Alcatel Pixi 4 (5) 5010D: White Screen after PL Language Upload, SP Flash Tool & ROM Issues
max_gsm 5613 10
How can I fix a white screen after flashing language/firmware on an Alcatel Pixi 4 (5) 5010D and get the correct ROM for this dual-SIM model?
The white screen means the flashed firmware does not match the phone’s board/version; if you only wanted to add Polish, flash only `system.img` and `custpack.img`, or use the full firmware for the correct PCB variant because this model has 3 board versions [#16472371] If `Alcatel Mobile Upgrade S 4.5.9` says the latest software is already installed, edit and re-upload `pro_info.img` first [#16472371] One user also recovered the phone by replacing `system.img` from a ROM that booted, then flashing everything again with SP Flash Tool, which kept IMEI intact, but Polish was still missing [#16472916]
  • #1 16471442
    max_gsm
    Rate: 42
    Hello colleagues. I wanted to upload the PL language to the Alcatel Pixi 4 (5) 5010D and unfortunately after uploading I have a white screen, only the backlight without any content on the LCD.
    I uploaded the software using SP_Flash_Tool_v5.1712, everything uploaded without errors, but as I wrote above, only a white screen, there is a sound when starting the phone and nothing else. It looks like it is not a suitable rom. In total, I uploaded three roms but the same on each.
    I also tried the original Alcatel Mobile Upgrade S 4.5.9 but the program crashes the message that the phone has the latest software installed. I am asking for help and thank you in advance.
  • #2 16471654
    tonk
    GSM specialist
    Help: 137
    Rate: 57
    As you mentioned the wrong rom, did you write down what was on the phone before uploading?
  • #3 16471691
    max_gsm
    Rate: 42
    Unfortunately I did not write it down, my mistake. Now I uploaded a rom from 5010X and the phone started but it stands on the logo and it doesn't go any further.
    I need a rom for 5010D it is dual sim.
  • #5 16471876
    max_gsm
    Rate: 42
    The rom from the first link is the first one I uploaded and there is a white display.
    The rom from the second link is a rom that can be loaded from the TWRP level also in this case.
    On the other hand, from the third link, I also downloaded it, but unfortunately the archive requires a password that does not exist.
  • #7 16471980
    max_gsm
    Rate: 42
    I also uploaded this one and there is an effect like the previous ones, i.e. a white screen. Now I have uploaded a rom from 5010X and the phone is up but there is only one imei now because the rom is probably for one card model. A strange thing, because this model was available on our market. I keep searching
  • #9 16472371
    gsm-tech
    Help: 56
    Rate: 43
    If only PL was to be caught up, it was enough to select only system.img and custpack.img when uploading and it would not be white, at most if it would hang on the logo. Now it only remains to upload the full full size to the appropriate PCB version, and there are 3 of them in this model ;) As for the information in Alcatel Mobile Upgrade S 4.5.9 that the latest software is already installed in the phone, just download the pro_info.img file, edit it, upload it again and after the problem ;)
  • Can CM 13 system.img be flashed via SP Flash Tool?
    #10 16472916
    max_gsm
    Rate: 42
    I was able to put the phone back to its original state.
    I replaced the system.img file from the rom with a white screen to the rom where the phone was firing but only had one imei and I uploaded everything via SP Flash Tool. Everything smiga and, surprisingly, even imei did not break out, but unfortunately I still do not have Polish. On Elektroda I found a rom apparently with Polish but you need to upload it via TWRP but after uploading TWRP the phone does not go into recovery at all, I tried different versions of twrp but it does not come in every time. Is it possible to get the system.img file from this rom and upload it with SP Flash Tool because I've never done it? rom named cm-13.0-20160817-UNOFFICIAL-PIXI5010.zip
The discussion addresses the issue of a white screen on the Alcatel Pixi 4 (5) 5010D after attempting to upload Polish language support using SP Flash Tool v5.1712. Despite successful flashing without errors, the device only shows a white backlit screen with no display content, although it produces startup sound. Multiple ROMs were tested, including those for the 5010X variant, which boots but lacks dual SIM functionality and shows only one IMEI. Attempts to use Alcatel Mobile Upgrade S 4.5.9 failed due to the software detecting the latest firmware already installed. Suggestions include verifying the correct ROM for the 5010D dual SIM model, selectively flashing system.img and custpack.img to avoid white screen, and modifying pro_info.img to bypass upgrade tool restrictions. The user restored the phone by combining system.img from a working ROM with others via SP Flash Tool, preserving IMEI but still lacking Polish language. Attempts to flash TWRP recovery for installing a custom CM-13 ROM failed due to recovery boot issues. A community-shared firmware for Alcatel 5080D dual SIM was provided as a potential white screen fix. Links to various ROM sources and firmware archives were shared, some requiring passwords or containing incomplete files. The discussion highlights the importance of matching the exact PCB version and ROM variant for successful flashing and language support on the Alcatel Pixi 4 (5) 5010D dual SIM device.
