[Solved] Bosch PWS 700-115 - replacement of the gear bearing on a Bosch PWS angle grinder
didi57 20886 7
  • #1 16844234
    didi57
    Rate: 14
    How to replace the gearbox bearing on a Bosch PWS 700-115 angle grinder. I am asking for help, because you can't get to this crap without professional knowledge of the subject.
  • #2 16844329
    TomekB123
    Help: 43
    Rate: 147
    Which placenta exactly does your colleague mean? If those in the bearing flange, then the manufacturer did not foresee its replacement.
  • #3 16844449
    didi57
    Rate: 14
    The bearing on the shaft where the worm gear is. The bearing is in a plastic body. I heard that it must be squeezed on a press.
  • #4 16844661
    TomekB123
    Help: 43
    Rate: 147
    Are we talking about this model as in the picture? If so, I do it so that I break the outer race of the bearing in a vice. Then I can easily remove the plastic collar. Then, without any problems, using a press, I remove the remaining inner race along with the rack.
    Before disassembly, measure the position of the rack on the shaft so that it is in the same place after reassembly.
  • #7 16844966
    didi57
    Rate: 14
    Thanks. I was hoping that I would be able to change the bearing myself somehow.
  • #8 17677195
    didi57
    Rate: 14
    I was not able to change the bearing myself, they said about PLN 70 on the site. A new head about PLN 90. I decided to buy a new Parkside PWS 125 mm angle grinder with a 3-year warranty for PLN 99.
The discussion revolves around the replacement of the gearbox bearing in a Bosch PWS 700-115 angle grinder. Users express difficulty in accessing the bearing, which is encased in plastic and reportedly not designed for replacement. One user suggests breaking the outer race of the bearing in a vice to facilitate removal, while another mentions that the bearing is typically pressed in and not easily replaceable. The original poster expresses frustration at the inability to perform the replacement themselves and ultimately decides to purchase a new Parkside angle grinder instead, citing the cost of repairs as a factor.
