Cordless Drill / Driver for Concrete Walls: Sunday DIY - Metabo SBE 650, SB 760, Bosch GSB 13 RE
chester2420 26640 11
Can a cordless drill/driver in the PLN 250–280 range drill a few 8–10 mm holes about 8 cm deep in concrete walls?
Not reliably: for concrete walls, a cordless screwdriver/drill in this budget is generally too weak, and the thread recommends either a cheap hammer drill or renting a mains tool for occasional work [#16146820][#16146865][#16153830] If you want battery-powered only, choose a mid-range Li-ion model with impact rather than a basic screwdriver, but even then concrete drilling is hard on both the tool and the user [#16152413] One reply says that if you rarely drill concrete, it is better to buy a cordless drill-driver without impact and use a rental tool for the concrete jobs [#16153830] Another user reported that a Bosch PSB 12 VE-2 screwdriver drilled four wall plugs without problems, but stressed that good-quality widia bits matter [#17929708]
  • #1 16140653
    chester2420
    I wanted to ask for professional advice. Well, I would like to buy a cordless drill for Sunday DIY. It depends on the screwdriving function, but also drilling in concrete walls (small, rarely performed works), the maximum depth of the hole is 8 cm, diameter 8-10 mm.
    Due to the low intensity of the planned works, I would not like to burden the budget and invest up to PLN 250-280. Is it possible to make a few holes in a concrete wall with such equipment? Naturally, I would go in the direction of network drill holes, but in the basement where I would like to make open holes, I do not have a socket.
    I sent several inquiries to the hardware stores. I received the following options:
    Store No.1:
    Hammer drill SBE 650 Impuls Metabo case, Product code:, 600672000
    Impact drill SB 760 with Metabo toothed chuck, Product code:, 600840000
    Impact drill GSB 13 RE + acc Bosch case, Product code:, 0601217103
    Screwdriver BS 12 NiCd, 2x1.7 NiCd, Metabo case, Product code:, 602194500
    Hitachi DS12DVF3 2x1.5 Ah screwdriver
    Cordless drill Maktec MT070E
    Store No.2:
    Graphite 58G116 cordless drill / driver
    Einhell cordless drill TE-CD 12 Li-2
    Store No.3:
    Drill-screwdriver. Vulcan Con VZV14B 14V 2aku PLN 235
    Drill-screwdriver. Vulcan 12V 1.2Ah 2aku + case 189 PLN
    Screwdriver 12V 2 Aku 1.5 Ah Triton 269 PLN
    14V 2 Aku 1.5 Ah Triton screwdriver 322 PLN
    What do you think about these types? Do you have experience in this matter? What would you recommend to me in the given budget?
  • #2 16140691
    procsa
    Help: 173
    Rate: 364
    Metabo, or Milwaukee is the top shelf, I have a Milwaukee impact screwdriver which cost over 2,000 6 years ago. and to this day it works like a razor, the li-ion battery is kept almost like new, I also had a Hitachi for 700 PLN, but after exactly 1.5 years of use, both batteries died; / Hitachi is at the level of Makita, medium shelf, Graphite or Einhell yet weaker.
  • #3 16146820
    beam_beer
    Help: 49
    Rate: 136
    To drill in concrete with a screwdriver, you have to spend well over a thousand, and still it is exhausting the equipment and yourself. For PLN 300, I wish you a Merry Christmas.
  • #4 16146865
    Zbigniew 400
    Help: 283
    Rate: 794
    Better get the cheapest hammer drill and screwdriver.
  • Occasional light drilling drives preference for a budget cordless tool
    #5 16152391
    chester2420
    thanks for the answers.
    On the one hand, you are right, because the equipment must be solid, but on the other hand, I will use it from time to time to hang a light painting in my apartment or a nail in the basement. With an ordinary 4.5 V screwdriver from castorama for PLN 50, to which they added a drill with a diameter of 3.5 mm, I can drill 2.5-3 cm, so I thought that the equipment for PLN 300 would be able to drill 5 cm more.
    To make maybe 20-30 holes in the walls in my entire history of drilling, I will not buy equipment for PLN 1000 and I do not have a socket in the basement to buy a power drill And I do not want to borrow a drill every time ...
  • Choose a midrange Li-ion drill with hammer action
    #6 16152413
    freebsd
    Help: 766
    Rate: 2034
    For "Sunday" work, choose something from the middle price range, but with a Li-ion battery.
    Unfortunately, impact is useful for drilling in concrete. Cheap cordless drill without hammer action until 0:34 then with hammer action:
    If you don't need to drill in concrete often, maybe focus your attention on a good cordless screwdriver (Li-ion), and for concrete, buy the cheapest drill, e.g. for PLN 39: https://youtu.be/BwPiPhZDyh0
  • #7 16152430
    chester2420
    Hey freebsd,
    This is exactly what I would do and I would not create a post, it is just a matter of not being able to connect a network processor in the basement.
    Greetings
  • #8 16153830
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1624
    If you hardly ever drill in concrete, consider buying a drill-driver without impact, and for occasional work, use a power tool rental.
  • #9 17929632
    Jamesbond664478
    Help: 36
    Rate: 163
    Hello, I join the topic. I just made a small folding bench for the cemetery. I have a question for you, how to screw it to concrete? I was planning on wall plugs, but how to drill holes for plugs? In the cemetery, there is rather no electricity to connect a normal drill. I thought to take a cordless drill, but does it make sense, will it handle concrete? I am asking for hints
  • #10 17929692
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Well, you probably have no choice, as there is no "mains" electricity. Either a battery or a generator, I don't see any other choice. If you have a cordless drill, try it, and if you doubt that it will not cope, the aggregate only saves you. You have no other option (at least I don't see it) :D :D :D .
  • #11 17929708
    Topolski Mirosław
    Help: 355
    Rate: 1624
    Once upon a time I had to screw the tombstone on, and then I had a Bosch PSB 12 VE-2 screwdriver at my disposal. It is true that there are four wall plugs, but they did it without any problems. The accessories are important, i.e. a good quality widia drill - I used Bosch drills.
The discussion revolves around selecting a cordless drill/driver suitable for occasional DIY tasks, particularly drilling into concrete walls. The user seeks advice on affordable options, with a budget of PLN 250-280, for making small holes (up to 8 cm deep and 8-10 mm in diameter) without access to mains electricity. Responses suggest that while high-quality tools like Metabo and Milwaukee are recommended for durability, they exceed the budget. Users advise considering a basic hammer drill or impact driver for concrete work, emphasizing the importance of having a Li-ion battery for better performance. Some suggest renting tools for infrequent use, while others mention specific models like Bosch PSB 12 VE-2 and Parkside PABH 20Li B2 as potential options.
