Renault Clio 4 - 'Check the Uphill Start Help' Dashboard Message: Can I Drive?
Robson30 41835 6
  • #1 15816150
    Robson30
    Hello everyone, I was coming back from the seaside today and in one of the parking lots after stopping for a short rest after starting the car, a message was displayed that worries me a bit (check the uphill start help) I was looking on the internet but I can't find anything, and if this you can drive and how to delete it yourself without visiting the workshop thanks in advance for your answer and best regards.
  • #2 15816483
    genek1000
    Help: 289
    Rate: 1057
    Robson30 wrote:
    and you can drive with it
    No, because the "uphill start aid" does not work.
    - connecting the dignoscope, removing the fault and clearing the error in the ABS.
  • #3 15816530
    Robson30
    And tell me, is it possible to drive with it for a while and why did this message pop up? will it show up from time to time?
    what's the matter, can you enlighten me.
  • #4 15816590
    genek1000
    Help: 289
    Rate: 1057
    No one will give you an answer like "yes you can drive" or "no, you can't drive" without knowing what is the cause of the error, to which the counter responds with the message "check the uphill start aid". The rule is that if the yellow light is on - then you should go to the service - you can on wheels. If the red light is on - it is strongly discouraged to drive the vehicle - you should call assistance. With a yellow indicator light, you can also call assistance, justifying it with your fear of further driving because you do not know what may happen.
  • #5 15816873
    Robson30
    Hello, so I will say yes, the yellow light is on, such a key and after firing from the card, after 2 seconds, it lights up and this message pops up, this is the counter where the main one, where the speedometer and tachometer, in my opinion, it may be an electronic fault, not a mechanical one, in your opinion?
  • #6 15816882
    akceptuję
    Rate: 10
    You can drive
    Moderated By CameR:
    The post adds nothing to the thread. Colleague's claim is not supported by any substantive conclusion.
    Reg. 3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #7 15818816
    genek1000
    Help: 289
    Rate: 1057
    I think it may be a mechanical/electrical fault :cry: You won't connect a diagnoscope with good service, you won't find out :|
The discussion revolves around a dashboard message in a Renault Clio 4 indicating "check the uphill start help." Users express concerns about whether it is safe to drive with this warning. Responses indicate that if the yellow light is illuminated, driving is generally permissible, but it is advisable to seek service to diagnose the issue. If the red light appears, driving is strongly discouraged. The message may stem from either a mechanical or electrical fault, and connecting a diagnostic tool is recommended for accurate troubleshooting.
