LG F12U2TDN0 vs Bosch WAN2426EPL: Comparing Washing Machines, Bearing Replacement & Capacity
skypablos 13668 4
  • #1 16632320
    skypablos
    I warmly welcome,
    I kindly ask you for help in choosing a washing machine. I'm asking here because I see many specialists in this field familiar with and testing various models.
    Fortunately, I already have two to choose from and I'm hesitating all the time between:
    LG F12U2TDN0 and Bosch WAN2426EPL ...
    As far as I know in both there is the possibility of replacing the bearings, the drums are bolted, both models have a production line in Poland.
    Only the difference (not confirmed, maybe someone has such LG model), that if in LG will pack laundry, for example, on a mixed program above the nominal given in the instructions of the balance, the program will not take off. In a word, I have to take out excess laundry to have the 4kg charge on a given program no more.
    And in Bosch, despite the given amount of charge, I can exceed the kg and the program will start, but I can be not satisfied with the final washing effect. This is where I wonder why the batch weighing system ?? Maybe the question of choosing water ?? But, for example, the program mix in Bosch is given in the instruction 4kg max, weighs the laundry and is 6kg, the program will start in LG, it would not start. Maybe someone has similar experience with these models of washing machines?
    The above information from the hotline of both producers.
  • #2 16632343
    Bobasy
    Rate: 12
    low ground is not Bosch. Sometimes I work with washing machines, hobbystically. And with LG there are, how would it ..... Strange cases, and that's something here, or there, np urwie / przepali / .......
    And the weighing also shows care for the bearings. Only if there is really care, is it just another trick.
    Assess yourself because you'll be able to see your chosen washing machine every day and use it a little less often ;)
    PS I have Bosch (different model than your question) and I like Hotpoint Aqualtis and Dyson CR01 or CR02, because they wash beautifully in the sense that it looks cool even during washing.
    Ps, if you're going to mess with advertising, instead of concentrates or washing balls, or you'll do a concentrated powder (borax + soda) yourself. And if you are going to rinse the lotion (a lot) and have hard water, the best thing would be an automatic Tara washing machine ;) very economical in storage ;)
  • #3 16637346
    skypablos
    Hmm ... interesting statement, I suppose, however, that Bosch is second to none ;)
    And what could you say about the Siemens brand yet?
    Are the motors used in current Bosch and Siemens are as quiet and energy-saving as it is in LG ??
  • #4 16637409
    Bobasy
    Rate: 12
    Do you ask about DTS or thx sound or simply mono sound like yamaha orthodynamic headphones model HP-50A or similar ;)
    Where will you be connecting, how do you have a stable network what neighbors have on the line? Because, let's give it an electric massaging mat, it can kill not just one piece of equipment, and it's somehow still a few meters away from it and not the surrounding ones.
    Do you understand what I'm writing about? Why are you going to listen to the washing machine? Because it is missing, so far ;) I sometimes listen, but it's a different thing, the Hobbit and entertainment. The organism is placed for faithful and dedicated service ;) , the sounds are beautiful when the washing machine comes in, and when the couple hisses and I know that after 20 minutes of refreshing, I remove something soft and almost fluffy, and these were just shirts or something like that.
    But it is a clean machine needed without common "preparations".
    But closer to ... The more you "protect" against failure or malfunctions, the more you go ... go a little scratch. You will not achieve it anyway. Because it is already like that. Titanika was built on the unsinkable. This is the so-called "good hand". One has a polonaise before he rides and is satisfied and another has a mustang and trembles because someone will do it. One you eat happy and the other one has (only)
    greetings :)
    Ps three weeks ago, Siemens oven fell and it was really great. Now there is no microwave and the entire cookbook because it turns off after 2 seconds, it is "only" an oven.
    If I was not too happy with him, he would go quietly but ... ;)
    Did you see a 30-year-old + 150-in-1 washbasin every day without special maintenance? Do you think it depended on the quality of the components? ;)
  • #5 16674613
    skypablos
    Thank you all for your commitment to the subject!
    However, I focused on a completely different brand than the one I asked about the customer!
    I chose the washer: SIEMENS WM12N26BPL and a very good choice for now! RECOMMEND ;)
