LED Strip Issue: 3m (180 Diodes), 4 Sections, 12V 1.4A Power Adapter - Two Sections Not Working
Arek1255 21663 8
  • #1 15884200
    Arek1255
    Rate: 8
    I have a problem with a 3m LED strip (180 diodes). I divided it into 4 equal sections, each connected in series with a 2x0.5mm² cable. After a few months, it turned out that two episodes suddenly stopped working. I use a 12V 1.4A power adapter
  • #2 15884236
    zbychmg
    Help: 183
    Rate: 159
    So you had 60 modules of 3 leds (each module 5cm long).
    4 equal pieces of 15 modules.
    each module (3 LEDs + resistor) is powered in parallel.
    If one section consisting of a dozen or so modules is not lit, then check
    is there voltage to it, maybe a cold solder ... sometimes a led or a resistor will fail in one module, but for all modules to fail you would have to connect a higher voltage.
    Check that the power supply has 12V output
  • #3 15884426
    Arek1255
    Rate: 8
    I corrected the contacts of the wire and tape once again with a soldering iron, but now they shine weaker, as if there was a voltage drop :/
  • #4 15884997
    e-sparks
    Electrician specialist
    Help: 77
    Rate: 216
    Arek1255 wrote:
    3m LED strip (180 diodes). I divided it into 4 equal parts
    zbychmg wrote:
    So you had 50 modules of 3 LEDs (each module 5cm long).
    It cannot be divided into 4 equal pieces.
    :cry: Some alternative math?
    180/3=60 modules
    60/4=15 modules per section
    180/4=45 modules
    Or maybe I'm counting something wrong, or I slept through important night shifts?
  • #5 15885384
    zbychmg
    Help: 183
    Rate: 159
    Thanks to e-sparks...
    Well, actually, if the sun was still shining, I could explain that I was warmed up....
    The night shift was too strong...
    I fixed it, although I don't want to, but I have to...
    Added after 11 [minutes]:
    Maybe try cleaning the next solder contacts and connect the wires there,
    or maybe replace the wires, I once bought such "copper" wires that the magnet attracted :)
  • #6 15885474
    HD-VIDEO
    Help: 1263
    Rate: 1876
    Arek1255 wrote:
    4 sections, each connected in series with a cable
    And why in series, the tapes are probably 12V
  • #7 15885475
    zbychmg
    Help: 183
    Rate: 159
    Unless you connect the first module from the power supply, and from the end of this module the next module, as you described it in series, then the last module will actually have a lower voltage.
    In this case, supply power to the last module with additional wires.
    Or power 4 sections from the inside. If that doesn't help, bypass the power supply to the sections
    parallel wire 0.5mm2
    With one-sided power supply of a 5-meter tape (9W/m). The voltage drop on the copper tracks reached 1.5V V (I measured the voltage at the beginning of the tape and at its end).
    They probably save on copper and the resistance of the power supply paths of individual modules is too high in relation to the supply current.
    You did not specify the power of the W/m ruler and the distance from the power supply and between the sections.
    0.5 mm2 wire is approx. 0.1 Ohm per meter. at a distance of 2m, it will be about 0.4 Ohm
    If you can, take a meter and measure the voltage on the power supply of individual sections,
    this is the best way to find the cause.....
    a_noob
    Help: 14
    Rate: 447
    If a few months were shining well, then the resistance of the tracks in the tapes and wires did not suddenly increase?
    @Arek1255 solder the wire between the last glowing and the first unlit section of the tape to the next pads, 3 diodes into the tapes.
  • #9 15924408
    Arek1255
    Rate: 8
    Problem solved. Thank you for your help. I close the topic.
✨ A user reported an issue with a 3m LED strip (180 diodes) divided into four sections, where two sections stopped working after a few months. The LED modules are powered in parallel, and troubleshooting suggestions included checking for voltage at the non-working sections, inspecting for cold solder joints, and ensuring the power supply outputs the correct 12V. The user attempted to fix the connections but experienced a voltage drop, leading to dimmer lights. Further advice included powering the sections in parallel to mitigate voltage drop issues and measuring resistance in the wiring. The problem was eventually resolved after following the community's suggestions.
