Peugeot 307 SW- Turning off the radio after removing the key
obadaw 8961 11
How do I wire a Sony DSX-A40UI in a 2003 Peugeot 307 SW so it turns off automatically when I remove the key?
Swap the constant and ignition power feeds: connect the car’s yellow wire to the radio’s red wire and the car’s red wire to the radio’s yellow wire, and verify which wire is fixed +12 V and which is +12 V after ignition using the radio manual and a test lamp [#16173225][#16173530] In this case, the thread also concludes that the Peugeot keeps temporary power after the key is removed, so it cannot really be bypassed in the usual way [#16976958] Because of that, the practical solution is to switch the radio off manually with its own button [#16976958]
  • #1 16173208
    obadaw
    Rate: 18
    I replaced the radio in my Peugeot 307 SW 2.0 16v from 2003 with a standard Sony SONY DSX-A40UI.
    I have a question what needs to be done so that the radio turns itself off after removing the key from the ignition as it was on the original radio.
  • #2 16173225
    kkknc
    Help: 1916
    Rate: 6722
    Properly connect the red and yellow wires.
  • #3 16173242
    obadaw
    Rate: 18
    I have connected yellow and red because when I was normally connected, I lost stations what I had saved.
  • #4 16173281
    kkknc
    Help: 1916
    Rate: 6722
    Together it will not turn off. Swap places.
  • #5 16173388
    obadaw
    Rate: 18
    If I change places (yellow - yellow, red - red), it will return to its initial state, i.e. I will lose the stations saved earlier: /
  • #6 16173453
    kkknc
    Help: 1916
    Rate: 6722
    You don't read. You have to turn yellow to red. Red to yellow.
  • #7 16173459
    Rysio4001
    Heating systems specialist
    Help: 617
    Rate: 1079
    Where yellow was connected, connect red, and where red was connected, connect yellow.
    Greetings.
    UPS, as I wrote the answer, has already fallen the same.
  • #8 16173465
    obadaw
    Rate: 18
    You don't read too ...
    Currently I have combined yellow and red
  • #9 16173484
    Rysio4001
    Help: 617
    Rate: 1079
    And you don't read with understanding.
    Disconnect these cables and reconnect them as you did before when you lost stations, only connect yellow where red was connected and red where yellow was connected.
  • #10 16173530
    tzok
    Help: 3177
    Rate: 6565
    Yellow from the car is to be combined with red from the radio and vice versa. And it's best to take the instructions from the radio and read where the "fixed" plus and where the plus should be "after the ignition", and then determine on which wires the original installation is what (preferably with a "test tube" with a bulb).
    http://download.sony-europe.com/pub/manuals/swt/Z012/Z012648111.pdf
    Two solutions will meet on car radios:
    - In better aftermarket radios and most factory ones, the main power supply is constant, and the power supply "after the ignition" is only for information, to control the so-called "ignition logic" on the radio (there is practically no current in this circuit). Such radios can be turned on with the button, without the key in the ignition (but they usually have a timer and turn themselves off after a dozen or so or several dozen minutes), but of course they turn on themselves when the ignition is turned on (or rather they return to the state they were in when the ignition was turned off) .
    - In cheaper radios, the main power supply is "after the ignition", and the constant power supply only serves to maintain the settings memory. These radios cannot be turned on when the ignition (or ACC circuit) is turned off.
    Hence, by putting a cheap radio in the place of the factory, it is usually necessary to swap the power cables "cross-wise" (although this may cause a problem with the load capacity and protection on these circuits in the factory installation).
  • #11 16173531
    kkknc
    Help: 1916
    Rate: 6722
    And this is bad. Connect as I wrote and colleagues.
    sometimes ;)
  • #12 16976958
    obadaw
    Rate: 18
    Everything has been done as intended, but it turns out that Peugeot after removing the key from the ignition has temporary support and this can not be bypassed. So it turns off the radio directly with the button on the radio. Thank you for your help.
The discussion revolves around the issue of a Sony DSX-A40UI radio not turning off automatically after the ignition key is removed in a Peugeot 307 SW. Users suggest that the problem may stem from incorrect wiring connections, specifically the red and yellow wires. The correct configuration involves swapping the connections: the yellow wire from the car should be connected to the red wire of the radio and vice versa. However, the original poster indicates that this solution leads to the loss of saved radio stations. Ultimately, it is noted that Peugeot vehicles may have a temporary power support feature that prevents the radio from turning off automatically, requiring manual shutdown instead.
