Adjusting Constantly Heating Thermostat & Removing Danfoss Valve Head
parart 107049 8
  • #1 7408712
    parart
    Rate: 23
    Hello!
    I have a thermostat that heats all the time (after adjustment by a specialist). Unfortunately, I did not see how it got to him and regulated. I am asking for help, how to remove the head and adjust the thermostat? I present everything in the photo.
    Adjusting Constantly Heating Thermostat & Removing Danfoss Valve Head Adjusting Constantly Heating Thermostat & Removing Danfoss Valve Head
  • #2 7408830
    serwisant73
    Help: 188
    Rate: 1260
    There is a large nut on the side of the valve. If you unscrew it, the head will come off the valve together with this nut. On the valve, around the pin that presses the head in, there is a profiled ring. If you look at it, you will notice stamped numbers on it. , you can adjust the flow by turning it. This is called crisscrossing.
  • #3 7410866
    parart
    Rate: 23
    You mean the nut that I marked in the photo? I want to make sure because I do not want to flood the apartment if unscrewing it would lead to a leak from the central :) . However, as for the scale, it is at a minimum and the circulation is not interrupted (the radiator heats up non-stop).
  • #4 7410941
    krisi3
    Help: 26
    Rate: 187
    Go ahead, you can unscrew it, nothing will happen, as a colleague wrote above, you have adjustment behind the nut.
    this is what it looks like after removing the head.
  • #5 7412504
    serwisant73
    Help: 188
    Rate: 1260
    Exactly as in the photo.
  • #6 7415308
    parart
    Rate: 23
    Thank you for your help. The directions were accurate and helpful. I consider the thread closed. greetings
  • #7 16305282
    wengi
    I have a similar problem with the Junkers head. The radiator, despite turning off, still heats up to the maximum.
    I attach photos of the valve with the head. How to disassemble this thermostat ?? Can I act as described above ??
    Thanks for the advice
  • Radiator heating indicates valve blockage or thermostat head failure
    #8 16305598
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    If the radiator heats up - despite turning off the thermostat, it is not a case of flaring, but a malfunction of the thermostat. Maybe some debris got into the valve and prevents it from closing completely (after removing the head, just apply the N-position casing for 15 minutes, for a greater flow to rinse the valve, and then restore the casing to the previous value). If it does not help - a head defect. This metal bellows may be damaged, in which there is gas which expands due to heat (or vaporizing liquid) and when it expands, it closes the plug. If this bellows was perforated, the thermostat will never work (the head must be replaced, or at least this bellows). Contrary to appearances, these heads can be dismantled. Maybe there is damage in the head plug (it is a material), so it does not press the valve needle. You will probably need to buy a new head. Regarding post # 2, the encroachment regulates the max. heating medium flow, but it does not affect the thermostat (the problem in post # 1 is also on the side of the head, not the crossover). Maybe it was worn carelessly?
  • Testing thermostat head versus clogged radiator valve
    #9 16306288
    Sstalone
    Help: 72
    Rate: 398
    Zbigniew Rusek wrote:
    If the radiator heats up - despite turning off the thermostat, it is not a case of flaring, but a malfunction of the thermostat. Maybe some debris got into the valve and prevents it from closing completely (after removing the head, it is enough to cover the valve for 15 minutes in the N position, for a greater flow to rinse the valve, and then restore the crystallization to the previous value). If it does not help - a head defect.
    Not only can it be debris, I do not know the structure of the Junkers valve, but the spring in the Hertz valve may get blocked due to the accumulation of sediment. It would be best to screw the mushroom on the valve, as then the valve closes, it is the head's fault, if not, the valve's fault, if someone likes to play, he should unscrew the valve and unscrew it, more than once it is enough to clean it to resuscitate it.
The discussion revolves around troubleshooting a constantly heating thermostat and the process of removing the Danfoss valve head for adjustment. Users provide guidance on unscrewing a large nut on the side of the valve to detach the head, which allows access to an adjustment mechanism for regulating flow. Concerns about potential leaks during the process are addressed, with reassurance that unscrewing the nut will not cause flooding. Additionally, a user with a similar issue regarding a Junkers head describes their radiator heating despite the thermostat being turned off, suggesting possible debris blockage or a malfunction in the thermostat's bellows. Recommendations include cleaning the valve and considering head replacement if issues persist.
