BFT Thalia - Connection of light barriers, control unit installation
warczyna 9387 1
  • #1 15826533
    warczyna
    Hi. How do I properly connect one pair of photocells to this control panel? Currently I have power under 50 and 51, while I have signal between 70 and 72. I have removed the jumper between 70 and 72, the rest of the jumpers unchanged 70-71, 70-74. I have a PHOT message after commissioning. When I set the panel language, motor type etc at autoset the relays are heard and KO message appears. Please help me to get this control panel up and running.
  • #2 15831974
    Marek J.
    Help: 526
    Rate: 951
    Thalia is quite complicated for the layman.... You need to read the manual carefully. Ensure that you have the PRESET settings correct, and that you have the SAFE 1 photocell operation settings correctly set in LOGIC- SAFETY INPUTS CONFIGURATION.
