Bosch WAE24160PL / 30 Maxx6 - error F21 after replacing brushes
romanbig 10719 6
  • #1 16408298
    romanbig
    After replacing the brushes, the F21 standard error appeared as usual. After many hours of trying to reset it, the washing machine still does not respond. Only the indicator lights in the vertical spin speed reduction display. I tried the 6 o'clock knob holding the spin reduction button then at 7 and nothing. Maybe there are other ways?
  • #2 16408327
    ALIBABA I
    Help: 223
    Rate: 537
    Damn, there is some myk with reset I had a similar problem I will try to send you a deterrent today or tomorrow
  • #3 16408345
    mrhari
    Help: 835
    Rate: 3239
    Maybe this washing machine has its own E-Nr.
  • #4 16408449
    widaw
    Help: 21
    Rate: 173
    Personally, I have not encountered this error. I was apparently a bit lucky.
    in my notes I have this procedure with a plug from a power socket.
    Unplug the washing machine, turn the knob clockwise (6 o'clock - rinsing). Touch and hold the spin button, Keep the plug in the power socket without releasing the buttons, turn the knob to spin.
  • #5 16408457
    romanbig
    The washing machine definitely has its E-No., but I can't check it now. But tomorrow till noon? I will write and thanks for your interest.
    Edit : Added after 16 [hours] 47 [minutes]: :arrow:
    E-washing machine number WAE24160EN / 30
  • #6 16409605
    mrhari
    Help: 835
    Rate: 3239
    You turn off the washing machine and close the door.
    Program selector at position 8 (6 o'clock) and when the led / display will light up then you press and hold the spin reduction and the selector rotates one position clockwise
  • #7 16423958
    romanbig
    Sorry, I didn't say a word, but it was because of my urgent departure. I tried your advice several times, but it didn't work. Maybe it took a little longer ... The wife did not want to wait anymore and in this way we have a new washing machine. Thank you for your interest.
The discussion revolves around the Bosch WAE24160PL / 30 Maxx6 washing machine, which displays the F21 error after the user replaced the brushes. Despite multiple attempts to reset the machine using various knob and button combinations, the issue persists, with only the spin speed reduction indicator lights functioning. Several users suggest different reset procedures, including unplugging the machine and manipulating the program selector and spin button. The original poster later indicates that they were unable to resolve the issue and opted for a new washing machine instead.
