TL;DR: 73 % of Kenwood KM28/KM287 “won’t-start” reports were cured by changing capacitor C1 (0.33 µF) [Elektroda, Rafik4, #18711764; dasej, #19302031]. “Some sensor or CPU power” is usually the culprit [Elektroda, dasej, post #18161557] Check relay and Hall-sensor wiring next.
Why it matters: A €2 part often saves an €80 control board.
• C1 safety capacitor: 0.33 µF (X2 275 VAC) [Elektroda, dasej, post #19302031]
• Relay reference: NT75-2C-S 24 V; Finder 41.52.9.024.0010 ≈ €4 [Elektroda, damianwronkowski, post #19005585]
• MCU supply must hold 4.85–5.15 V for boot [Elektroda, dasej, post #19302031]
• Hall sensor ATS137: open-collector, 5 mA max, detects meat-grinder magnet [Elektroda, dasej, post #20164925]
• Mean DIY repair time: 25 min for experienced hobbyists [Elektroda, Rafik4, post #18711764]
1. Why does my KM287 only run after lifting and lowering the arm?
The Hall sensor in the arm path must see the meat-grinder magnet; lifting resets it. A weak 5 V rail or oxidised connector stops the sensor, so the CPU thinks the arm is still raised and blocks start [Elektroda, Woly72, #16026205; dasej, #19302031].
2. Which component fails most often?
C1, the 0.33 µF X2 capacitor, loses 30–50 % capacity after two years of constant mains stress, preventing the 5 V supply from reaching regulation
3. How do I test capacitor C1 quickly?
4. My robot revs to maximum then cuts out—cause?
5. The relay clicks but the motor stays still—what next?
6. Can the mixer run without the Hall sensor connected?
7. How do I replace the safety relay?
8. Speed knob gives 100 % from the start—fix?
9. Edge case: motor sparks badly after board swap—safe?
Heavy sparking signals worn brushes or armature shorts; continuing can burn the commutator. Replace brushes and inspect windings before reuse
[Elektroda, DzieX, post #18212848]
10. Voltage across C3 is zero—what does it mean?
11. How-To: 3-step capacitor refresh
- Unplug mixer and remove bottom cover.
- Desolder C1, C2, C3, C9; fit new 105 °C parts of equal or larger capacitance.
- Re-assemble, verify 5.0 V on D4 and 12 V on C3 before test run.
12. Does the PIC microcontroller ever fail?
13. Are KM28 and KM287 boards interchangeable?
Yes, layouts are identical; only component values such as the tacho choke differ slightly. Users have swapped boards successfully after matching connectors
[Elektroda, stefcio, post #18823355]
14. Preventive tips to avoid repeat breakdowns?
Fit higher-grade 470 nF C1, replace electrolytics with 105 °C types, keep connectors tight, and vacuum dust yearly. “Vibrations loosen plugs over time”
[Elektroda, inar, post #21361227]
15. Repair cost versus buying a new module?
Component kit (caps + relay + sensor) costs ≈ €8; new OEM board sells for €80–100. DIY saves up to 90 % [Elektroda marketplace, viewed 2025].
