Reassembling JIABEN FA7-10/2 Drill Switch: Locating Spring Placement and Clutch Issues
Brivido 17907 4
  • #1 15880763
    Brivido
    Help: 226
    Rate: 428
    I have such an impact hammer. Currently, the only thing that works in it is forging. But the switch is bridged. How to assemble it? Type FA7-10 / 2, two springs fell out when I dismantled and I can't find their place in any way.
    In addition, the clutch is probably damaged. Feel it jump, even when I turn the head with my hand. When it was operational, you could easily turn the whole mechanism.
  • #2 16007893
    Brivido
    Help: 226
    Rate: 428
    OK, I already know how it should be assembled. I have just recently fallen a second similar hammer. Obviously, the dust on the switch causes the contacts to conduct poorly, they heat up and stick together in the plastic part. I do not see to buy one anywhere in normal money. Perhaps they will match these tiny parts from some other similar switch.
  • #3 16016281
    Brivido
    Help: 226
    Rate: 428
    Unfortunately, however, I still do not know how these springs should be arranged, so that by pressing the button the plate under the springs goes up and presses the contacts?
    I bought a second similar to have these small parts for replacement and I think I will buy another one and cut the side wall in it to check how they sit at the factory.
    Reassembling JIABEN FA7-10/2 Drill Switch: Locating Spring Placement and Clutch Issues Reassembling JIABEN FA7-10/2 Drill Switch: Locating Spring Placement and Clutch Issues
  • #4 16032974
    Brivido
    Help: 226
    Rate: 428
    Riddle solved, it was one of the options on my mind, but it was hard to assume. I will try.
    The switch normally costs about PLN 50, this model is ~ PLN 12, from which you can take parts to repair the original one.
  • #5 20384085
    gulson
    System Administrator
    Help: 148
    Rate: 6025
    Report: Easy to fixed need to open the pin of the switch JIABEN FA7-10 where is the big Wellow button where it the 2 long spring 👍and fixed gently the 2 sort spring and press it back
