Internal Resistance of Average Car Battery: Discharge/Charge & Temperature Dependence
esperoaranos 63129 20
What is the internal resistance of an average car battery when charged or discharged, and how does temperature affect it?
An average lead-acid car battery has an internal resistance of only a few milliohms when charged; a worn battery is typically about 2.5–3 times higher, and the exact value depends on capacity and construction rather than being a single fixed number [#13482614][#13488815] As a rule of thumb, one reply gives about 10 mΩ up to 20 Ah, 5 mΩ for 20–50 Ah, 2 mΩ for 50–100 Ah, 1 mΩ for 100–240 Ah, 0.5 mΩ for 240–500 Ah, and 0.1 mΩ for 500–1000 Ah [#13482614] Another reply states that a fully charged battery is about 3–10 mΩ, and that 0 V at the terminals means the battery is scrap, not a usable battery [#13482479][#13482637] The resistance/impedance also depends on factors like plate surface area, electrode spacing, and other physico-chemical effects, so the best practical estimate is from the manufacturer’s starting current and the expected voltage drop (for example, 100 Ah at 350 A gives about 0.35 V drop) [#13487456][#13488180] The thread does not give a numeric temperature coefficient, only that the value varies with battery condition and other physical factors [#13488180]
  • #1 13482264
    esperoaranos
    Hello. I think I chose the right department. I can't find this information anywhere. Namely:
    What is the internal resistance of the average car battery? Discharged to zero and charged?
    How much does it depend on the battery temperature?
  • #3 13482356
    esperoaranos
    I don't see the answer to my question here.
  • #4 13482372
    Aleksander_01
    Help: 1167
    Rate: 3432
    After all, it can be measured very easily.
  • #5 13482379
    adam158
    Help: 36
    Rate: 232
    internal resistance of the source in this case, the battery should be as low as possible, strive for
    zero, take zero practically at home, because you will not measure it
  • #6 13482479
    vodiczka
    Help: 1185
    Rate: 4311
    Discharged to 0V or to 10.7V? If the voltage at the terminals = 0, it is a scrap and not a battery. The internal resistance will depend on the battery capacity, the higher the resistance, the lower the resistance. As a guide, the internal resistance of a fully charged battery is 3-10 m?
  • #7 13482503
    Aleksander_01
    Help: 1167
    Rate: 3432
    vodiczka wrote:
    Discharged to 0V or to 10.7V? If the voltage at the terminals = 0, it is a scrap and not a battery. The internal resistance will depend on the battery capacity, the higher the resistance, the lower the resistance. As a guide, the internal resistance of a charged battery is 30-100 m?
    So when consuming only 30 A, the voltage drops by 3 V. Interesting? And what about starting, it goes down to minus 6V (for a small starter).
  • #8 13482542
    krau
    Help: 65
    Rate: 126
    I don't want to be malicious, but 1m? = 0.001?
    You got something wrong with your calculations.
  • #9 13482614
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2658
    On average, the internal resistance of a lead-acid battery is:
    10m? for capacities up to 20Ah, 5m? 20-50Ah, 2m? for 50-100Ah, 1m? for 100-240Ah, 0.5m? for 240-500Ah and 0.1m? for 500-1000Ah.
    A used battery has this resistance at least about 2.5-3 times greater.
    U = I * R. e.g. for 100Ah, the starter consumes 350A, so we have a voltage drop of around 0.35V.
  • #10 13482637
    vodiczka
    Help: 1185
    Rate: 4311
    Sorry, actually :cry: It should be 3-10 m?, I have already corrected.
  • #11 13483526
    Aleksander_01
    Help: 1167
    Rate: 3432
    AWESOME, where they taught or teach. I suggest a little bit of study.
  • #12 13483978
  • #13 13484076
    vodiczka
    Help: 1185
    Rate: 4311
    SHOW you how they taught you, I'd like to read what can you accuse my statement? Probably only that I did not indicate that I compare batteries made in exactly the same technology and not any batteries.
  • #14 13484139
    Aleksander_01
    Help: 1167
    Rate: 3432
    Since the battery capacity is related to its internal resistance We write about acid batteries. From a battery, e.g. 50 Ah, you can easily get a battery with a much larger capacity by removing its plates from the housing and immersing it in a much larger amount of acid solution. But his resistance wen. will not change.
    Internal resistance acid battery depends only on the surface of the plates, and the capacity on the amount of acid solution.
    There are 12 V 50 Ah batteries on the market with a starting current of about 1000 A, to achieve this the cells are rolled (surface). There are 1.5 V batteries on the market with the inscription HEVY DUTY - used for toys, motor drives where electricity is required, and LONG LIFE batteries - "long life" used for watches, remote controls, etc.
    I'm not malicious, but seeing someone writing such stupid things is .......... it's a pity to write.
  • #15 13484169
    vodiczka
    Help: 1185
    Rate: 4311
    Only now have YOU GIVEN BODIES, it's funny when you give up writing nonsense and write them yourself. :D
    Where do you think the battery stores its energy? Write the equation of the chemical reactions occurring on the electrodes during the charging and discharging of the battery and you will understand what nonsense you were doing :cry:
    And do not confuse the relationship between the capacity and the internal resistance of the battery with the relationship between the inrush current and the internal resistance of two batteries of the same capacity.
  • #16 13487456
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    But you girls are scratching ...
    The capacity and impedance of the battery depend on many factors, but the surface of the claddings (and this may be larger than the surface that is the product of the length and width, because the structure of the cladding is spatial) is of the greatest importance here - generally batteries with a larger capacity have lower impedances and are able to deliver larger current (and thus have less "internal resistance").
    As it was written earlier in the thread - you can indirectly calculate it from the starting current provided by the manufacturer (according to the manufacturer's conditions, i.e. current expenditure with an acceptable voltage drop).
  • #17 13487500
    vodiczka
    Help: 1185
    Rate: 4311
    But gender :D
    The capacity and impedance of the battery depend on many factors, the surface of the claddings (which may be larger than the product of the length and width, because the cladding structure is spatial) is of the greatest importance.
    Right, only the surface of the cladding cannot "be larger" but "it is always larger". The times when the active surface area of the electrodes was approximately equal to the product of dimensions are long gone.
  • #18 13487550
    Aleksander_01
    Help: 1167
    Rate: 3432
    One could further discuss, but write Vodiczka technically and not "The times when the active surface of the electrodes was equal to the product of dimensions are long gone." Write down how it is done today in acid or similar batteries.
    Compare such aku
    http://allegro.pl/akumulator-volt-zap-sznajder-12v-100ah-760a-i4046543323.html
    http://allegro.pl/akumulator-optima-red-rtc4-2-12v-50ah-swiezy-2013r-i4111564687.html
    The questioner asked a fairly simple question - how to calculate the internal resistance. the battery in question.
    For this, all you need is a resistor, ammeter and voltmeter, and an internal resistance. any voltage source is computable having these three things.
  • #19 13487610
    vodiczka
    Help: 1185
    Rate: 4311
    The questioner asked a fairly simple question - how to calculate internal resistance given the battery.
    You are stubborn and you distort everything in your own way, the questioner asked:
    esperoaranos wrote:
    How much is internal resistance average car battery?
    I am not going to lecture to someone who thinks that the capacity of the battery does not depend on the surface of the electrodes but on the amount of acid:
    Internal resistance lead acid battery depends only from the surface of the plates, and the capacity depends on the amount of acid solution .
    The internal resistance also depends on other factors, e.g. the gap between the electrodes.
    deus.ex.machina he wrote correctly: "The capacity and impedance of the battery depends on many factors, with the surface of the cladding being the most important factor here"
  • #20 13488180
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    It depends on the purpose of the battery - sometimes the spatial structure is not significantly expanded, e.g. for the sake of battery longevity - a lot could be written about it.
    I dare say that the matter is a bit more complicated - yes, you can use the technical method using two different resistors to try to determine the impedance of the battery, but the problem itself is much more complex because to determine the actual impedance you would have to take into account the dynamics of the physicochemical processes taking place in the battery, which is a bit more complex than the treatment of the battery as a static current source.
    As I already wrote - for working use, you can use the starting current specified by the manufacturer, which usually determines the safe from the battery point of view, the duty cycle, the actual battery impedance will usually be even lower, but "using" it may mean irreversible damage to the battery.
  • #21 13488815
    vodiczka
    Help: 1185
    Rate: 4311
    You are right again, but this topic applies to car batteries, and in them there has been a long-standing tendency to increase the capacity and inrush current without increasing the dimensions and weight of the battery, which can only be achieved by expanding the active surface of the electrodes and their tighter packing. The result - the battery is less long-lived than a dozen years ago and, what's worse, it can fall unexpectedly, without signaling its near end by the resistant turning of the starter. :D
The discussion centers on the internal resistance of car batteries, particularly lead-acid types, and its dependence on charge state and temperature. Internal resistance values are provided, indicating that a fully charged battery typically has a resistance ranging from 0.1 to 10 milliohms, depending on its capacity. The conversation highlights that internal resistance increases significantly in used batteries and is influenced by factors such as electrode surface area and the physical structure of the battery. The relationship between battery capacity, internal resistance, and starting current is also explored, emphasizing the complexity of accurately measuring internal resistance due to dynamic physicochemical processes. Various methods for estimating internal resistance are suggested, including using resistors and measuring voltage drops under load.
