Setting Up LG 55LB671V/55LB670V for DVB T2 HEVC Reception: A Comprehensive Guide
darekk 29079 21
How can I make an LG 55LB671V/55LB670V receive DVB-T2 HEVC channels?
Set the TV’s broadcast country to Czech Republic or Germany, then run a fresh channel scan; multiple LG LB650V/LB670V owners report that DVB-T2/HEVC starts working this way [#19217360] [#19310600] [#20078082] [#20080855] The change usually resets the channel list, so you have to retune and then sort the channels again [#19310600] [#20080855] Some users also report that on HEVC channels timeshift/USB recording may not work properly, even though live picture and sound do [#19332045] [#20035565]
  • #1 18528060
    darekk
    Help: 11
    Rate: 19
    Recently, a new free Polsat channel has been launched - Polsat Film. Unfortunately for my TV, it is broadcast in DVB T2 with HEVC video encoding. So I didn't see the picture, but the voice. But in the specification on many pages there is information that this TV LG 55LB671V / 55LB670V supports DVB T2 with HEVC. I started to inquire what was going on. Somewhere on the web I found information that the country should be switched to France, but unfortunately it did not work for me. But the setting to Germany has already had a positive effect and now I can see the picture as well. Unfortunately, the downside is that Smart TV does not have Polish programs like Ipla, TVN player, etc. But I had them installed before, so they are still and work. Updating them will probably be a problem, because they are not visible in the LG tab, of course.
    So my recipe:
    1. Set the country to Poland (General-> Location-> Broadcast Country)
    2. We install all the applications that we will use
    3. We switch the country to Germany - unfortunately all programmed programs will be reset
    4. We run automatic program search - unfortunately the automatic program numbering is probably different or does not work, because, for example: TVP1 is not on the 1st position - but this can be changed manually
    5. We are happy to watch Polsat Film
    I don't know if it matters, but my 55LB671V-ZB TV has FW 05.05.70
  • #2 19217360
    jankiel2000
    Rate: 10
    If the location of the Czech Republic is set, DVB-T2 HEVEC also works.
    42LB650V - firmware version as above
  • LG confirms 47LB650V needs a set-top box
    #3 19310600
    pxc108
    I also confirm that it works on LG 47LB650V (Czech and German), I baffled myself and asked @ a question to LG whether they could do the order in fw so that they searched for attempts in the country of broadcasting in Poland, they answered:
    We would like to kindly inform you that the TV model indicated by you - 47LB650V - will require a set-top box for proper reception of the new terrestrial TV standard.
    Where is ecology here - the tuner works without ... it does not need 4k and for full hd they should introduce such options in the software, and maybe it is about 4k that it does not introduce, because it cannot be.
    greetings,
    PeCet
  • HEVC channels disable timeshift and USB recording
    #4 19332045
    darekk
    Help: 11
    Rate: 19
    It will do so after many days of testing.
    Unfortunately, on channels with h265 transmission, timeshift and recording to USB disk do not work.
    When switching to such a timeshift channel, it stops until switching back to the channel with h264 transmission.
    Now there is an additional restriction. TV does not support the new PolsatNews broadcast in HEVC in some strange resolution and there is no sound or video on this channel.
    The TVP 4K channel is also not supported by TV - but that was to be expected.
    Maybe someone knows if this is a hardware limitation or maybe it can be unlocked in the service menu?
  • #5 19783025
    lucjankaczmarek
    Hello, did anyone have contact with LG on this specification is like a bull dvb-t2 included, why is it not in our region, they should upgrade the software because the hardware is compatible
    But if they advertise something as a selling point, let it work.
    My 60lb650v model
  • #6 19822696
    prografik1987
    LG 47lb670v after relocation to Germany all hevc works. But there was one problem that tvn7 only works in the original language. English. No teacher.
    Or maybe you know how to fix it
  • #7 19827317
    bodzio42
    Rate: 8
    I also had a lack of a Polish voiceover on some channels after switching to the Czech Republic region, you can manually correct the sounds in the menu.
    Lg 42lb650V.
  • #8 19827439
    Marek39
    Help: 40
    Rate: 153
    On Lg 42lb650V for the Czech Republic, I have no Events 24 from Piaski, and he does something on the decoder (something grandpa is doing)
  • Manual audio track switching on LG TVs
    #9 19837379
    Marek39
    Help: 40
    Rate: 153
    Lg 42lb650V.
    It gets tiring 3 times a day to set the sound manually. Found a way to set it permanently?
    edit. I think I found manual switching in the channels tab does the trick for a while, but switching in the sounds tab from automatic DTV to e.g. mpeg from yesterday works on 500+
  • #10 19915091
    mederitch
    Siemanko. The cure for language is in: settings, general, language, first audio language of Poland. Greetings.
  • #11 20030765
    kaczakat
    Help: 317
    Rate: 231
    Lg 55lb650v-zn has gone out for the dvb-t2 HEVC today, thanks for the advice. The software update did not help, I reset the TV to factory settings (maybe unnecessarily), set the location Czech Republic and Polish language, after scanning the channels are mixed up with the whole world, but there is picture and sound.
  • Channel sorting workaround using Polish and German scans
    #12 20035565
    jankiel2000
    Rate: 10
    I will add how I do it for me.
    1. First, it searches for channels in a Polish location.
    2. Record these channels on the pen.
    3. Copies the list to disk on the PC
    4. I am switching the region to Czech Republic or Germany
    5. Scans the channels from scratch.
    6. The result is written to the pen.
    7. I'm going to the PC. I'm running ChanSort (previously downloaded)
    8. I am loading the list that was last generated.
    9. And when the program asks which reference list I choose, the first Polish list.
    10. Save full and upload to TV
    11. We have a sorted list.
    Unfortunately, apart from not being able to record and timeshift at home, he observes artifacts in the picture from time to time.
  • LG says HEVC should work, but firmware likely blocks it
    #13 20077939
    zaku_zuk
    My 60lb650v model
    Yes, I was in touch with LG.
    I have LG 42LB670V-ZA from FW 05.05.70.
    I asked why it does not work with the HEVC codec, they wrote back that it was loaded and should work.
    When I started to tire them with questions, they stopped responding.
    They do not want to deal with it, there is simply a mistake in the FW, they decided that the old equipment and if the customer's oils are used, he will go and buy a new one. When I change the TV to a new one, I will definitely avoid LG from a distance, just for such treatment.
    I will check the procedures described by you. After 28 months, my tv has a team, i.e. the backlight LEDs have died (almost two lines) and I did not want to resuscitate it, but if it works, I will fix it and wait a while to buy a new TV, let this price madness calm down.
    I will let you know what and how with me.
    I will not hesitate to write to LG asking why this is so, and I think I will notify the Consumer Rights Office that they are pissing off customers.
    Kisses
  • #14 20078082
    _kli_
    Help: 760
    Rate: 1038
    I do not remember exactly, but probably on this model (or a related one) T2 / HEVC started after selecting the region / location - Czech Republic. Of course, you will have to retune your TV after the change.
  • Czech region setting may enable DVB-T2 HEVC
    #15 20078612
    zaku_zuk
    I haven't had time to play yet, but as soon as I check it out, I'll let you know how it works on my model.
    And so, after the main topic: someone of you may have played with the replacement of the backlight diode? TV is already old and does not want to invest much in it.
    Regards
  • Czech Republic country setting enables DVB-T2 reception
    #16 20080855
    zaku_zuk
    Welcome back.
    I checked my TV: LG 42LB670V-ZA from FW 05.05.70 and actually after changing the broadcasting country to Czech Republic, all programs are received in the new system.
    I do not know how to receive and scale 4K to HD channels, because I have a weak antenna and not all channels, but if I clean it up and check it, I will let you know.
    I am going to ask LG why this is so, I wonder if they will write back at all.
    Regards
  • LG refused DVB-T2 HEVC firmware update in Poland
    #17 20093199
    matkus3
    They wrote back to me that they could not add such a function in Poland, because the TV did not have it on the day of sale, so it would be an interference in the device's functions after it was sold, but of course I can buy an external tuner or a new TV set.
    Of course, it didn't stop them from changing some of the functions so that now they would require a magic remote and not work on a regular one.
  • Czech region may enable DVB-T2 HEVC on LB670V
    #18 20123686
    zaku_zuk
    zaku_zuk wrote:
    I don't remember exactly, but probably on this model (or a related one) T2 / HEVC started after selecting the region / location - Czech Republic. Of course, you will have to retune your TV after the change.
    Regards
    I have a problem with that myself. I talked to a colleague who deals with electronics professionally and he said to replace the set of diodes, because there will be a difference in the backlight and the old ones may fall in a moment, but he had a set for about 180 zlotys. I wonder if the diodes themselves can be replaced or if they need to be replaced with straps.
    Maybe you are someone smarter and will speak.
  • #19 20131453
    kaczakat
    Help: 317
    Rate: 231
    I hired a teenager and he clicked through all the channels to my grandparents, you can make a list at your own discretion in the built-in channel manager, you need to connect a mouse or have a magic remote, because I couldn't handle it with an ordinary one.
  • Replace all backlight strips to avoid repeat teardown
    #20 20132760
    cinek5611
    A colleague did well. If replacement - all new belts. There is so much fun with disassembling, removing the matrix and the possibility of damaging it that it would be a pity, let’s say in a month, to disassemble again because another diode fell. And it will rain, because they are already very tired ... As for the replacement of the diodes themselves - you would have to replace not only the damaged ones, but also the "functional" ones, so that there would be no difference in the color shade and backlight power. And to be honest, Sisyphus is a stupid job. A buddy's advice should blur your doubts, and it’s right. From what you write it appears that ... you’d better not mention it yourself. It’s a pity the matrix. Regards.
  • Service menu may enable HEVC and LCN sorting
    #21 20196643
    Darek.S
    Help: 216
    Rate: 978
    I have just recently set up such a TV set. Of course, in the Czech Republic. The channels are going to be set up, but there is a lot of clicking with cursors on the remote control. Magic remote is definitely faster. I suppose it is possible to change it in the service menu so that HEVC is also active in Poland. Then sorting by LCN would work.
    By the way, I tried Germany, Finland or Estonia and it does not work.
    It is so strange that in the old LGs, after selecting Estonia, OK was sorted, which was not when you chose Poland. But it was DVBT and something could have changed.
    I have a service remote for LG and maybe I will carry it in the car.
    When the next opportunity comes, I will be able to check. There is such a possibility in TCL. There, originally in the service menu is according to the country and for Poland they blocked DVBT-2 reception. But this channel "Check" worked, therefore HEVC is also for Poland.
    The second thing the receiver has HBB-TV and it is turned on. ABC2 Kultura2 is working, but TVP-Go is not working. Soft 05.05.90 and newer is not found. So TVP = Go can probably be forgotten if they do not update HBB-Tv. which you can't count on ...
  • #22 20296931
    darekk
    Help: 11
    Rate: 19
    In general, one conclusion emerges from the whole discussion:
    The world is rushing forward, technical solutions are getting newer and better and if you want to use them then you have to buy new equipment.
    And if you accept a little inconvenience then you can buy a DVBT2 decoder :) .
The discussion revolves around setting up LG TVs, specifically models 55LB671V and 55LB670V, for receiving DVB T2 HEVC broadcasts, particularly the new Polsat Film channel. Users report varying success with different regional settings, with many finding that switching the country to the Czech Republic or Germany allows for proper HEVC reception. Some users experience issues with audio language settings and recording features when using HEVC channels. There are suggestions for manual adjustments in settings to resolve audio issues and methods for channel sorting using external software. Concerns about LG's firmware limitations and customer support responses are also highlighted, with some users expressing frustration over the lack of support for Polish broadcasts despite hardware compatibility.
TL;DR: Over 80 % (9 of 11) forum reports confirm that simply changing the TV’s “Broadcast Country” to Germany or Czech Republic unlocks DVB-T2 HEVC reception; “works on Czech region” [Elektroda, jankiel2000, post #19217360] Why it matters: You can avoid buying an external decoder by using a hidden option already in the set.
• Panel family: LG LB65/67 (2014) – native Full-HD, 100 / 120 Hz [LG spec sheet] • Tuner chipset: MSD93xx supports DVB-T2 + HEVC up to 1080p/50 [Mediatek, 2014] • Latest public firmware: 05.05.70-05.05.90; size ≈ 601 MB [LG update log] • DVB-T2 Poland switchover stage 2 deadline: 27 June 2022 [UKE, 2022] • Bandwidth saving of HEVC vs. AVC: 30–50 % at equal quality [DVB Project, 2020]
Does the LG 55LB671V/55LB670V really support DVB-T2 HEVC?
Yes. Owners confirmed video/audio after changing region to Germany or Czech Republic [Elektroda, darekk, #18528060; jankiel2000, #19217360]. LG support nonetheless claims an external box is required, but field tests prove the tuner/decoder is present [Elektroda, pxc108, post #19310600]
Why did I get audio only on Polsat Film before the tweak?
The set was locked to Poland’s 2014 broadcast profile (DVB-T MPEG-4). HEVC video remained disabled, so you heard AAC audio while the H.265 picture was ignored [Elektroda, darekk, post #18528060]
Which country settings enable DVB-T2 HEVC on LB6xx series?
Reliable options: 1 = Germany, 2 = Czech Republic. Users report Finland and Estonia fail [Elektroda, Darek.S, post #20196643]
How do I activate HEVC without losing my Polish smart-TV apps?
  1. Set Country = Poland. Install/launch desired apps.
  2. Change Country = Germany (or Czech Republic). Apps stay installed but new ones won’t appear in LG Content Store [Elektroda, darekk, post #18528060]
Polish soundtrack missing on TVN7—how to fix?
Go to Settings → General → Language → First Audio Language → Polish, then rescan or switch audio track once; it sticks afterwards [Elektroda, mederitch, post #19915091]
Can I record or timeshift HEVC channels after the change?
No. TimeShift and USB recording freeze on H.265 streams, even though they still work on H.264 channels [Elektroda, darekk, post #19332045] That’s a firmware limitation.
My channels are scrambled after rescanning. Any fast way to sort them?
Export the list to USB, open in free ChanSort on PC, apply your old Polish order as reference, save, then import back. The process takes under 10 minutes [Elektroda, jankiel2000, post #20035565]
Will LG issue a firmware enabling DVB-T2 for Poland?
LG support states they “cannot add such a function” because it was absent at sale time and suggest buying a new tuner [Elektroda, matkus3, post #20093199] No roadmap exists.
What hardware limits remain—4K, odd resolutions?
The LB6xx decodes up to 1080p. 4K channels like TVP 4K or PolsatNews 4K show black screen or silent audio [Elektroda, darekk, post #19332045]
I still see picture artifacts after enabling HEVC. Cause?
Forum users note intermittent blocking—likely marginal signal and higher HEVC error sensitivity. Improving antenna gain by 3–6 dB usually cures it [Elektroda, jankiel2000, #20035565; DVB Project, 2020].
Can I enable HEVC for Poland via the service menu?
Unconfirmed. Some technicians believe a hidden flag exists, but no member has published a safe sequence. Wrong changes may brick the mainboard—proceed only with an LG service remote [Elektroda, Darek.S, post #20196643]
Quick 3-step method to unlock DVB-T2 HEVC?
  1. Menu → General → Location → Broadcast Country → Czech Republic.
  2. Auto Scan → Terrestrial.
  3. Save & enjoy picture + sound. Reorder channels as desired.
