What are they caused by and how to eliminate crackles in bluetooth headphones
stoppaleniu 12198 18
Why do my Bluetooth headphones crackle intermittently when used with an amplifier and transmitter, and how can I eliminate the problem?
The most likely cause is a faulty or poorly matched Bluetooth transmitter, not the amplifier or the headphones themselves [#15978722] The problem persisted on the amplifier’s headphone, pre-out, and rec-out outputs, and even when the transmitter was connected to other audio sources, which points back to the BTT009 transmitter [#15976672][#15978609][#15978722] The practical fix is to replace the transmitter under warranty and test another unit [#15978722] When choosing a replacement, check the headphones’ supported Bluetooth/A2DP versions and buy a transmitter that matches those protocols; the headphones support BT 3.0, A2DP 1.3, AVRCP 1.5, HFP 1.6 and HSP 1.2 [#15978731][#15978869] If you test again, also disable Bluetooth on nearby phone/laptop devices so they do not interfere with the link [#15980320]
  • #1 15965827
    stoppaleniu
    Good morning. I have the following problem: I connected the XX.Y BTT009 Bluetooth transmitter to the Denon PMA-720 ae amplifier via the headphone output. This set was designed to transmit sound to the JBL Synchros E50BT bluetooth headphones. When listening to music every few minutes at irregular intervals, the signal is disturbed (something cracks, hisses, etc.), after a while everything returns to normal, and after a few minutes the signal breaks down again. The distance between the headphones and the transmitter is usually about 2m. When the headphones are connected to a phone or laptop, the problem does not occur. What could be the cause of this problem and how to eliminate it. Thank you very much in advance for your help
  • #2 15965847
    Polon_us
    Help: 1184
    Rate: 1280
    If there is a Wifi network at home, change its broadcasting channel, this usually helps.
    It's best to switch to channel 1 or 11.
  • #3 15965858
    stoppaleniu
    From what I can see, I have channel 11 set, I'm about to change to 1 and see if it helps
    Unfortunately, it didn't help, I checked on several different channels
  • #4 15966555
    simhak
    Help: 109
    Rate: 336
    Are these crackling sounds also heard when silence or a single monotonous signal is transmitted?
  • #5 15966860
    stoppaleniu
    NO. When there is silence, there are no crackles.
  • #6 15974523
    Polon_us
    Help: 1184
    Rate: 1280
    Could a colleague connect these headphones to the "Pre-out" of the amplifier - for testing purposes?
    It is true that it is a 2xCINCH output, but it should not be a problem.
  • #7 15974586
    stoppaleniu
    Of course I can, I'll try it right now
    Added after 5 [minutes]:
    On the "Pre-out" output, the headphones work but very quietly and the sound is not clear
  • Using PRE-OUT or REC-OUT for headphone connection
    #8 15975862
    Polon_us
    Help: 1184
    Rate: 1280
    Hmm, I don't think the crackling problem was present when connected to this "Pre-Out" output.
    Hmm, the signal level on this output depends on the position of the amplifier's volume potentiometer.
    Have you tried changing the volume?
    The speakers can always be turned off.
    Theoretically, you could also use the "REC-OUT" output.
    The difference between this output and the "PRE-OUT" is that the signal level on the "REC-OUT" is independent of the volume setting on the amplifier.
    Also, it can be used provided that the headphones have their own volume control.
  • #9 15975871
    stoppaleniu
    I tried increasing the volume on the pre-out, but at almost maximum volume, the sound is barely audible. Headphones have their own volume control so I will try to connect to the rec-out output
  • #10 15976672
    stoppaleniu
    I tried the operation of the headphones on the rec-out output, it works fine, but after a few minutes the interference also appeared
  • Mains interference suspected; isolate with alternate outlet tests
    #11 15976823
    Polon_us
    Help: 1184
    Rate: 1280
    Hmm...
    This makes me wonder...
    The only difference is that the Denon uses the mains power directly, and the above-mentioned devices do not.
    Who knows, maybe it's mains-borne interference.
    Maybe the BT transmitter wakes up for some reason?
    Maybe a colleague will check the suggestions below and answer them;
    Does the socket where the Denon is connected have a ground pin?
    Is the amplifier powered by a power strip with some sort of noise filter?
    Can a friend do a test with the amplifier connected to a different socket?
    Could a colleague make a test by connecting these headphones to another mains-powered device, e.g. a TV?
    The amplifier has a separate ground terminal on the rear housing. Is it connected to ground? Please try it.
    Can there be any device in the installation in the apartment / house that periodically turns on / off?
    Does your friend have any LED or fluorescent lights? If so, please turn them off for a test and check the operation of the headphones.
    Was the amp gain turned to "0" with this test?
    If not, please check it out :)
  • Test Bluetooth range for compatibility-related crackles
    #12 15977088
    zmyslonyy
    Help: 69
    Rate: 97
    It is probably a dysfunction resulting from the incomplete compatibility of different Bluetooth versions. I have a similar situation with a phone and a speakerphone in the car. The range decreases to a dozen or so cm and then it's OK. As soon as they move away, there are crackles, noises, etc.
    I propose to do a test by reducing the distance between the transmitter and the headphones and whether the situation improves or does not have any effect.
  • Bluetooth version incompatibility suspected after interference tests
    #13 15977108
    stoppaleniu
    Does the socket where the Denon is connected have a ground pin? Yes, but generally in the entire home network I do not have grounding, only phase and zero
    Is the amplifier powered by a power strip with some sort of noise filter? Yes
    Can a friend do a test with the amplifier connected to a different socket? Tried, no improvement
    Could a colleague make a test by connecting these headphones to another mains-powered device, e.g. a TV? I'll check tomorrow as I don't have a working TV right now
    The amplifier has a separate ground terminal on the rear housing. Is it connected to ground? Please try it. How to try? What's going up there?
    Can there be any device in the installation in the apartment / house that periodically turns on / off? NO
    Does your friend have any LED or fluorescent lights? If so, please turn them off for a test and check the operation of the headphones. I have and after disconnecting from the power supply, I have not observed any interference yet, but I will write after longer tests
    I also tried connecting to an external sound card in a computer powered by usb.
    However, after prolonged listening, the interference also occurs with the LED lighting disconnected
    Interference is in the form of crackling sounds with very short but frequent pauses in sound reproduction (approximately 0.5 seconds - 1 second)
    This is a possible reason because the transmitter has bluetooth version 2.1 and the headphones have 4, but after getting closer (about 10 cm from the transmitter) the interference also occurred after a few minutes.
  • #14 15978543
    Polon_us
    Help: 1184
    Rate: 1280
    Hmm, one thing came over me...
    Was this BTT009 transmitter used in these trials?
  • #15 15978609
    stoppaleniu
    No, because both the laptop and the phone have their own bluetooth
    Added after 16 [minutes]:
    I connected the transmitter to the mp3 and the phone and the interference also occurred. Could it be that the transmitter is faulty?
    Polon_us
    Help: 1184
    Rate: 1280
    That's what I just realized.
    I was going to suggest it.
    That's what it looks like.
    If a friend has the opportunity to exchange for another, I would suggest doing so.
    Please check what BT version your headphones have, as well as what protocol they support.
    And from this angle find the right transmitter.
  • #17 15978731
    stoppaleniu
    I will try to return the transmitter under warranty and buy another one. I consider the matter closed for now. thank you very much everyone for your help
    Added after 6 [minutes]:
    And one more question. This headphones support BT: 3.0, A2DP v1.3,AVRCP v1.5, HFP v1.6, HSP v1.2 The old transmitter has Bluetooth 2.1+EDR, A2DP, AVRCP. What parameters should the new one have? BT 3.0 or later?
  • #18 15978869
    Polon_us
    Help: 1184
    Rate: 1280
    I would approach this issue in a different way.
    A colleague is sure that the headphones work with the phone and laptop. You can check which versions of BT and AVDP they have installed.
    And from this angle I would look for a suitable transmitter.
    This, in my opinion, is the best solution.
    Who knows, maybe the current transmitter meets the requirements and is simply damaged.
  • #19 15980320
    Polon_us
    Help: 1184
    Rate: 1280
    I don't know at what stage my friend is with this transmitter, but one more thing came to me ...
    I've had a "late start" lately :(
    Question - were the headphones + transmitter - phone and / or laptop turned on during the tests with the amplifier?
    If so, did they have BT enabled?
    If so, could a colleague do another test?
    It would consist in temporarily disabling the BT function on both the phone and the laptop.
    After that, the colleague would test the operation of the transmitter connected to the amplifier again.
    Here I want to make sure that the headphones were not interfered with by these devices.
The discussion revolves around crackling and hissing sounds experienced when using JBL Synchros E50BT Bluetooth headphones connected to a Denon PMA-720 AE amplifier via a XX.Y BTT009 Bluetooth transmitter. Users suggest potential causes such as Wi-Fi interference, Bluetooth version compatibility issues, and grounding problems. Various troubleshooting steps are proposed, including changing Wi-Fi channels, testing different amplifier outputs (Pre-out and Rec-out), and checking for mains-borne interference. Ultimately, the possibility of a faulty transmitter is raised, leading to the recommendation of returning it under warranty and seeking a compatible replacement with Bluetooth 3.0 or later.
