Identifying German-Made Bosch Washing Machine Models with Removable Drums and Replaceable Bearings
mmstan 67956 15
Which Bosch washing machine series and models are made in Germany and still have a removable drum with replaceable bearings?
There is no reliable thread-based list of Bosch models that are both made in Germany and have a removable drum with replaceable bearings; the German-made WAW series is reported as non-dismantlable, while the clearly repairable series in the thread are WAE and WLG, but they are listed as Poland and Russia, not Germany [#16014159][#17472775] The most practical advice is to check the Bosch spare-parts diagram for each exact model: if the front and rear tub parts and the bearings are shown separately, the bearings are replaceable; if not, the tub is glued or the bearings are integrated [#17472775] Using that rule, WAE24240PL.B3 is shown with separate tub parts and bearings, while WAW24740PL/12 is shown as glued [#17472775] WAN is inconsistent in the thread: one post says it was produced in Poland and not dismantlable, but a later update says WAN bearings are fully interchangeable [#16860633][#17602137] For slim models, Bosch confirmed WLT and WLK are produced in Russia and have a dismantlable washing unit, so they are repairable but not German-made [#17037905]
  • #1 16013035
    mmstan
    Rate: 50
    Good morning
    I am planning to buy a new washing machine. A few years ago I was working on this topic. The choice then fell on Bosch, recommended on the forum made in Germany. The washing machine works until today. For now (knock on) there are no problems with it.
    What series and models are made in Germany? Which have a removable drum and replaceable bearings? If someone had a list, I would be very grateful.
  • #2 16013231
    hessto
    Help: 10
    Rate: 79
    Germany Bosch, some model, for example, WAW, but all of them cannot be dismantled.
    And the WAE Polska model is all whitened.
    And the new WAN model, I do not know, but I think the news is that it can be dismantled.
    The new Bosch ...
    Series 6 WAT24340PL 8kg, Steel drum + Plastic threshold, 1200 rpm
    Series 6 WLT24460PL 6.5 kg Steel drum + Plastic threshold, 1200 rpm
    Series 6 WLK24240PL 6kg, Steel drum + Plastic threshold, 1200 rpm
    Series 4 WAN24240PL 7kg, Steel Drum + Steel Threshold, 1200rpm
    Series 4 WAN2426KPL 7kg, Steel Drum + Steel Threshold, 1200rpm
    Series 4 WAN20140PL 7kg, Steel Drum + Steel Threshold, 1000rpm and no Prewash.
  • #3 16013253
    mmstan
    Rate: 50
    And the WAQ line?
    However, I would prefer made in Germany.
  • #4 16014159
    hessto
    Help: 10
    Rate: 79
    WAW - Germany, the drum cannot be dismantled
    WLK - Russia, the drum cannot be dismantled
    WLT - Russia, the drum cannot be dismantled
    WAT - Turkey, the drum cannot be dismantled
    WAQ - Turkey, the drum cannot be dismantled
    WLG - Russia, demountable drum
    WAE - Poland, demountable drum
    WAK - Turkey, the drum cannot be dismantled
    WOT - Slovakia, demountable drum
    WAB - Turkey, the drum cannot be dismantled
    WAN -?, Demountable drum?
  • #5 16014240
    mmstan
    Rate: 50
    Thank you. From what I can see, there aren't many products made in Germany anymore.
    I need a washing machine with a load capacity of 5-6 kg. And do you know what the same issue looks like in the Electrolux or AEG brand?
  • #6 16860633
    frantz12
    Freshly after buying a washing machine with the WAN symbol and information from the seller that the drum cannot be dismantled and production in Poland.
  • #7 16860780
    hessto
    Help: 10
    Rate: 79
    +1, Thanks for the info. :)
  • #8 16862737
    holz
    Rate: 35
    Newly acquired information, line of 2006 waves production of Poland, the drum was dismantled. Now that needs to be confirmed.
  • #9 17037905
    roger5
    I join the thread for information - as part of "preparations" for the purchase of a BOSCH washing machine from the SLIM line (load from the front, with a shallower depth - up to 45 cm), I sent an e-mail inquiry to BSH Hardware Gospodarstwa Domowego Sp. z o. o. on the two series that interest me (WLT and WLK). Here is a quote from the responses dated 02/14/2017 of the Senior Product Specialist:
    "(...) both series: WLT ... and WLK ... are produced in Russia and have a washing unit that can be dismantled. . (...) "
    If you believe her, and there is no reason not to :) so I update information about these two series:
    * WLT - Russia, demountable drum
    * WLK - Russia, demountable drum
    Regards - Roger
  • #10 17432541
    zbo3q
    Hello!
    I know that I reheat the topic a bit, but I have a WLT24460PL washing machine and from what it says, it's made in Spain.
    The washing machine was bought in April 2017. Until now, the washing machine works flawlessly. And this silence .... :D
  • #11 17432604
    PanAGD
    Help: 65
    Rate: 112
    Dismountable drum = the possibility of replacing the bearings.
    I confirm :)
  • #12 17472775
    wojtek__
    Help: 8
    Rate: 150
    In Bosch washing machines, to find out whether a given model has a bolted / disassembled or glued drum, it is best to go to the diagram of a given copy on the Bosch company website to choose spare parts for it:
    Bosch - Find spare parts
    For example. If the diagram for the WAW24740PL / 12 specimen does not show the front and rear parts of the drum container and the bearings separately, it means that the drum container is non-dismantled, glued:
    Bosch - WAW24740PL / 12
    Identifying German-Made Bosch Washing Machine Models with Removable Drums and Replaceable BearingsBosch-WAW2...-edit1.jpg (314.36 kB)You must be logged in to download this attachment.
    If the diagram for WAN2826EPL / 24 shows the front and rear parts of the drum reservoir separately, but the bearings are not listed, the drum reservoir is dismountable, bolted, but the bearings are INTEGRATED with the rear drum reservoir and cannot be replaced (must be purchased the entire rear part of the tank in case the bearings need to be replaced)
    Bosch - WAN2826EPL / 24
    Identifying German-Made Bosch Washing Machine Models with Removable Drums and Replaceable BearingsBosch-WAN2...-edit1.jpg (285 kB)You must be logged in to download this attachment.
    If the diagram for WAE24240PL / B3 shows the front and rear parts of the drum reservoir and the bearings separately, it means that there will be no problem with replacing the bearings:
    Bosch WAE24240PL.B3
    Identifying German-Made Bosch Washing Machine Models with Removable Drums and Replaceable BearingsBosch-WAE2...3-edit.jpg (279.64 kB)You must be logged in to download this attachment.
    The current Bosch series with bolted tanks and NON-integrated bearings are: normal WAE and slim WLG version
    Bosch series with bolted tanks but INTEGRATED bearings with the rear of the drum tank are: WAN and slim versions WLT and WLK
    Bosch series with glued drum tank are other series: WAT, WAW, WAY, WAB, WIW, slim versions do NOT have glued tanks
  • #13 17586516
    qucia
    Rate: 103
    Hello ! I know that the topic is almost closed, but I have a question related to the Bosch washing machine model. In the coming weeks I have to buy a bigger Bosch washing machine, currently I have 6 kg, but I have to buy 9 kg. I am considering two Bosch models: WAW 24540PL Serie 8 VarioPerfect and WAT 2466EPL Serie 6. Could someone please explain to me what the initial letters mean and which model to choose. Thank you in advance and best regards.
  • #15 17600965
    plastifon
    Rate: 19
    How does this relate to washer dryers?
    I am thinking of the Bosch Serie 6 WDU28540EU
    There are no such markings there?
  • #16 17602137
    PanAGD
    Help: 65
    Rate: 112
    A little update. Bearings in Bosch WAN washing machines are fully interchangeable. They are not sunk in the back vat, and simply in the world they can be broken and replaced.
The discussion centers on identifying Bosch washing machine models made in Germany that feature removable drums and replaceable bearings. Users share insights on various Bosch series, noting that models like WAW, WLK, WLT, and WAN are produced in different countries, with many lacking dismantlable drums. The WLG and WAE series are mentioned as having demountable drums. The importance of checking the Bosch website for spare parts diagrams is emphasized to determine drum types and bearing replaceability. Users also inquire about Electrolux and AEG models, indicating a broader interest in reliable washing machines with specific features.
