  • #1 16169524
    NowerOzw
    This is my second forum topic, but let's get to the point :) I recently bought a Turbo Pressure Gauge from a friend. And here comes a question for you: Where to connect the hose that will measure the pressure? Under the pipe from the intake manifold? The engine is 1.6td without a cooler :)
    Pawel wawa
    Help: 1262
    Rate: 4433
    Under the pipe from the intake manifold.
  • #3 16169599
    NowerOzw
    Boost pressure gauge how to connect Are we talking about it? and how to get inside? drill a hole and insert the metal nozzles from the gas?
    Pawel wawa
    Help: 1262
    Rate: 4433
    I thought you used the mental shortcut that I copied too. Of course not to the pipe itself, but to the manifold, attach the hose. You can use the gas connectors you write about. We don't know what car you have.
  • #5 16171448
    NowerOzw
    Boost pressure gauge how to connect My car is Golf 2 :) Here he gives you a picture of how it is supposed to look :) and whether it has to look like this :P ?
    Pawel wawa
    Help: 1262
    Rate: 4433
    You will destroy the pipe! Rubber works, if you disturb its structure, it will break quickly. Put in the collector. There is probably even a vacuum outlet there, so a tee is enough. If it is missing, put this gas connection in the intake manifold.
  • #7 16172401
    NowerOzw
    Oki! As soon as it gets warmer, I start working:> Insert photos as it turned out for others :P Thanks :)
The discussion revolves around connecting a Turbo Pressure Gauge to a 1.6td engine without a cooler. The consensus is to connect the hose under the pipe from the intake manifold, rather than directly to the pipe itself, to avoid damaging it. Users suggest using gas connectors for the connection and recommend checking for a vacuum outlet in the manifold for easier installation. A user mentions their vehicle is a Golf 2 and shares images for clarity on the setup.
