  • #1 16004415
    grabos92
    unfortunately, I noticed the lack of a knob on the radiator, so I can not regulate the temperature on it and it is turned to the max. I would like to ask what I can do in such a situation. Do I have to replace the entire valve (rather impossible due to the heating season), or maybe a head or any knob can be mounted on it to reduce heat and, at the same time, bills.
    Thank you in advance for your help and best regards.
    Broken knob on the heater Broken knob on the heater
    sanfran
    Help: 955
    Rate: 2975
    A thermostatic head can be installed.
    Take some photos, preferably with a ruler, and go with the photos to the store that sells these things. The seller will help you choose the right part.
    By the way, it doesn't look like anything broken there, it's just unscrewed there.
    Sometimes you can open and close the valve using such a plastic cap:
    andrzej lukaszewicz
    Help: 622
    Rate: 2107
    This is good advice. Measure the thread diameters (it can be, for example, M28, 30) and take photos from the bottom and top (the markings on the valve body are important - designation of the make / type of the head) and chase to the store (s).
  • #4 16017881
    Rebal
    grabos92 wrote:
    unfortunately, I noticed the lack of a knob next to the radiator, so I cannot regulate the temperature on it
    Since replacing a compatible valve is not an option, I suggest adjusting some pliers. I know that the first better pliers may not grip, but it will definitely grab some smaller serrated Knipex key.
    Moderated By ROBSON33:
    Please don't write nonsense. If a colleague does not know how a given valve is built, please do not comment.
    I will reward the next such statement with a Warning.
  • #5 16018660
    sanfran
    Help: 955
    Rate: 2975
    Buddy Rebal, with a valve like in the picture, you can pick your nose with pliers. I recommend that you get to know how such a valve works and only then give advice.
  • #6 16018669
  • #7 16018721
✨ The discussion revolves around a broken knob on a radiator, preventing temperature regulation. Users suggest installing a thermostatic head, emphasizing the importance of measuring thread diameters (e.g., M28, M30) and taking photos of the valve for accurate part selection. One user mentions that the valve is a Danfoss RTD model with a typical M30x1.5 thread, indicating that a compatible thermostatic head can be fitted. There are also suggestions to use pliers to adjust the valve, although this method is debated regarding its effectiveness. Overall, the consensus is to seek a replacement head rather than replacing the entire valve during the heating season.
