Why is the value of electric current not included on the battery?
SciTuber 8652 27
Why isn’t a fixed current value printed on a battery instead of just the voltage?
A battery does not have one fixed current rating because the current is determined by the connected circuit’s resistance, while the battery mainly provides voltage [#15768565] A real cell also has internal resistance, so the current changes with the load and with discharge; in an ideal voltage source that internal resistance would be zero, but in a real cell it is not [#15770665] That is why manufacturers usually specify voltage, capacity in Ah/mAh, and sometimes permissible discharge current or discharge curves in a datasheet, rather than a single “current” value [#15768594][#15772348] For disposable cells, capacity is generally the more useful label, because the actual current depends on how the cell is used [#15770026]
  • #1 15768532
    SciTuber
    What is the reason for this? The fact that it is a value that changes when modifying electrical circuits and, unlike voltage, we can not explicitly define it? I make my considerations with direct current.
  • #2 15768565
    goldi74
    Help: 1367
    Rate: 1539
    Current depends on the resistance of the circuit. The battery itself does not produce current only voltage. Current begins to flow only when the battery is loaded with a load.
  • Battery current depends on circuit load resistance
    #3 15768575
    SciTuber
    I understand that as the voltage on the battery is specified equal to 3V, while the current is not necessarily, this is because it can take different values?
    I was prompted to these considerations by the fact that when the nth receiver is connected to a series circuit, the voltage of the source will not change, while in the case of a parallel circuit, the current source intensity will increase....
  • #4 15768585
    goldi74
    Help: 1367
    Rate: 1539
    Read about Ohm's law.
  • #5 15768592
    SciTuber
    I will read. I will take this opportunity to ask one more question. When the nth receiver is connected to a series circuit, according to the rule, will the intensity of the source not change, while the voltage and intensity of the receivers will decrease in direct proportion?
  • Battery current depends on circuit resistance and discharge conditions
    #6 15768594
    Falco76
    Help: 41
    Rate: 148
    On a 3V battery there is no such data, but take a battery and there you will find: voltage V, Ah capacity, and inrush current - this is the current of discharge of the battery under certain conditions, specified by the manufacturer. The current that will flow in the circuit depends on the resistance of the circuit - as a colleague wrote earlier.
    Added after 4 [minutes]:
    Are you asking about the current source or voltage source, or what happens in practice?
  • #7 15768616
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    For the total circuit.
    goldi74 wrote:
    On a side note, what a bunch of nonsense and lameness :cry: .
  • #8 15769571
    tomekm33
    Help: 42
    Rate: 120
    Read, maybe something will brighten up for you: "Ohm's Law"
    There is a voltage on an unloaded battery because.... Voltage is the potential difference, in this case between the two terminals of a battery (actually a cell, but that's a detail). We associate current with flow. If the poles are not loaded or otherwise connected to each other then current does not flow.
  • #9 15770026
    Artur k.
    Help: 1279
    Rate: 1701
    The question is not at all as silly as it might seem. While it indeed makes no sense at all to state the current on disposable cells/batteries, there would be nothing wrong if manufacturers stated the capacity of a new cell as they do in rechargeable batteries. Such information would give some idea of what to expect from such a cell.
  • Battery datasheets may provide capacity, but labeling is inconsistent
    #10 15770304
    tomekm33
    Help: 42
    Rate: 120
    Arthur k. what's right is right, although it is possible to find such information - here is an example . The manufacturer has stated a capacity of 1200 mAh. Ba! There is even datasheet :)
    Only that...
    First - not everyone needs such detailed information (datasheet). After 2 - it would be better if (as you mentioned) at least approximate capacity in mAh was given. After 3 - you probably won't find information for every cell.
  • Print indicative or average capacity on batteries
    #11 15770371
    Artur k.
    Help: 1279
    Rate: 1701
    tomekm33 wrote:
    First - not everyone needs such detailed information (datasheet). After 2 - it would be better if (as you mentioned) at least indicative capacity in mAh was given. After 3 - you probably won't find information for every cell.
    Of course, after all, it would be enough to give, for example, the average capacity on the cell. In most cases, such information is sufficient, and if someone wants to know the details, let him look for a datasheet.
    Well, unfortunately, Varta is one of the few manufacturers that provide such information (and even this is not for every cell). Most don't, and the datasheet is sometimes not easy to get to at all.
  • Battery capacity depends on discharge current and device load
    #12 15770420
    398216 Usunięty
    Help: 3925
    Rate: 9447
    The trouble with this is that the capacity of the battery is closely related to the current that is drawn from it.
    My opinion is that this data is intentionally not available to "mere mortals", because they could misinterpret it and then there would be more trouble than it's worth. Besides - in 90% of cases a given battery model is dedicated to a certain type of receiver - we are talking, of course, about "factory" designs - and for such a receiver it performs properly. Admittedly, it is possible to use an alkaline cell instead of carbon cells (there are still such manufactured) - but for the user it is only better - the equipment will last longer. So the user himself has a choice - whether the cell "usual" and frequent replacement, or alkaline with much higher efficiency and capacity, so replaced less often but more expensively.
    I don't know how it is nowadays, but, for example, in Polish (portable) radios, the recommended type of battery was given - and I even remember that I saw in some manual "estimated operating time" on the recommended cells (which, in total, gave nothing anyway, because at that time there were only batteries of one type available - lousy and pouring.... ;) ).
    I think I still have somewhere a flash (Polish) where the number of flashes on a set of carbon batteries and in comparison - on alkaline batteries was given. On the Polish batteries, these figures did not coincide with reality, because the batteries lasted at most for a few shots....
  • Battery capacity data remains necessary for comparisons
    #13 15770458
    Artur k.
    Help: 1279
    Rate: 1701
    398216 Usunięty wrote:
    The trouble with this is that battery capacity is closely related to the current you draw from it. In my opinion, it is deliberate not to have this data available to "mere mortals", because they could misinterpret it and then it would be more trouble than it's worth.
    Of course, except that the identical situation is with batteries, and on batteries the capacity is given. In my opinion, this does not change anything, and even makes it more difficult - for example, to compare different cells, especially cells from different manufacturers.
    Otherwise - in 90% of cases, a given battery model is dedicated to a specific type of receiver - we are talking, of course, about "factory" designs - and for such a receiver it works properly.
    With this I will not agree, this may have been the case in the past, but not today. Today anyway, most devices are powered by AA or AAA type cells. Even in multimeters where practically from time immemorial reigned 6F22 today already meet AAA precisely because of their incomparably higher capacity than 6F22. There used to be no readily available, cheap and good step-up converter circuits, and assembling a 9V from AAA cells would significantly increase the weight and size of the instrument. Today there is no problem with this, which is why this type of battery is slowly dying out.
    The same way the once very popular 3R12 battery - the so-called flat battery, which was dedicated mainly to flashlights - died out.
    In the past, when, first of all, there was no such variety of cells, there was no point in stating the capacity. However, today I believe that such information would be needed by many people.
  • Internal resistance limits battery current and causes voltage sag
    #14 15770665
  • Battery type, capacity, and quality determine device runtime
    #15 15770982
    398216 Usunięty
    Help: 3925
    Rate: 9447
    Artur k. wrote:
    Identical situation is in the case of batteries
    I think that in the case of car batteries this is necessary - after all, the car manufacturer equips its products with a specific type (capacity, starting current and even size, but that's another matter) of battery - precisely because of the energy requirements of a particular vehicle. As for batteries - the case is similar - if the manufacturer has decided that they are to be AA then you will not put AAA, because it will not contact. And vice versa - You won't put AA in the place provided for AAA because it won't go in. Comparing a bunch of batteries of a given type with each other, you can see quite significant differences in capacity from one type to another - so in some way this is also an indication of the "current appetite" of a given device.
    Of course - old equipment was adapted to the batteries of the time - it is known that those 10 and even more so 20 years ago batteries of the same type as those produced today were of much lower capacity.
    Example: The first electric (battery) alarm clock I bought for myself (I like to sleep...) was adapted for a R-14 battery. Today, at the market you can easily buy a similar one for a AAA battery. The working time of my first alarm clock is a month at the most, and the one from the bazaar - a Chinese one for a modern AAA battery - two - three times as much (with a daily wake-up call). So it's not only the device itself (its current-consuming capacity) that affects the working time, but also the quality of the battery; since the many times smaller AAA present-day can be thus compared to type C.
    http://www.mechatrobot.pl/rodzaje-baterii-oraz-ich-wlasciwosci/
  • #16 15771122
    kortyleski
    Help: 957
    Rate: 3860
    Even if the capacity of batteries was stated, marketers would immediately come up with thousands of ways to measure so that the batteries of a particular manufacturer would be the best. It would be necessary to standardize the measurement from the top down and this will not work on the free market.
  • #17 15771784
    Artur k.
    Help: 1279
    Rate: 1701
    in the case of car batteries this is necessary - after all, the car manufacturer equips its products with a specific type (capacity, starting current and even size, but that's another matter) of battery - precisely because of the energy requirements of a particular vehicle. As for batteries - the case is similar - if the manufacturer has decided that they are to be AA then you will not put AAA, because it will not contact. And vice versa - You will not put AA in the place provided for AAA because it will not go in.
    But rechargeable batteries are not only in cars. After all, there are rechargeable batteries in typical AA and AAA and other sizes. Here, too, the capacity is given, and it varies greatly.
    kortyleski wrote:
    Even if the capacity was given on batteries, marketers would immediately come up with thousands of ways to measure so that the batteries of a particular manufacturer would be the best.
    And that's for sure, except that the possible stretching would be relatively easy to catch by a thinking person. It's exactly the same with rechargeable batteries - it's been known for a long time that in the case of, for example, AA-size NiMH, it's rather rare to find batteries with capacities greater than 2500mAh (typically around 2000-2300mAh, although I once had a Sanyo 2700mAh), if someone quotes a much higher capacity than everyone else then you can immediately sense that something is wrong.
    The problem is different - while in the case of a rechargeable battery it is quite easy to check what capacity it has and possibly prove that it does not hold the declared parameters, an alkaline cell is disposable - once you discharge it to check the capacity, the physical evidence ceases to exist.
  • #18 15771949
    CMS
    Help: 258
    Rate: 2601
    Artur k. wrote:
    the factual evidence ceases to exist.
    And this very fact, I believe, is the main reason why, on "batteries" we have only voltage. And that the batteries from the bunny, or those that used to have such a funny bar to check the "level of charge", last much longer than NONAME's or other "market" batteries, is no news.
    And anyway, the capacity of rechargeable batteries is not everything. For example, my dad's old camera, some Soniak with a 5MPx sensor, on branded 2200mAh "batteries" (probably Sanyo, but I won't give my head) after literally a few photos sucked the cells to zero. I purchased some "industrial" cells (whatever that was supposed to mean) of an unknown brand, with a capacity of 2200mAh, on the volume, and you can easily "snap out" a 512MB card and still rip it to the computer.
    Here's where the Eneloops came from.... And other "serious rechargeable batteries"
    Greetings.
    CMS
  • #19 15772009
    Artur k.
    Help: 1279
    Rate: 1701
    Eee, I think the real reasons are different. What would be wrong if manufacturers quoted the average capacity of a cell of a given type? I'm far from conspiracy theories, but from my observations it seems that some people could realistically lose out on this.
    Do a simple test - buy one AA battery each from, say, 3 different manufacturers - let it be Energizer, Duracell and some cheap ones such as Carrfeour. Measure the short-circuit current of each of them, put it together with the price per unit and draw your conclusions. :)
    CMS wrote:
    Where did the Eneloops come from in the end.... And other "serious rechargeable batteries"
    The Eneloops are about something else - Eneloops and all the new generation have a much smaller capacity than classic NiMH, for that they have a completely different property - much less spontaneous charge loss. That's what this is all about. :) .
  • #20 15772348
    jarek_lnx
    Help: 4198
    Rate: 6126
    Batteries that have a datasheet with specified capacity and internal resistance, as well as discharge characteristics, are offered by many manufacturers. Batteries with datasheets are a separate product line, they usually have "industrial" in the name, an ordinary user who buys batteries in a nearby market is unlikely to get the "industrial" version, but only a regular one, and must be satisfied with the assurances of marketers that they are simply the best.
    I used to do tests and remember that batteries with the highest capacity do not have the lowest internal resistances.
  • #21 15772386
    Artur k.
    Help: 1279
    Rate: 1701
    jarek_lnx wrote:
    An ordinary user who buys batteries at a nearby store is unlikely to get the "industrial" version
    And it depends what nearby store. Not long ago, there were Varta Industrials in a kiosk near me. Interestingly, they were not at all expensive - I think they were 2zl each for AA.
  • #22 15776375
    Zygmunt_mt
    Help: 39
    Rate: 85
    I, for many(maybe decades) years, check the condition of the battery, by briefly measuring the short circuit current. For such a "dictum" once, I had my post deleted "to the trash". And I continue to measure, because I know what, and why, I am doing. As written by Colleagues RitterX and Arthur K , The magnitude of the short circuit current, indicates the internal resistance of the cell(battery). And it is one of the most important parameters, indicating the amount of stored energy. Of course, it must be done with specific and preferably, the same wires, supplying the meter. They can also be Chinese, (these have a resistance, even tens of milliohms) and the instrument then less, loads the cell. It is important that the measurement is very short, so that only the readings, relatively stabilized. Even for used NiMh and NiCd (not Lion ) rechargeable batteries I use this.
  • #23 15776426
    CMS
    Help: 258
    Rate: 2601
    I always did the measurement of Rw (for 18650 cells) on the principle, measuring the voltage of a charged cell "at idle", then measuring the voltage of this cell with a "plugged in" resistor 10Ω 5W, (but I recommend a larger power, because you can burn your fingers), after 5s. after connection. Then I calculated from the formula:
    RW=R(U without load ÷ U under load).
    Till now it worked, but maybe there are better ways.
    Greetings.
    CMS
  • #24 15776495
    Zygmunt_mt
    Help: 39
    Rate: 85
    Well, yes. It certainly gave you a picture to compare the internal resistance, but not the resistance itself in Ω (ohms), directly. Well, because what is according to your way of reasoning RxU. It is Ohm or V/A(ohm) multiplied by V(volt) ? So even if only by looking at the units, right ?
  • #25 15776563
    Artur k.
    Help: 1279
    Rate: 1701
    Zygmunt_mt wrote:
    the size of the short-circuit current, indicates the internal resistance of the cell(battery). And it is one of the most important parameters, indicating the amount of stored energy.
    Not exactly, the value of the short-circuit current, yes it indicates the internal resistance of the cell, but it does not indicate the amount of energy that such a cell can store.
    It is perfectly evident by looking at the characteristics of small batteries. Those with the highest capacities do not necessarily have the highest discharge current. And, after all, the discharge current depends on the internal resistance.
    In fact, one of the colleagues has already mentioned this:
  • #26 15776634
  • #27 15776693
    Artur k.
    Help: 1279
    Rate: 1701
    trymer01 wrote:
    Short-circuit current measurement is actually a current measurement with a load of 0.1 Ohm - that is, a current far greater than the current of normal operation, which calls into question the advisability of such a measurement, in addition, it is usually not healthy for the battery.
    Makes sense, I have long checked the overall condition of cells in this way. Very often we are not able to check a cell by loading it with the nominal current at which it operates in the device, because we simply do not know the value. Measuring the voltage without a load also very often gives very little.
    I know from experience that a new fully operational alkaline AA cell from a reputable manufacturer has a short-circuit current of about 8-9A, while the SEM of the cell is usually about 1.55V. In contrast, a cell that has already worked a little will have about 5-6A while the SEM is around 1.5V - so measuring the SEM does not arouse suspicion, while measuring the current indicates that the cell has already worked a little. In contrast, cells having a short-circuit current of about 2-3A often have a SEM around 1.4V. SEM begins to drop dramatically only at the end of the cell's life, when the short-circuit current itself is already very low. Often the current of 1-1.5A have cells with SEM of about 1.3V, while such cells already practically exhausted with SEM of about 1.1V can still give 500-700mA on a short circuit.
    SEM does not depend linearly on the state of charge of the cell, hence a better method of checking the cells is to measure the short circuit current (provided that we know what values to expect).
    Of course, this is not healthy for the cell, but if such a measurement lasts for a very short time, its effect on the cell is negligible.
    In "field" conditions, we have no other way to check the state of the cell than by measuring the short circuit current. This is because no one carries with them an array of high-power resistors to check the cells. For this universal meter we usually have with us (or at least I have).
    Many times in this way I have also caught brand new, damaged cells - SEM within 1.55V, while the short circuit current barely 1A. I put brand-new cells into the device, and the device does not work, I measure the voltage - it is ok. Well, and what can you think to yourself at this point?
    Also, as you can see, the purpose and sense is there, only that you can not do it mindlessly - you need to know what to expect. Then such a measurement can provide a lot of information.
  • #28 15776735
    Zygmunt_mt
    Help: 39
    Rate: 85
    [quote="Artur k."]
    Not exactly, the value of the short-circuit current yes indicates the internal resistance of the cell, but does not at all indicate the amount of energy that such a cell can store.
    I was mainly concerned with this equation, in which Om =Om multiplied by volts. And this stings and will sting my eyes. It's just that the so-called "titers" or units don't agree, and they should or even must. And capacity depends on many things, maybe even less electrical and more chemical and physical(dimensions). And with your post of 19:52, I agree completely. Greetings
  • Topic summary
    The discussion centers on why electric current values are not specified on batteries, particularly in the context of direct current (DC) applications. Participants explain that current is dependent on the circuit's resistance and load, while batteries provide a fixed voltage. Current only flows when a load is connected, making it variable and context-dependent. Some suggest that manufacturers could provide average capacity ratings for batteries, similar to rechargeable types, to give users a better understanding of performance expectations. The conversation also touches on the internal resistance of batteries, the implications of short-circuit current measurements, and the differences in battery performance across brands and types.
    TL;DR: Only voltage (e.g., 1.5 V) appears on primary cells because “current starts only when a load closes the circuit” [Elektroda, goldi74, post #15768565] Current varies with resistance via Ohm’s law; a 0.5 Ω load can pull 3 A from a AA cell [Varta, Datasheet]. Why it matters: Misreading labels leads to burnt electronics or under-powered designs.
    • Nominal voltage of an alkaline AA cell: 1.5 V ± 0.15 V [IEC, 2021] • Fresh AA short-circuit current: 6–9 A [Duracell, 2023] • Internal resistance (new AA alkaline): ≈0.15 Ω [Varta, Datasheet] • Capacity range AA alkaline: 1800–3000 mAh at 250 mA discharge [IEC, 2021] • Recommended max continuous current for AA alkaline: ≤2 A [Energizer, 2022]
    1. Why don’t battery labels list current?
    A cell delivers whatever current the external circuit demands, limited by its internal resistance. Because that current can vary from microamps to amperes, listing one fixed value would mislead users [Elektroda, goldi74, post #15768565]
    2. What is the difference between a voltage source and a current source?
    A voltage source maintains near-constant voltage while current changes with load. A current source maintains constant current while voltage rises or falls to satisfy Ohm’s law. Real batteries behave as imperfect voltage sources with rising internal resistance during discharge [Anonymous, #15770665].
    3. How does internal resistance affect available current?
    Output current equals battery voltage divided by the sum of load and internal resistance. As internal resistance climbs from 0.15 Ω to 0.5 Ω, the maximum current from a 1.5 V cell drops from 10 A to 3 A [Varta, Datasheet].
    4. Does putting cells in series change current?
    Series connection adds voltages but leaves circuit current equal through every cell; total resistance rises, so current stays limited by the load and combined internal resistances [SciTuber, #15768592].
    5. What happens when loads are added in parallel to one battery?
    Parallel loads share the same voltage; combined current demand rises. The battery must supply the sum of branch currents, which accelerates discharge and increases voltage sag [Elektroda, SciTuber, post #15768575]
    6. How much energy can an AA alkaline store?
    Modern AA alkalines store about 2–3 Wh (≈2000–3000 mAh at 1.1 V average) [IEC, 2021].
    7. How can I check a cell’s health in the field?
    Measure short-circuit current briefly. Healthy AA alkalines show 6–9 A; under 3 A indicates heavy use or damage [Artur k., #15776693].
    8. Is short-circuit testing safe for the battery?
    A sub-second test with thick leads limits heat, yet repeated shorts can dry electrolyte and drop capacity by 10 % per event—avoid on lithium cells [trymer01, #15776634].
    9. Why do high-capacity cells sometimes have higher internal resistance?
    Thicker cathodes increase storage volume but lengthen ion paths, raising resistance. “Batteries with the highest capacity do not have the lowest internal resistances” [jarek_lnx, #15772348].
    10. How do manufacturers specify maximum discharge current?
    Datasheets list continuous and pulse currents—for example, 2 A continuous, 6 A pulse for a Varta Industrial AA—based on 10 % voltage drop limits [Varta, Datasheet].
    11. Why is capacity printed on rechargeables but not on disposables?
    Rechargeables must match charger settings; giving mAh protects safety and warranty. Disposables see wide load profiles and one-time use, so capacity varies and is harder to certify [CMS, #15771949].
    12. What happens if I short a battery?
    Internal resistance limits current, but heat builds fast. Alkaline cells can vent potassium hydroxide at 10 A, while lithium cells may ignite above 15 A—a documented edge-case failure [Anonymous, #15770665].
    13. How-To: Measure internal resistance with a resistor
    1. Measure open-circuit voltage V₀.
    2. Connect known load R (V₀ / I_nom). Measure loaded voltage V₁ after 5 s [CMS, #15776426].
    3. Compute R_int = R × (V₀ − V₁) ⁄ V₁.
    14. Does cold weather cut available current?
    Yes. At −20 °C, internal resistance of alkaline cells triples, slashing current from 6 A to about 2 A [Duracell, 2023].
