JBL E45BT Wireless Headphones: Experiencing Digital Squeak and Noise Instead of Music
sebidino 6573 5
  • #1 17133032
    sebidino
    I have JBL E45BT wireless headphones.
    They connect to the phone without any problem, the control (volume, play, stop) works without any problem.
    On the other hand, when you play the music, you only hear a digital squeak and noise - there is no music.
    Headphones on the cable are working normally.
    What can I do in this situation?
    There is no warranty - the headphones are about a year old.
    best regards
  • #2 17133200
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    You need to check if the headphones are working properly with another phone. What format was this .flac music in? Wired headphones work properly because they are not limited in any way, otherwise it is with wireless headphones where the transfer between devices is limited to about 3 Mb / s and the Bluetooth 4 version even less due to energy savings where the transfer speed is even lower.
  • #3 17133212
    sebidino
    The problem is the same with every phone - digital noise and squeaks (when the music is stopped, the noise disappears)
    Music is mp3, spotify, youtube (same everywhere)
  • #4 17133281
    Freddy
    Help: 1394
    Rate: 2821
    The BlueTooth receiver in the headphones may be damaged.
    Why is not there? After all, there should be a guarantee, and if not a guarantee, if you have a receipt, of course :)
  • #5 17133298
    sebidino
    Unfortunately, the proof of purchase is lost.
    I noticed that when you turn the headphones up to 100% you can hear a "fart" to the rhythm of the bass
  • #6 17133342
    Freddy
    Help: 1394
    Rate: 2821
    Signal too strong - distortion.
