[Solved] Huawei B528s-23A Router Configuration Access: SSID, Password, & Advanced Settings Guide
bpjl 28404 10
How can I access the full configuration of a Huawei B528s-23A router instead of only the quick setup wizard so I can change the Wi‑Fi password and other advanced settings?
There was no special admin/login method given to unlock the full menu; the practical advice was to factory reset the router, because if the menu still does not expand then something is wrong with the device [#17300051] If it is a T-Mobile-supplied unit, the recommendation was to let the operator handle it, especially if it is still under warranty [#17300398] The router in the thread was eventually exchanged by T-Mobile, and after that everything worked correctly [#17322707]
  • #1 17299405
    bpjl
    Help: 16
    Rate: 177
    Welcome,
    Does anyone know how to enter the configuration of the Huawei B528s router? After logging in to 192.168.8.1 I get only a quick configuration wizard where I can set the SSID of the network, the new router access password and the way of updating.
    How to get to more advanced settings? I would like to change the WIFI password.
    I remember that some Netia router had to log in with other data than admin / admin and then access to the full configuration. Maybe it's the same here? Unfortunately, I can not find this on the web.
  • #3 17299963
    bpjl
    Help: 16
    Rate: 177
  • #5 17300039
    bpjl
    Help: 16
    Rate: 177
    Cable. I try to never configure via WiFi to not stay with the proverbial finger in the proverbial ...
  • #6 17300051
    matek451
    Help: 4352
    Rate: 5808
    Something is wrong, there are only settings in the menu and they do not develop. Reset it to factory settings, RESET button / hole.
  • #7 17300108
    bpjl
    Help: 16
    Rate: 177
    I tried. Single press and hold until all LEDs are green
  • #8 17300143
    makosuu
    Help: 369
    Rate: 370
    It used to be the case here in the forum, it ended up putting the router in T-Mobile. Something is wrong with him and let them worry.
  • #9 17300264
    bpjl
    Help: 16
    Rate: 177
    I will find out. This is not my equipment so first I will find out whether it is still under warranty. If so, let the owner take it to the operator and let him be worried. And if not then I will undertake such a fun - http://www.bez-kabli.pl/viewtopic.php?t=52451
  • #10 17300398
    matek451
    Help: 4352
    Rate: 5808
    Is this equipment from T-Mobile? If so, this is not the property of this lady only T-Mobile, the subscription includes installments for him. As long as it is not repaid in accordance with the terms and conditions of the offer, it remains the property of the operator. These routers appeared half a year ago and the bank should be under warranty.
  • #11 17322707
    bpjl
    Help: 16
    Rate: 177
    The router along with the SIM card was guaranteed by T-Mobile. They exchanged and now everything is as it should.
The discussion revolves around accessing advanced configuration settings for the Huawei B528s-23A router. The user initially encounters a quick configuration wizard upon logging into the router's IP address (192.168.8.1) and seeks guidance on accessing more detailed settings, particularly for changing the WiFi password. Responses suggest checking the connection method (WiFi vs. LAN), resetting the router to factory settings if options are limited, and verifying if the router is tied to a specific service provider (T-Mobile). The user later confirms that the router was exchanged by T-Mobile, resolving the configuration issues.
