High AUXTIN Temperature in SpeedFan: Intel Core i5-4690k, MSI Z97 Gaming 7, MSI GTX 970 Setup
arkadioo 42699 13
Why does SpeedFan show AUXTIN temperatures jumping to around 130°C on this PC, and should I worry about it?
AUXTIN in SpeedFan is usually a bogus or misread sensor value, so 130°C and similar extreme readings can generally be ignored [#16041247][#16041249] It may be associated with a PSU sensor or sometimes the motherboard power section, but the thread does not confirm a reliable hardware source for this particular MSI Z97 Gaming 7 setup [#16041247][#16041761] One reply notes that such readings are often not correct and suggests checking the PSU exhaust only to see whether it is actually blowing hot air [#16041249] Another reply says it is definitely not the PSU and recommends not relying on SpeedFan for this kind of monitoring [#16041819] The safer approach is to use the monitoring software provided by the motherboard manufacturer instead of SpeedFan for these AUXTIN values [#16041819]
  • #1 16041225
    arkadioo
    Does anyone know what this AUXTIN in speedfan means? It worries me that the temperature jumps up to 130 even :( CPU usage is also quite large because 25 is probably not the norm and everything is turned off (???,)
    CPU: Intel Core i5-4690k + Be Quiet! Dark Rock 3 GPU: MSI GTX 970 Motherboard: MSI Z97 Gaming 7 Case: Corsair 760T Storage: Crucial M550 128GB + 1TB WD Blue PSU: Corsair CS Series 650W Modular 80+ GOLD RAM: G.Skill TridentX DDR3 2x4GB0 2400MHz CL10 Monitor: LG 23MP65
  • #2 16041247
    Marek Nawrocki
    Help: 98
    Rate: 136
    Hello !!
    Found on the net, but maybe it will help you.
    AUXTIN is a temperature sensor placed most often in the power supply (less often on some element of the main plate) and in most cases it shows temperatures from space (for me it was even above 300 degrees). These indications can be ignored without fear.
    See: http://www.chip.pl/forum/viewtopic?tid=51834&fid=4
  • #3 16041249
    PCG_PL
    Help: 10
    Rate: 8
    This is the temperature of the power supply, although you have a good one. You don't necessarily have to worry about this, usually these readings are not correct, but you can put your hand to the air exhaust from the power supply just in case and check that it is not blowing hot air. The consumption is not that high, and you don't have to worry about it either.
  • #4 16041256
    badboy84
    Help: 1197
    Rate: 1486
    And those -60 don't bother you? ... You have HWmonitor so you can remove this "funny fan" because it is not useful anyway.
  • #5 16041277
    arkadioo
    -60 hehe I just noticed it. Thanks for the answers, I decided anyway to dedicate today to cleaning the computer inside.
  • #6 16041286
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Since my colleague is sure that this is the temperature of the power supply, could I ask you to explain to me how it is read from this power supply? Because for such fun you would need a sensor in the power supply and some connection to the monitoring system on the board. And while I assume the occurrence of a temperature sensor as possible, I wonder how the power supply would communicate with the board in this matter.
  • #7 16041307
    badboy84
    Help: 1197
    Rate: 1486
    2-pin cable ?! :) I just wonder where this sensor should be placed? I have a sensor in my power supply stuck in the rear grilles, which would blow the air from the power supply on it and it shows something there ;)
  • #8 16041609
    dt1
    Help: 7315
    Rate: 8292
    But where do you connect this cable to the MSI Z97 Gaming 7? The board has no connectors for connecting external sensors. If you mean connecting strange cases to the front panels with a large LCD inserted there for a fancy, these have nothing to do with the AUXTIN indications, so I'm curious how AUXTIN is to measure the temperature of the power supply in such a computer, on such components :)
  • #9 16041625
    badboy84
    Help: 1197
    Rate: 1486
    Asus thought about it and left such a connector ;) as for the readings, I only checked organoleptically and I have no objections.
  • #10 16041735
    PCG_PL
    Help: 10
    Rate: 8
    I honestly don't know, that's just how I read it :P it could go through a 24-pin, or the program would somehow estimate it in terms of voltages.
  • #11 16041740
    dt1
    Help: 7315
    Rate: 8292
    It could not, the specification does not provide for this :)
  • #12 16041761
    PCG_PL
    Help: 10
    Rate: 8
    I will suggest one more guess, maybe it's the power section on the motherboard and not the power supply? This is probably a more realistic option.
  • #13 16041819
    badboy84
    Help: 1197
    Rate: 1486
    It is definitely not a power supply, it does not look like the power section either, because the temperature is too high. It may well be the temperature of your neighbor's fireplace. I really would not be influenced by what this program gives, but to use the software provided by the manufacturer.
  • #14 16042535
    PCG_PL
    Help: 10
    Rate: 8
    As far as I know, the section can get so hot sometimes, especially when it is not cooled. And the fact that SpeedFun should not be suggested is another matter.
The discussion revolves around the high AUXTIN temperature readings in SpeedFan, specifically for a setup featuring an Intel Core i5-4690k CPU, MSI Z97 Gaming 7 motherboard, and MSI GTX 970 GPU. Users clarify that AUXTIN typically refers to a temperature sensor, often located in the power supply or motherboard, which can sometimes yield inaccurate readings, such as excessively high temperatures. Suggestions include checking the power supply's air exhaust for overheating and considering that the AUXTIN reading may not be reliable. Some participants speculate on the source of the temperature reading, debating whether it could be from the power supply or the motherboard's power section. Overall, the consensus is to not overly rely on SpeedFan's readings and to use manufacturer-provided software for more accurate monitoring.
