LG TV Displaying 'No CI Module' After Moving to a Larger City: What Could Be the Issue?
Sylwesteer 143709 8
  • #1 16116900
    Sylwesteer
    Rate: 39
    I used my LG TV at home, the usual antenna was connected and the set-top box built into the TV downloaded these basic 20 channels, I moved to a larger city, I took the antenna and TV with me, I connected. "No CI module" pops up, can anyone tell what's going on? Maybe it's some trivial reason, and I don't know anything about it.
  • #2 16118685
    krru
    Help: 230
    Rate: 214
    I understand that you are trying to receive DVB-T (terrestrial TV). One of the multiplexes is coded, probably it was not available in the first location and now it is and the TV is asking for a decoding module. You can probably specify in the menu that the TV should ignore scrambled channels.
  • #3 16119947
    KOCUREK1970
    Help: 3867
    Rate: 5500
    Probably mux4 (Cyfrowy Polsat) - you will not buy a module for this, because their CP does not offer this service.
    And on TV, remove the channels and set the search only for uncoded, or manually enter the parameters.
  • #4 16120891
    Sylwesteer
    Rate: 39
    It is very possible that you are right but I have been playing with it for a long time and I have no idea how to do it
  • #5 16120923
    KOCUREK1970
    Help: 3867
    Rate: 5500
    Reset the tv to factory settings and program the muxs manually:
    Here you will find the parameters of your transmitter / closest to your location
    http://emi.emitel.pl/EMITEL/przeglad_obiektow.aspx
  • #6 16122346
    leszekpo59
    Help: 151
    Rate: 263
    Hello. Let me also speak about solving your problem. What is mentioned earlier, i.e. the reception of the MUX-4, which requires the CI + module, is one of the reasons for the appearance of the message. The second reason may be that a DVB-C search may have been started in the menu to search for terrestrial TV channels. Please check carefully which tuner has been selected. For terrestrial DVB-T is required and this must be set. Good luck.
  • #7 16122490
    Sylwesteer
    Rate: 39
    Yes, my neighborhood is channel 46 on the 674 MHz frequency, but in my manual setup there is only a signal on 38 and there are 10 radio 15 tv's, but of course all encoded. I have a peaceful antenna, but it should catch something
  • #8 16122540
    KOCUREK1970
    Help: 3867
    Rate: 5500
    And here may be a problem - the need for an external antenna.
    Your transmitter is Białystok Krynice - I don't know how far from you - but if it's 10-20 km, with its power I don't see any chances for a room antenna to work.
  • #9 16122548
    Sylwesteer
    Rate: 39
    I'm renting this room in the house, it's not connected to me, so I won't drill for them here :) Close topic, thank you
The user is experiencing a "No CI module" error on their LG TV after relocating to a larger city. This issue likely arises from the reception of DVB-T channels, specifically due to the presence of coded multiplexes that were not available in the previous location. Solutions suggested include adjusting the TV settings to ignore scrambled channels, resetting the TV to factory settings, and manually programming the multiplexes. Additionally, the need for an external antenna is highlighted, as the current indoor antenna may not suffice for receiving signals from a distant transmitter.
