Grinding plates for valve adjustment - where to do it in Warsaw?
9156 9
Where in Warsaw can I have 28 mm valve-adjustment shims ground by 0.03–0.05 mm while I wait?
In Warsaw, take the 28 mm shims to an engine-machining shop such as Auto Grinding at Białołęcka 247, which reportedly charges PLN 15–25 per piece [#16170049] Other suggested locations are Auto Grinding in Italy at Parowcowa 6d, charging up to PLN 15 per piece, and Nagalscy at Krakowiaków 31, charging PLN 15–25 per piece [#16170049] The thread also recommends Autoszlif in Białołęka, Italy, or Gocławek [#16168972], and engine machining at Krakowiaków [#16168984] AutoPartner on Kraśnicka was said to stock shims in the required sizes, although access to the shop was reportedly difficult [#16170049]
  • #1 16168925
    bearq
    Help: 414
    Rate: 1612
    AUTOSZLIF to Białołęka / Italy / Gocławek
    kortyleski
    Help: 957
    Rate: 3860
    Machining of engines for krakowiaków.
  • #4 16169247
    kmitki
    Help: 39
    Rate: 232
    Why play with grinding when you can buy tiles of the right thickness.
  • #5 16169464
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Any head repair company should do this.
    Why play sanding?
    You will get the dimension exactly what you are interested in.
  • #6 16169649
  • #7 16169721
    kmitki
    Help: 39
    Rate: 232
    I know several places where I buy every size I need with an accuracy of 0.5. I used to play grinding too, but those were times when it was difficult to get tiles.
  • #8 16169746
    brofran
    Help: 650
    Rate: 1407
    Well, why not give it, if you know! Is mail order sale?
  • #9 16169762
    kmitki
    Help: 39
    Rate: 232
    There are 3 stores with parts in Gliwice. One at the car market. In Zabrze, at Żelazna part for a Ford. In Gliwice, Opel parts on Śliwki street, for example, for the 1.7 TD. I also bought in a workshop in Mikołów where they repair heads. I don't know by mail, but they are probably also available.
  • Warsaw valve shim grinding shops and prices
    #10 16170049
The discussion revolves around finding a service in Warsaw for grinding valve adjustment plates, specifically 28mm in diameter. Users suggest several locations for machining services, including AUTOSZL in Białołęka, Italy on Parowcowa, and Nagalscy on Krakowiaków. Prices for grinding range from PLN 15 to PLN 25 per piece. Some participants recommend purchasing the correct thickness plates instead of grinding, citing difficulties in availability. The author expresses frustration with sourcing the plates and is temporarily suspending the grinding option.
