Connecting Kitchen Hood to Mechanical Ventilation Using 230V Relay with Potential-Free Output
baxxterhp 3006 4
  • #1 16015343
    baxxterhp
    Rate: 9
    Hello, I have this problem:
    i wanted to connect the hood with the mechanical ventilation in such a way that when the hood is activated, the exhaust fan in the mechanical ventilation is switched off. I would need some kind of 230V relay to control the potential-free output. Does anyone have any suggestions?
  • #2 16015355
    goldi74
    Help: 1367
    Rate: 1539
    Any relay with a 230V AC coil having at least one NC contact will fit.
  • #3 16015395
    baxxterhp
    Rate: 9
    Can you ask for an example?
  • #5 16016873
    baxxterhp
    Rate: 9
    Thanks for the hint.
