Lenovo - Lenovo power supply - flat plug with PIN and resistor. What?
Jack78 26040 12
What resistor value should the identification pin use in a Lenovo 45W power supply, and will a 584 ohm resistor work instead?
A Lenovo 45W adapter uses about 120 Ω between ground and the signal pin, and one user reported that a 100 Ω substitute still charged the laptop normally [#17022497] Using 584 Ω should not cause damage, but it is not the typical 45W value [#16170651] Another reply notes that a 560 Ω resistor in a service cable also worked with all boards without problems [#16171220] A later measurement table also lists the Lenovo adapter coding as roughly 0.12 kΩ for 45W, 0.263 kΩ for 65W, and 0.555 kΩ for 90W [#17022497]
  • #1 16170643
    Jack78
    Help: 5
    Rate: 35
    I have a power supply in which I need to replace the cable (with a flat 11x4.2mm plug)
    There is a control PIN in this cable. For the 65W power supply it is 285 ?, for the 90W it is 548 ?. And what should the 45W power supply be like?
    And what will happen if a 584 ? resistor is used for the 45W power supply ??
  • #2 16170651
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    Nothing wrong.
  • #3 16171212
    Jack78
    Help: 5
    Rate: 35
    But will the power supply be correctly recognized and whether the charging will proceed correctly.
  • #4 16171220
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    Should not.
    I have 560? in the service cable and all boards work without any problems.
  • #5 16172704
    slawmix1234
    Level 32  
    Help: 130
    Rate: 102
    One question, where do you want to solder this resistor? , we are talking about a cable with a flat plug that looks like a usb from a mouse, out of curiosity I checked the factory cable has two wires + and -
    , and between the negative and the pin the resistance measurement gave a result of 298Ohm, between the + and the pin there is a break
  • #6 16172783
    Jack78
    Help: 5
    Rate: 35
    There is a resistor embedded in this plug.
  • #7 16172790
    slawmix1234
    Level 32  
    Help: 130
    Rate: 102
    So what's the problem?
  • #8 16172797
    Jack78
    Help: 5
    Rate: 35
    I wanted to know what is in 45w power supplies
  • #9 17022497
    codiql
    Help: 16
    Rate: 17
    I had a Lenovo G50-30 with an ADLX45NCC3A power supply on the table.
    Measurement between Ground and Signal pin gave 120 Ohm.
    Due to the lack of lacquer, I used a 100 Ohm resistor and the charging worked properly, i.e. 1.2A - 1.4A with the Win8.1 desktop and 0.847A at 20V with the laptop turned off.
    However, without a 0.012A battery when turned off and 0.4 - 0.6A at the panel.
    I recommend post # 6 from the address http://cafealle.pl/c/index.php?topic=183.0
    Listed below:
    Measurement between V- and Signal internal pin
    20V / 2.25A 45W - 0.12k?
    20V / 3.25A 65W - 0.263k?
    20V / 3.5A 70W - 0.267k?
    20V / 4.5A 90W - 0.555k?
    20V / 6.75A 135W - 1.504k?
  • #10 17253156
    R_3_M
    gentlemen,
    Whether from the Lenovo power supply: 20V / 6.75A 135W - 1.504k?
    you can make a power supply for HP, which has the voltage levels between the outer (mass) and inner cladding is 19.9 - 20V and between the inner cladding and the pin about 15.5V.
    Can you drop by, which is the easiest way to do it?
  • #11 17254270
    Stani12
    Help: 134
    Rate: 107
    You need to replace the wire, it will have a round large / small plug. The middle pin in the power supply must be connected through a resistor of approx. 300k / for 65W / to + 19V. / remember not to connect to this point which is for Lenovo because it is connected via a low resistor to the gnd. / Enter what hp laptop, I will give more detailed resistor data.
  • #12 17254862
    R_3_M
    I already bought the cable (it rushes to me with a parcel locker ;) .
    The exact laptop model for the HP G62. Nominally there is a 65W power supply for it, but I want to make it more powerful. Since I have an unused ~ 120W power supply for Lenovo, an idea was born to use it.
    I understand your information as shown in the image below:
    The question remains: what should be the value of the resistor "R"?
  • #13 17255060
    Stani12
    Help: 134
    Rate: 107
    This is exactly how it needs to be done.
    With a 90W power supply, the resistor should be 330k.
    With a 120W power supply, a 120k resistor.
    Don't use god's fortune on Dell-i. One wire systems are programmed in Dells. They generate waveforms that the computer recognizes. The pulse bundle is power dependent.
    The amplitude of the signals is 5Vss. If the HP power supply is given to the center pin, this pin will be 19V, so it will release the identification system.
The discussion revolves around the specifications and resistor values for Lenovo power supplies with flat plugs, specifically focusing on the 45W, 65W, and 90W models. Users inquire about the appropriate resistor values for the 45W power supply, with measurements indicating that a 120 Ohm resistor works effectively for a Lenovo G50-30 model. The conversation also touches on the implications of using different resistor values, such as a 584 Ohm resistor, and the potential for compatibility with HP power supplies. Various users share their experiences and measurements, emphasizing the importance of correct resistor values for proper power supply recognition and functionality.
