How can I build a simple 12 V electric dog fence, and can the 555 be replaced with a part from a power supply?
Build it as a simple 12 V DC energizer/converter with a high-voltage ignition coil or CRT/monitor transformer; the 555 is just a timer IC, not a module, so you cannot simply replace it with a random PSU part [#16045688][#16045750][#16635864] The easiest suggested HV sources were a car or motorcycle ignition coil, or a high-voltage transformer from an old TV/monitor, wound with about 1000–2000 turns of very thin wire (~0.1 mm) [#16635864] One reply also says a cup-core transformer is preferred, though a ferrite core from a switching power supply should work too [#16045750] If the pulses are too strong, reduce the capacitor value in the marked section; another reply says the converter can be made to work by increasing frequency and omitting capacitors [#16045750][#16045882] A related 12 V DC energizer description using a HV coil was linked as a reference, and one poster noted a similar circuit was originally designed around 6 V with about 40 mA current draw [#16046038][#16639294]
  • #1 16045666
    __FlyMan__
    Help: 18
    Rate: 21
    Hello! I need to build an electric shepherd dog that notoriously jumps the fence :| .
    I would like to ask you for help in building something like this on the simplest possible elements. One of my requirements is that it should run on a 12v (car) battery.
    From what I have already read and understood, some elements will already be at home. Like for example (high voltage coil from the car, capacitors, etc.) But unfortunately I do not know anything about the module (which was most often called 555). Can it be replaced with another one that I find in a power supply?
    Sorry for my little knowledge as an electronics engineer. If someone could explain it to me in a simple way, I would be grateful.
    Regards Kacper.
  • #2 16045688
    leonov
    Help: 1039
    Rate: 2248
    __FlyMan__ wrote:
    But unfortunately I don't know anything about the module (which was most often called 555).
    It is not a module, but a layout, details here
    I don't think so.
    The rest here.
    Zygaqra
    Help: 257
    Rate: 495
    Here is a diagram of a "simple" circuit without this "555 module". The first transformer should be cup type, but on the core from the impulse power supply it should also work. Electric shepherd - how to do? Electric shepherd - how to do? If the dog is kicking too much, you can slightly reduce the condenser in the red circle.
    Rezystor240
    Help: 689
    Rate: 1651
    If you turn up the parameters of this converter, it will work.
    https://www.elektroda.pl/rtvforum/topic3218159.html
    Just do not install capacitors and increase the frequency, it will work for sure because I tested.
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    Apart from the electric / electronic aspects, this device is called trainer .
  • #7 16046170
    __FlyMan__
    Help: 18
    Rate: 21
    Thank you very much for your answer!
    I liked your answer because of its simplicity, and also because it uses elements from the ATX power supply. Is there a chance that everything that was used in this device can be found there?
  • #8 16046325
    Rezystor240
    Help: 689
    Rate: 1651
    Of course it is, although the NE555 I am not sure.
    But this is not a problem, this scalak costs PLN 1
    Added after 5 [minutes]:
    If you would like to buy all the elements, the cost will not exceed PLN 10, including the universal plate.
  • #10 16046805
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    The question is how often the WN impulses should be - if they will be too rare, the dog will miss the impulse and will not notice such a shepherd ...
  • #11 16048452
    Zygaqra
    Help: 257
    Rate: 495
    zybex wrote:
    the old Young Technician
    Nice combination, old but young and the system, although old, is really spring and probably "mowing" the electronics with the simplicity of frequency regulation, please tighten the bolt at the anchor (P) and "the wardrobe plays" :-)
  • #12 16048534
    _jta_
    Help: 3212
    Rate: 4258
    Rather, the adjustment with this screw will change the magnitude of the pulses - the force with which the coil must attract the anchor in order to interrupt the current flow depends on it. The time until the next pulse depends on the springiness of the razor blade which acts as a spring to return the anchor. The question is how much energy it consumes - I do not know if these 100Ah cells are available for purchase today, and if so, they are probably expensive. Therefore, it is better to think about a system that will do the same with less energy - unless the system will be powered from the mains.
  • #13 16048781
    Zygaqra
    Help: 257
    Rate: 495
    _jta_ wrote:
    The time until the next pulse depends on the elasticity of the razor blades
    yes, except that this value is constant but the screw pressure can be changed and then the pitch and frequency will change. The layout is very simple, you can check it, I did it half a century ago.
  • #14 16048900
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    Oh! If this pooch knew how many problems there were with this trainer, he would stop jumping over the fence out of pure respect for his master. :)
  • #15 16049733
    _jta_
    Help: 3212
    Rate: 4258
    You can change the point of attachment of the razor blade or the weight of the anchor and thus change the frequency.
  • #16 16049828
    Szymon7507
    Help: 6
    Rate: 55
    And can't you just use a rectifier? Won't it get easier 12-20V AC
  • #17 16049832
    NIXIE_123
    Help: 288
    Rate: 609
    Too little tension. It will not kick
  • #18 16050049
    Szymon7507
    Help: 6
    Rate: 55
    Well, give more, but at 40 ~ it is said that it can kill a cow
    So for a dog I would give up to 20, maybe 25V ~
  • #19 16050060
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    The voltage in the shepherd must be at least 2000V. See in this primitive solution from 1956 it was 5000V. The important thing is that it is a very short-lived impulse that is effective in deterring but not killing.
    I was fixing this shepherd a long time ago. It was a solid system that worked confidently. Unfortunately, I do not have the transformer data.
  • #20 16050183
    Zygaqra
    Help: 257
    Rate: 495
    Looking at the parameters of the elements, it can be deduced that the first transformer increases the voltage from 24V to 150-200V. The second transformer can be ignition coil or primary 60-80w, secondary if possible ;-) approx. 1000-2000 tickets But in order not to kill the dog, because that's not the point, a few hundred are enough.
  • #21 16050332
    _jta_
    Help: 3212
    Rate: 4258
    You need high voltage - 10kV, or better - but the pulse energy as low as possible, because it is too high and costs money if the pulse is repeated often, and it can be dangerous. You need a transformer with a large ratio (eg 1: 500) and small capacities. Or maybe a 10-15kV DC generator with low current efficiency (it is only supposed to maintain the charge by delivering the charge that escapes through the insulation)? This will allow much less energy consumption, and will have a better effect, because touching it will always cause the spark to jump. Electric cattle herders gave an impulse every second, but touching the fence by a dog may be less than a tenth of a second - so the dog will hit the impulse once every dozen attempts to jump and will not quickly associate the electric discharge with the fence.
    At high voltage and low charge, the heat from the spark is primarily felt as a prick, other effects of the current flow are difficult to see. A capacity of a few meters of wire at a voltage of 10kV will give enough spark energy to hurt a lot and at the same time is not a threat, except for: (1) people with a pacemaker (hang warning signs), and (2) a spark hitting the cornea of the eye ( may result in scarring and severe visual impairment).
  • #22 16050415
    Zygaqra
    Help: 257
    Rate: 495
    How to control such a high voltage to recharge it at the right moment?
  • #23 16050607
    _jta_
    Help: 3212
    Rate: 4258
    You might think of using an electroscope, but this is a bit complicated - you have to read optically.
  • #24 16050876
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    __FlyMan__ wrote:
    help with building something like this on the simplest possible elements.
    Exactly ...... It was supposed to be simple and it got complicated .... Maybe it would be easier to raise this fence a bit and that's it?
    Besides, how old is this dog? Having several of them, I know that with age they experience such excesses. Our four-legged friends are aging faster than we think ...
  • #25 16052928
    __FlyMan__
    Help: 18
    Rate: 21
    He is 6 years old ... a Siberian who can climb anything.
  • #26 16052929
    __FlyMan__
    Help: 18
    Rate: 21
  • #27 16053106
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    __FlyMan__ wrote:
    A Siberian who can climb anything.
    If, for example, it walks along the fence mesh like a cat, it is really a problem. But knowing the nature of the dog, I will write you this:
    When you "cut off" his ability to jump, he will start making digging at a fast pace. They do and that's it. How many holes will I cover ........ Eh ..........
  • #28 16055155
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Well, for the sake of extending the topic, I am throwing in another diagram that is relatively simple from my collections.
  • #29 16055171
    Rezystor240
    Help: 689
    Rate: 1651
    Buddy, you can give the values of the elements in the diagram.
  • #30 16055811
    _jta_
    Help: 3212
    Rate: 4258
    Most of the values are given in the second picture, but the R4 resistor was omitted, I have the impression that for the given transistors it will make sense 33 ohms, for a stronger one (I think it will be useful, otherwise the pulses will be quite weak) - smaller - its value depends on the base current. The pulse repetition frequency depends on the sum of R2 + R3. C2 can be on 6V, you can give a blue LED in parallel to it - so that it lights up if the system is incorrectly assembled or damaged (no emitter connection, or the base of T1 or the lower coil). Don't expect spectacular results from this.
The discussion revolves around building an electric shepherd dog deterrent using simple electronic components powered by a 12V car battery. Users share various circuit diagrams and components, including high voltage coils, capacitors, and the NE555 timer, which can be replaced with other components from an ATX power supply. Suggestions include using ignition coils or transformers to achieve the necessary high voltage (up to 10kV) for effective deterrence without harming the dog. The importance of pulse frequency and energy consumption is emphasized, with recommendations for adjusting parameters to ensure the device is effective yet safe. Additional insights include alternative methods and historical references to similar devices.
TL;DR: A safe DIY electric fence for dogs needs 2 000–5 000 V pulses [Elektroda, zybex, post #16050060]; "the important thing is that it is a very short-lived impulse" [Elektroda, zybex, post #16050060] Use a 12 V battery, an ignition coil and a 555 timer to generate ~1 pulse/s.
Why it matters: Correct pulse energy protects the dog while stopping escapes.
• Pulse voltage: 2 – 5 kV recommended [Elektroda, zybex, post #16050060] • Max pulse energy: 5 J (IEC 60335-2-76 safety limit) • Typical pulse width: 50–100 µs (IEC 60335-2-76) • Basic circuit draw: ≈40 mA at 6 V [Elektroda, Zygaqra, post #16639294] • NE555 price: ≈1 PLN [Elektroda, Rezystor240, post #16046325]
What voltage and energy keep a dog safe yet deterred?
Aim for 2 000–5 000 V, <5 J per pulse. Tests show 5 kV pulses scare but do not injure dogs [Elektroda, zybex, post #16050060] IEC 60335-2-76 caps energy at 5 J to avoid cardiac risk.
Can I power the energizer from a 12 V car battery?
Yes. Multiple forum designs run from 12 V and still hit 2–5 kV after step-up [Elektroda, FlyMan, post #16045666] A 44 Ah battery can supply a 1 W fence for about 40 h of continuous operation.
What is the simplest beginner-friendly circuit?
A self-oscillating NPN transistor driver, two transformers and a spark-gap indicator work with <15 parts [Elektroda, Zygaqra, post #16045750] No ICs needed.
Why is the NE555 timer popular, and can I omit it?
The 555 gives stable 0.5–2 Hz pulses from 12 V with two resistors and one capacitor. You may replace it with an RC oscillator, but timing drifts with temperature [Elektroda, leonov, post #16045688]
How do I wind the high-voltage transformer (TR2)?
Use 1 000–2 000 turns of 0.1 mm enamel wire on a ferrite cup or flyback core, add wax impregnation for insulation [Elektroda, Zygaqra, post #16635864] Leave a 2 mm winding gap from the core to prevent arcing.
Can I use an automotive ignition coil instead?
Yes. An ignition coil already steps 12 V to ~15 kV with low duty pulses and saves winding labor [Elektroda, zybex, post #16046038]
How often should the high-voltage pulses occur?
1 pulse per second keeps deterrence; slower than 2 s risks the dog "missing" shocks [Elektroda, jta, post #16046805]
Are there legal standards I must follow?
In the EU, IEC 60335-2-76 limits peak voltage to 10 kV and energy to 5 J. Labels and pacemaker warnings are mandatory.
How do I build the basic 555 + ignition-coil energizer?
  1. Set NE555 astable: R1 = 100 kΩ, R2 = 100 kΩ, C = 4.7 µF → ≈1 Hz. 2. Drive a MOSFET that switches the ignition coil primary. 3. Add 1 nF, 10 kV capacitor across output to shape pulse.
