
    furtek
    Rate: 34
    Hello, I bought a Huawei E5186s-22a router from the T-mobile network and I do not know the password for this router.
    I reset the router by holding the reset button for more than 10 seconds, several times as if the router is resetting (it seems to me after the lights),
    but typical passwords, ie admin password 1234 0000, do not work.
    I will add that on the sticker on the back there is only the password for wifi 2.4 and 5GHz.
    Is it only possible to upload the new firmware?
  • #2 17621266
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Check.
    Login: user or User
    Login: Enduser
    Regards, Dara
  • #3 17621278
    furtek
    Rate: 34
    Only the password needs to be entered without login.
  • #4 17700659
    zubrowaty
    Rate: 12
    Can you guide more precisely? Because I have the same router, only with the Tele2 logo, and I have the same problem - I cannot log into the configuration page.
  • #5 17700981
    symeks
    Help: 12
    Rate: 18
    I have a sticker with a pin code in my tmobile with which I log in after the reset, 6 or 8 digits.
  • #7 17701489
    zubrowaty
    Rate: 12
    I was able to preview nvram yesterday - I found a parameter there:
    http_passwd = admin
    But this password doesn't work.
  • #8 17701611
    furtek
    Rate: 34
    Have you changed the firmware?
  • #9 17701891
    zubrowaty
    Rate: 12
    Yes - I did a downgrade first, and then I uploaded soft from Telia.
    Unfortunately, this data is missing on the sticker, and the firmware itself will not change it - the login data is definitely saved in a different area.
  • #10 17709053
    zubrowaty
    Rate: 12
    Success, password is on another line:
    hw_webui_userpwd =
The discussion revolves around login password issues for the Huawei E5186S-22A router purchased from T-Mobile. The user is unable to access the router's configuration page despite multiple resets and attempts with common default passwords. Other users suggest various login credentials, including "user" or "Enduser," and mention the possibility of a PIN code specific to T-Mobile. Some participants discuss accessing the router's nvram to retrieve the password, while others note that changing firmware does not affect the saved login data. The conversation highlights the challenges faced by users in retrieving or resetting the router's login credentials.
