Opening XML Invoices: Best Software/Tools for Viewing, Printing & Converting to Readable Formats
fortaigne 4956 2
  • #1 16174562
    fortaigne
    Rate: 10
    Hi
    I am asking professionals for help. I received an xml invoice and can't open it. However, when I think about opening, I mean such an opening (most likely in the invoice program) that I would see the invoice with columns, i.e. ready to be printed. I downloaded a VAT program that supposedly can do it, I followed the advice on what to set but ... to no avail. How could I open an invoice that would be ready for printing?
    Opening so far it was visible but completely useless in one pass.
  • #2 16174583
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Can't you ask the person who sent you the file how to open it?
  • #3 16174601
    djwheele
    Help: 9
    Rate: 58
    The xml format is an open format "extensible markup" and it all depends on how the file was prepared.
    A tag is understood as e.g. a code block
    123456789
    and it is only up to the programmer of a given XML file that "interprets" such code.
    After searching for the tag, he will substitute it in his print layout under the invoice number field, or under the address or company data - it all depends on the programmer and the program code from which such XML was thrown out.
    I suggest that you write to the person who sent you this invoice for the name of the software they are using - or simply - to print the invoice in PDF and send it to you.
