Choosing Between Twisted Pair 5e or 6 for Gigabyte Home Network Setup
avatarus 14799 15
Should I use Cat5e or Cat6 cabling for a new gigabit home network, and what should I pay attention to during installation?
Cat5e is enough for gigabit at home over runs well under 100 m, and Cat6 is also a sensible choice if the price difference is small; Cat6A is usually unnecessary unless you simply want to overbuild [#15805837][#15810152][#15806059] The most important thing is routing: keep the network cables away from electrical wiring and do not bundle them in the same channel with power cables [#15805837] If you choose shielded FTP/STP cable, the whole installation should be compatible with grounding, including sockets, patch panels, and active equipment; otherwise UTP is simpler [#15805995] For peace of mind, a small separation from power lines, such as 10–20 cm, was recommended, and home installations with short runs usually work fine even with UTP [#15805995][#15810152]
  • #1 15805170
    avatarus
    Hello, I'm building a house and getting ready to create a network. However, I wonder what twisted pair to do this? 5e is enough or better 6? All devices will be new and prepared for gigabyte networks (NAS / tv / pc)
    Thank you and best regards
  • #2 15805189
    hermes-80
    Help: 1177
    Rate: 743
    The control panel in a cool place (basement as is) - lead the cables away from electric lines, run at least 2 pairs to one point, use UTP 6a cable.
  • #3 15805222
    Ricoh_220
    Help: 464
    Rate: 754
    2 pairs with 1 Gigabit network?
    All the wires are working there, 2 pairs can be used at 100 mega
    As for the category 6 cable, at 25 meters in the block on the 5e cable, my speed dropped to 100 after replacing it with cat 6, the problem ceased.
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
  • #4 15805228
    hermes-80
    Help: 1177
    Rate: 743
    I meant the number of network cables to one end point.
  • #5 15805307
    avatarus
    Ok, that's 6a, but you worried me about this far from the power cables. I wanted to have modular sockets where there are 230v plugs and at the same time rj45 plugs to work full giga, this design will not work?
  • #6 15805321
    Ricoh_220
    Help: 464
    Rate: 754
    You have to make an attempt with the shielded twisted pair and not very long distances can be successful.
    I have seen installations in shared channels and it worked, but such actions should be avoided as much as possible.
  • #7 15805488
    avatarus
    What is the safe distance from the power cable?
  • #9 15805837
    Darom
    Electrician specialist
    Help: 231
    Rate: 588
    For Gigabit transmission at home (distances much less than 100m), a cable of a good company cat. 5e is enough. I recommend brands: Molex, AMP, R&M. Of course, you can put a category 6 twisted pair - today these are not such large price differences. If you have too much money - it can be 6A - the only question is why.
    More important is the issue of close-ups with the wiring of the electrical installation. For the sake of peace of mind, I would suggest using a shielded cable, which has a slightly higher resistance to interference (than the E component) and keeping a small, e.g. 2cm distance. This is not in accordance with the standards, but sufficient at home so that there are no surprises. In any case, the strands cannot be arranged in one bundle with the electric ones. This small gap is more important than using the FTP twisted pair. At home, with UTP cables, I have never had any surprises, which I cannot say about industrial conditions.
    kisses
    - GIFT-
  • #10 15805995
    hermes-80
    Help: 1177
    Rate: 743
    No FTP twisted pair - you need to have all the equipment adapted to grounding - (sockets, patch panels, active equipment) - for safety, I would keep a distance of 10-20 cm. There may or may not be a disruption depending on many factors.
  • #11 15806021
    Darom
    Help: 231
    Rate: 588
    A fair point about the FTP twisted pair. We assume that it will be earthed on at least one side. However, I would not exaggerate with these disturbances at home. As a rule, they are so small that even not keeping a distance will not have bad consequences.
    kisses
    - GIFT-
  • #12 15806059
    hermes-80
    Help: 1177
    Rate: 743
    I would advise you to be safe - what will you do if there are cables under the plaster and you don't know where? UTP cat6 for the fact that it is not much more expensive and you do installations only once in your life because then no one will want to break all the walls.
  • #13 15806103
    Darom
    Help: 231
    Rate: 588
    The advice to be very careful is not bad advice. But I have never encountered any significant disturbances in the home environment. If there is an aggressor in such an environment (from the point of electromagnetic compatibility), the most effective action is its elimination, not "fortifying" the victim. This is different in an industrial setting where it is normal for significant levels of interference to occur.
    kisses
    - GIFT-
  • #14 15809899
    avatarus
    sorry in advance for the stupid question but
    For the 6a or 7 cable do you need special routers that work with these cables? So are some other terminals (compared to the 5e cable).
    And from the electrician's point of view, what do I have to say so that I can prepare the installations for it, earth electrode (the so-called "hoop") and something else?
  • #15 15810152
    jprzedworski
    Help: 758
    Rate: 828
    And I also do not encounter any disturbances in an office environment. A large, historic building, so you can put cables wherever you can, and not where you want. Usually everything goes in common channels with the electrician. A few cables of almost 100 m and there are sometimes problems with length. Wiring - part Cat5e, part Cat6. Zero errors. Switches have statistics for each port so it's easy to check. Installers, theoretically, are right to keep the electrics at bay, but if there are no problems in a large office (over 200 devices), then at home with short cables. Even UTP cat5e will do. And not to bother the electrician with some earth electrodes for the computer network. All electrical sockets are to be earthed, and that is enough.
  • #16 15810215
    zibq
    Help: 83
    Rate: 181
    I would not really "tense". I also thought it would be nice to have Gbit everywhere.
    In practice, a radio is enough for everything, and it's not an AC1200, but an ordinary 300. I connect the cable when I need to transfer a few hundred GB. Everything else, including the NAS and TV, runs on WiFi.
The discussion revolves around the choice between using Category 5e (Cat 5e) and Category 6 (Cat 6) twisted pair cables for a gigabit home network setup. Participants suggest that while Cat 5e is generally sufficient for gigabit transmission over short distances, Cat 6 offers better performance and future-proofing, especially given the minimal price difference. Concerns about electromagnetic interference from nearby power cables are raised, with recommendations for maintaining a distance of at least 2-20 cm and considering shielded twisted pair cables for enhanced protection. The importance of proper installation practices, such as avoiding bundling network cables with electrical wiring, is emphasized. Additionally, questions about the need for specialized routers and grounding requirements for higher category cables are addressed, with a consensus that standard equipment should suffice for home use.
