Black Screen on Eizo FS2434 Monitor Post-HDMI Connection to Asrock H61M-GE Motherboard
Clams Casino 24258 9
Why does my Eizo FS2434 show the motherboard splash screen and then turn black when connected by HDMI to an ASRock H61M-GE with Intel integrated graphics, while the TV works normally?
The monitor is likely not faulty; the PC is sending the desktop to the wrong display mode, so the Eizo is acting as an extended/secondary screen and shows a black desktop or wallpaper instead of the main image [#15965814][#15966185] Open Windows display settings and set the Eizo as the main screen, or switch the display mode to clone/mirror so both the monitor and TV show the same picture [#15965814][#15966722] You can also try the Windows+P shortcut to change the projection mode quickly [#15966185] The thread starter confirmed that after changing from extended desktop to cloning, everything worked normally [#15966722]
  • #1 15965533
    Clams Casino
    Rate: 19
    Hello. I decided to connect the TV to the computer.
    After connecting only the HDMI cable, only the start screen of the motherboard appears and after a while the entire image is black on the monitor screen. When I connect the HDMI cable to the TV, the image from the computer is displayed normally on it, and the monitor shows a black screen all the time. Is the cause of the motherboard fault or is there a missing driver? I will add that I have the latest Intel drivers for the integrated.
    My specification:
    Eizo FS2434 monitor
    i3 3220.
    Motherboard Asrock H61M-GE
    Ram 2x4GB Kingston
    Windows 7
  • #2 15965548
    MDD
    Help: 179
    Rate: 545
    What computer system.
  • #3 15965679
    Clams Casino
    Rate: 19
    Mam Windows 7 Ultimate .
  • #4 15965811
  • #5 15965814
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Take an interest in the display settings under Windows and set there which screen is to be the main screen and what is to be displayed on the secondary screen.
    It is also worth looking at the software that came with the graphics card.
  • #6 15966185
    310artur
    Help: 980
    Rate: 670
    See if the "windows" + "p" key combination doesn't give you what you need.
  • #7 15966458
    Clams Casino
    Rate: 19
    Aseri15, the monitor does not go to sleep. I forgot to write that this black screen is my wallpaper because I don't have a registered system. In addition to the "black wallpaper" there is information that the system is not original and sometimes a cursor appears.
    Kolobos, the monitor is set as the main screen, and the TV as the second, I use the integrated today and I have the latest drivers.
  • #8 15966722
    310artur
    Help: 980
    Rate: 670
    Well that's all the extended desktop game. What would be on it? It's to the left or right of the home screen. If you move your mouse over it, it's on it...
    Set screen mirroring to be the same on both.
  • #9 15967076
  • #10 15967265
    Clams Casino
    Rate: 19
    Thank you very much everyone for your help, the desktop was extended, I did the cloning and everything is as it should be.
The discussion revolves around an issue with an Eizo FS2434 monitor displaying a black screen after connecting it via HDMI to an Asrock H61M-GE motherboard. The user reports that while the motherboard's start screen appears, the monitor subsequently shows a black screen, whereas the TV connected via HDMI displays the computer's output correctly. Responses suggest checking the monitor's sleep mode, display settings in Windows, and ensuring the monitor is set as the main display. The user later confirms that the issue was resolved by cloning the desktop, allowing both the monitor and TV to display the same output.
